Philips Laserfax 725 SERVICE [2] ERROR CODE
Machine shows SERVICE [2] on display and red LED is flashing. Machine will not function. I have turned it off at power source and tried several times with no success. There is no paper jammed in machine. I do not know how to cancel and reset system warnings, so have been unable to try that option. Part numbers on manufacturers label are LPF725 and PX420F and PX02 0412 00BVT9. Thanks, regards,
Tim
  • stevenso Aug 01, 2008
    i,
  • johnny958 Sep 15, 2008
    error code 2
2 Suggested Answers
  • 37 Answers
SOURCE: Philips Laserfax 725 SERVICE [2] ERROR CODE
Service 2 relates to the Fuser unit. It will have to be replaced by an engineer.
Posted on Jun 19, 2009
Reset philips laserfax 855
laserfax 855 showing massage and error red light no work any key and no have phone tone in machine how to fix tell me plz
Jul 26, 2013 | Office Equipment & Supplies
Zanussi washing machine error codes 1 red flash and then 1 green flash
Hi there Yovanah:
Reds and greens on the start LED in a recurring sequence (unless you have an LCD display in which case the error code is displayed on screen).
Red flashes are the first digit in the error code, green the second. i.e. 5 reds, 2 green, then pause = E52. Which indicates a fault in the drive train...motor, motor capacitor, wiring, or pcb. Error codes are far from foolproof...on the contrary they can be directly misleading at times. But invalid error codes are almost always an indication of a defective pcb.
According with your code, E11 = Problems with water fill in wash phase (maximum 10 minutes for each fill phase).
Possible causes:
1: Tap closed
2: Mains water pressure insufficient
3: Solenoid valve
4: Hydraulic circuit of pressure switches
5: Pressure switches
6: Wiring 7: Main PCB
Hope this helps; also keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using Fixya, and have a nice day
Dec 19, 2011 | Washing Machines
Machine stopped mid cycle and green light flashing under green start button
Many modern washing machines display error codes if they detect a fault, but not all washing machines display a readable error code, some indicate an error by flashing, or lighting some of the lights.
Hotpoint, Indesit, Zanussi error codes
Hotpoint, Indesit washing machines and Zanussi washing machines are some common appliances that display coded error codes. On their more expensive models, they display readable error codes but basic models (without digital displays) use flashing lights to convey the error fault code.
If your washing machine malfunctions and you can see some of the lights flashing, or one or more option lights have lit up, then make a note of which lights are flashing and which option lights are lit. NOTE: the error code list engineers have only shows the option lights by number and not by name. Therefore you need to report the lights as LED 1 and 3, or 2 and 4 etc. and NOT "delay timer" and "extra rinse". Count the lights from the left (or from the top if in a column) and report as "led 1 and 3" etc.
No Option lights?
With basic washing machines that have no option indicator lights, count the number of flashes. For example, the door locked indicator may flash 7 times, pause, and flash another 7 times in a constant cycle which would indicate error code 7.
This information is vital, and needs mentioning when reporting a fault.
Jan 18, 2011 | Zanussi FJS1225W Front Load Washer
System error #1 Panasonic kxtg2770
1)On handset, press MENU, 0, 0, 1.
Handset display shows as follows.
*Skip this step when handset already shows as above.
2) On base unit, press LOCATOR for 3 sec until CHARGE LED flashes.
3) On handset, press OK button. Then wait until the handset display changes as follows.
If you receive an error message indicating the maximum number of handsets have been registered, you will need to deregister the handset from the base unit, then try to register again.
*If this does not work, your unit is defective. Please send your unit for service.
Panasonic Services Company Customer Servicenter
Suite B 4900 George McVay Drive
McAllen, TX 7850
McAllen, TX 7850
1) Press FUNCTION on handset. Then, using the Navigator key, press Down (V) 4 times, Right (>) 1 time, Down (V) 7 times, Right (>) 2 times.
2) On base unit, press MUTE. (MUTE LED flashes.)
Dec 04, 2010 | Panasonic KX-TG2770 Phone System w/...
My philips tv flat screen keeps shutting off and a red flashing code starts blinking?
Not sure what code since you didn't say, but here is the code breakdown.
When the TV does this, the RED LED on the front will blink. For digits 1-10 it will blink pause then repeat. For numbers with 2 digits it will blink the first digit slow and then second digit fast. So 25 would be 2 slow blinks followed by 5 fast blinks.
Error Description Error/Prot Detected by Device Defective module Result
1 I2C1
2 I2C2
3 I2C3
4 I2C4
5 VIPER
6 5V supply
7 8V6 supply
8 1.2V DC/DC
11 3.3V DC/DC
12 12V supply
14 Supply Class D amplifiers
14 Supply Audio part SSB
17 MPIF1 audio supply
18 MPIF1 ref freq
25 Supply fault
27 Phoenix
28 MOP
29 AVIP1
31 AVIP2
32 MPIF1
34 Tuner1
37 Channel decoder
39 POD Interface
43 Hi Rate Front End
44 Main NVM
45 Columbus
53 VIPER
63 PDP Display
Dec 27, 2009 | Philips 50PF7320A 50 in. Plasma HDTV
Dishwasher won't start, turns on but no display
1: Defective door lock switch
2: Defective electronic control board.
Get model and serial number of machine, enter model number on search engine and seek same like conditions. You should find solution to problem, or place model number here for me to correctly tell what is wrong.
Oct 01, 2009 | Dishwashers
Apr 17, 2009 | Panasonic Panafax UF-560 Plain Paper Laser...
No Pictre, Flashing Power LED - Philips 42PFP5532D Plasma
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details of many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board is faulty.
Counting of number of blinks to Philips TVs is entirely different to that of other brand TVs. It is not a direct count procedure. The site have details about how to count the number of LED blinks [Fault Codes] to Philips brand TVs are given; along with details of the faulty circuit location.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Jan 20, 2009 | Televison & Video
Try to unplug the fax wait for about 10 sec...and plug it back.
Mar 25, 2008 | Office Equipment & Supplies
795 people viewed this question
jasbo
jasbo
