Question about Dryers
How do i replace belt on condenser tumble dryer
Hoover NEXTRA 8 HNC 382T
  • 1 more comment
  • Anonymous Mar 27, 2014
    How do you replace the belt on a hoover nexus7 HNV 172 tumble drier
    Belt replacement
    Hnv172 belt replacement
  • 30 Answers
You need to remove the whole front of the machine by removing the : top by the 3 screws at the back,then unscrew the screws across the front of the top of the bezel then remove,then open the door,remove the circle of screws then put the machine on its back,remove the screws at the bottom front of the machine,then lift the front bottom of the machine and slide it upwards then you should be able replace the belt then refit in reverse order good luck.
Posted on Mar 17, 2008
6ya staff
SOURCE:
I have a Hoover nextra 6 kg condenser tumble dryer which is leaking water and the collector is empty and seems not to locate fully into the hole at the back?
Check for Lint/Dirt in the Drain and then you need to ensure it is fully connected in the Washer to the Drain...
Jan 03, 2015 | Hoover Dryers
My mums Hoover Nextra HNC 175 condenser dryer will not turn I have removed the top and the belt seems fine The drum will turn by hand but will not turn otherwise I have tried putting the power on and...
Try to physically turn the motor @ the pulley on the motor shaft. It sounds like the motor might be seized. If it does turn, there is a small fuse link on top of the motor that can be replaced. Good luck to you.
Jan 12, 2014 | Dryers
Hoover Nextra 6 1400 6+4kg - the tumble dryer
under top cover there are 2 thermal cut outs to reset.situated centre front
Sep 12, 2009 | Hoover Nextra HNWL 3136 Front Load Washer...
The drum on the tumble dryer isnot moving, why is this?
The belt can be replaced as follows.
1 remove top and front of dryer shell
2 belt goes around drum around motor pully then under tentioner wheel
3 replace front and top of dryer
(top pops off use a slotted screw driver)
Thanx for using Fixya Please take your time to rate me
Jun 18, 2009 | Zanussi TC180W Electric Portable Dryer
Noisy when running need to check belt and bearings
i need the serial # to assist you better
thank you
May 14, 2009 | Dryers
There is no heat
Disconnect power and access your dryer fuses. Check and test your fuses for "continuity". Most likely, a white thermal fuse. Can possibly be your ignitor or heat element as well. Is your dryer gas or electric?
Jan 27, 2009 | Hoover Dryers
Hoover Nextra 8 dryer making a squealing noise
you have to open the dryer and lubricate the rollers, these are the parts that normally make the squealing sounds.
tnx 4 using fixya,
drcool
Oct 07, 2008 | Dryers
My noisy hoover tumble dryer...help please!
possibly bearings gone on drum shaft
Mar 20, 2008 | Dryers
Leaking condenser tumble dryer
i have the same problem i need help sick of putting towels down infront of it
Dec 28, 2007 | Washing Machines
Dryers Logo
662 people viewed this question
Top Dryers Experts
Marvin
Marvin
jimorris77
