Question about Car Audio & Video
Car speakers and ground wires
My speakers have a really bad humming noise and I have an extra batterie in my trunk with my positive wire going from my under hood batt. to my trunk batt. then my ground from the trunk batt. to under the car the a shorter ground going to a self tapping screw in my trunk. But now when my system hits it makes my batt. gauge needle jump back and forth and my head lights go dim. What is the problem?
    Sergeant:
  • 300 Answers
  • What gauge is the wire used to route your battery + and - ?
  • What does audio your system consist of?
There could be several things happening. The hum is most likely from a ground loop or bad ground of some kind. Search the web for a "ground loop isolator" and pick one up.
The dimming sounds like there's just too much draw on your batteries for the wiring and system that you have. If the wire used to connect amp to battery and battery to battery are too small, there will be too much voltage drop in the wire. Plus, if your system is giant, you may have to add a 1 farad capacitor (or larger) or a high output alternator to your system to keep up with the power draw by the amp(s).
Posted on Mar 18, 2008
Have a humming noise in both of the speakers
Something's crossed, keep power lines and sound lines seporated double check wires in and out u could have bad sound wires and if so of home just buy new for a car get the RCA lines with a built in ground.
Aug 07, 2014 | Toymax Magnavox 37MF231D 37 in. LCD TV
Dennis my 1995 lincoln towncar JBL radio quit producing sound the system comes on fine but I get no sound could u help me please, what is the problem?
The Amp in the trunk might have blown,
Town Car Radio Wire Diagram
Car Radio Battery Constant 12v+ Wire: Pink/Light Blue
Car Radio Accessory Switched 12v+ Wire: Yellow/Black
Car Radio Ground Wire: Black/Light Green
Car Radio Illumination Wire: Light Blue/Red
Car Stereo Dimmer Wire: Blue/Red
Car Stereo Antenna Trigger Wire: Blue
Car Stereo Amplifier Location: Trunk
Car Audio Front Speakers Size: 5? x 7? Speakersir?t=modilife-20&l=as2&o=1&a=b00009uhre
Car Audio Front Speakers Location: Doors
Left Front Speaker Positive Wire (+): Orange/Light Green
Left Front Speaker Negative Wire (-): Light Blue/White
Right Front Speaker Positive Wire (+): White/Light Green
Right Front Speaker Negative Wire (-): Dark Green/Orange
Car Audio Rear Speakers Size: 6? x 9? Speakers[img src="http://www.assoc-amazon.com/e/ir?t=modilife-20&l=as2&o=1&a=B00009UHRE" width="1" height="1" border="0" alt="">
Car Audio Rear Speakers Location: Rear Deck
Left Rear Speaker Positive Wire (+): Gray/Light Blue
Left Rear Speaker Negative Wire (-): Tan/Yellow
Right Rear Speaker Positive Wire (+): Orange/Red
Right Rear Speaker Negative Wire (-): Brown/Pink
Check the fuses
24851106-prgqozi4aluuon54ixeydqz4-5-7.gif 24851106-prgqozi4aluuon54ixeydqz4-5-0_0.jpg
Jul 20, 2014 | 1995 Lincoln Town Car
Audio Wire Diagram
2003 Nissan Murano Car Audio Wire Guide
Car Radio Battery Constant 12v+ Wire: Yellow
Car Radio Accessory Switched 12v+ Wire: Pink/Black
Car Radio Ground Wire: Chassis
Car Stereo Antenna Trigger Wire: Green
Car Stereo Amp Trigger Wire: Green/White
Car Stereo Amplifier Location: Inside the trunk, under the floor covering.
Left Front Speaker Positive Wire (+): White
Left Front Speaker Negative Wire (-): Black
Right Front Speaker Positive Wire (+): Yellow
Right Front Speaker Negative Wire (-): Brown
Car Audio Rear Speakers Size: N/A
Left Rear Speaker Positive Wire (+): Orange
Left Rear Speaker Negative Wire (-): Black/Pink
Right Rear Speaker Positive Wire (+): Blue
Right Rear Speaker Negative Wire (-): Black/White
Oct 31, 2012 | 2003 Nissan Murano
Headlights not working no blinkers 1987 Cadillac Deville
You have a bad ground wire somewhere. Try running a new ground directly from the battery to the body of the car, possibly attach it to a strut bolt or something handy to the battery.
Wires run along the drivers side perhaps under the carpet and door kickers or plastic plate in door jam to the back of the car. Open trunk remove left side carpet just behind the tail lights and check this wiring.
Locate the negative wire going to your head lights (only need 1 and run a new wire from it directly to the battery or the ground you made from the battery to the body.
Nov 24, 2017 | Cars & Trucks
Wiring diagram for radio
2005 Nissan Murano Car Audio Wire Diagram
Car Radio Illumination Wire: N/A
Car Stereo Dimmer Wire: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Car Audio Rear Speakers Location: N/A
Oct 02, 2009 | 2005 Nissan Murano
Need diagram of audio system
2006 Ford Taurus Car Radio Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: White/Red
Car Radio Accessory Switched 12v+ Wire: Black/Pink
Car Radio Ground Wire: Black or Black/Yellow
Car Radio Illumination Wire: Dark Blue/White
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: Drivers side shock tower in trunk on sedan’s or station wagon behind spare tire.
pls rate
May 28, 2009 | 2006 Ford Taurus
Cant find stereo wiring diagram for 95' olds aurora
1995 Oldsmobile Aurora Car Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Ground Wire: Black/White
Car Radio Illumination Wire: Gray/Black
Car Stereo Dimmer Wire: Brown/White
Car Stereo Antenna Trigger Wire: Dark Green
Car Stereo Amplifier Location: N/A
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Car Audio Rear Speakers Location: N/a
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Apr 07, 2009 | 1995 Oldsmobile Aurora
Install new cd player please help
HERE U GO.
2002 Pontiac Grand Am Car Audio Wiring Diagram
Car Radio Accessory Switched 12v+ Wire: The radio harness does not provide a switched power source. Run a wire to the fusebox for switched power.
Car Stereo Amp Trigger Wire: Pink
Car Stereo Amplifier Location: Mounted behind trim in the left side of the trunk.
Feb 05, 2009 | 2002 Pontiac Grand Am
NEED DIAGRAM FOR THE RADIO HARNESS
2003 Ford Escape Car Audio Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Orange/Light Green
Car Stereo Cell Phone Mute Wire: N/A
Car Stereo Amplifier Location: Located on the right side of the trunk area.
Left Rear Speaker Positive Wire (+): Tan/Yellow
Left Rear Speaker Negative Wire (-): Gray/Light Blue
got this from www.modifiedlife.com
Oct 16, 2008 | 2003 Ford Escape
Audio system makes extra noises... pops
Check all the wiring. It could be a loose connection since it's intermitent. Really pay attention to the power cable, both the end for the amp and the one that's going to the battery cable.
Sep 05, 2006 | AudioBahn A8002T Car Audio Amplifier
Car Audio & Video Logo
470 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
