Question about Kitchen Ranges
I have a Bosch Worcester 24i Combi boiler which is 4 years old, last year had problems with boiler not always coming on and had the circuit board replaced, now the boiler does not come on at all and the timer does not move although there is power to the boiler. I have pressed the button at the top right hand corner which doesn't actually depress so not sure if that was effective. When I turn on manually the little red light flickers as if trying to ignite but has only a very feint click. After several seconds when nothing happens, I switch off and try again later but still no joy. What do you think the problem is
    Genius:
  • 1,226 Answers
Hello!
Thats is the problem of the boiler when the circuit had already replaced this will work but it cause another problems on the timer.
Please try unplug the boiler and replug it again to reset the setting . If not solve then maybe you should examine again the circuit board there might some parts that is not functioning.
melnavz
Posted on Mar 14, 2008
Hi I have a 24i worcester boiler I have drained the heating to do some work but I need the hot water to still work.I spoke to Bosch and they said I need to put a loop in.I am not a plumber but can get
Hi Steve, I am not a plumber but have done a lot of DIY on my own heating system with Worcester Bosch combi boiler! I believe that you can have the hot water on without the heating system filled, just turn all the settings as for summer use and the thermostat right down so the heating is forced to stay off!
Nov 07, 2014 | Water Heaters
MY WORCESTER COMBI BOILER 24i JUNIOR SUDDENLY STOP WORKING. THE WARNING LIGHT IS FLASHING. THE BOILER IS ABOUT 5 YEARS OLD.
when i open the tap for hotwater i can see only the flashing light on and not hotwater at all the guy changed the fan but after changing its no use waste of money i still have this problem i dont want to spend more on it can some one let me knolw the problem so that i can fix ir my self .
Jan 18, 2011 | Heating & Cooling
Lighting the pilot light on a Worcester 24CDi combi boiler.
Most of these boilers don"t have a permenant pilot light they have electronic ignition that lights the burner when you are calling for heat or hot water, is there enough water pressure in the boiler ( there is a small gauge on the bottom r/h side of the boiler the needle should be sitting at between 1 - 2 if not enough pressure the boiler won"t light )
Apr 23, 2010 | Heating & Cooling
Flashing red light on Worcester 24i junior combi boiler
Pressure is ok? at 1 bar or above
I think on this one there should be a reset button [red] on the left hand top of the casing - or lower the control panel [ phillips screw on each side] and the button is on the left of the base plate. Press this and try the heating.or hot tap
P.S. if you're on a prepayment meter check you have gas.
Nov 08, 2009 | Water Heaters
We have a Worcester Bosch Highflow 400 (10 year old) combi boiler. Over the last few weeks when we have put on the heating the boiler kicks in and fires up and the heating comes on (the water comes on fine...
The by pass pipe may be limed up. This apparently causes a reduced flow which will stop the heating side of the thing working. Call out Worcester Bosch engineer. It costs £210 including VAT and most parts and they almost guarantee to get it working.
Nov 06, 2009 | Ruud Matching Split Air Conditioner
Repressurizing my boiler
take your pick from video or text
How to Repressurise a Heating System with an Internal Filling Key ...
? 3:30
https://www.youtube.com/watch?v=zUsBw1ZpiKY
Oct 27, 2010 - Uploaded by Worcester, Bosch Group
This video shows you how to repressurise your heating system using your Greenstar gas boiler's internal ...
Repressurise Worcester boiler - YouTube
? 4:12
https://www.youtube.com/watch?v=K6fH4XfGgxo Nov 10, 2012 - Uploaded by Rory Macfarlane
This video demonstrates how to repressurise a Worcester combi boiler on the.
Product Troubleshooting Videos ' Worcester, Bosch Group
https://www.worcester-bosch.co.uk > Support > Troubleshooting > Videos How to repressurise a heating system with an internal filling key ... how to repressurise your heating system using your Greenstar gas boiler's internal filling key.
How to top your Worcester combi boiler up - Gas Care.
www.gascare-heating.co.uk/topping-pressure-worcester-bosch-combination-boiler/ Aug 4, 2014 - If the needle on the pressure gauge on your boiler has gone into the red or down to zero it means there is little or no pressure left in the heating system and it needs to be topped up ASAP. So here's Gas Care Swansea's guide to refilling your Worcester Bosch combination boiler through the internal filling link.
How do I re-pressurise my Worcester Bosch boiler? - My Plumber
www.my-plumber.co.uk/blog/how-do-i-re-pressurise-my-worcester-bosch-boiler/ Sep 1, 2015 - 6) Check the pressure on the pressure gauge. When it reaches between 1 and 1.5 bar, it is time to turn the white knob back to the right to close the valve. Be very careful not to over-tighten. 7) Turn the filling key to the left until the arrow lines up with the open padlock and remove the key.
May 12, 2017 | Heating & Cooling
My Worcester Bosch 35cdi boiler is flashing temp then backwards t forwards t, whats wrong with it.?
35 cdi worcester combi about 3 years old,heating not working,hot water works fine.It's been serviced not long ago.Room stat turned up and trv's ,but boiler want fire up,there's power to the boiler and the room stat the built in time clock is switched to on, but still nothing. do you think it could be the diverter valve, when i got there it was flashing SE which mean's it needs a service,cleaned the heat exchanger and burner with the proper worceter brush etc then re set boiler with technical, they also said it could be the built in clock and told me to disconect it, and just use the heating stat to control it.It still want fire.
Sep 03, 2008 | Heating & Cooling
Kitchen Ranges Logo
344 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
