Question about Microsoft Windows Vista Ultimate Edition
RE:Counter Registry Key
I installed My Software, after Installing tried to run by application but i cant able to run i got error "could not open counter registry key" how to Solve this????????
regards
Narain
devstudio.2007@yahoo.co.in
  • 407 Answers
Reinstall your OS.....then setup you software.......
Posted on Mar 14, 2008
Get the following error message: Your registry
If you are installing this on Windows 7 or 8 you will have to contact Microsoft directly. You can use Microsoft Technet or knowledge base to try to find a solution but I have found a bunch of this same error on their site and it appears to be a major problem.
I do know that the registry error is often a mistake and the program may run correctly after you reboot. This is a serious issue with Window 7.
Oct 15, 2013 | Microsoft Streets and Trips 2013 B17-00563
I have bought and installed Nero Multimedia 10. When I am trying to run it, it displays: "This application has failed to start because the application configuration is incorrect." Not even...
Try creating a super admin account. In command promt type this command: net user administrator /active:yes ......restart the pc after that. Then log in with the super admin account and try installing and running nero. Hope it will work.
Feb 17, 2011 | Ahead Software Nero 10 Multimedia Suite...
I cant open mozila firefox 3.6.8
Go to 'Run' and open 'cmd'
· Type 'netsh' in command console then press enter
· Then type 'winsock' and press enter and then type reset
· Restart Your PC
Another way is
· Open Regedit
· Navigate to:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Ole
· Find the Key :
· Name: EnableDCO and set
· Data: N
· Restart Your PC
· Problem Is Solve
It is a registry error. Run a registry cleaner to fix the error. Firefox creates registry key it may be error in registry key. May be dll is missing so you can run reginout cleaner to solve it.
Feb 16, 2011 | Mozilla Firefox
Can't open; says a version is already open. Can't get to tool bar....Have tried to download new version; can't close out existing version. Have thrown away all firefox in Applications..I have an imac:...
· Restart Your PC
Another way is
· Open Regedit
· Navigate to:
· Find the Key :
· Data: N
· Restart Your PC
· Problem Is Solve
It is a registry error. Run a registry cleaner to fix the error. Firefox creates registry key it may be error in registry key. May be dll is missing so you can run registry cleaner reginout cleaner to solve it.
Jan 23, 2011 | Mozilla Firefox
When i open picasa it shows run time error R6002 floating point support not loaded in picasa. what should be done?
This problem can either because your using a lower version of windows, your system might be infected or your registry might be corrupted.
You can try downloading a lower version of the picasa and try installing that on your system.
Another alternative is to fix your registry. In order to fix your registry download a software ccleaner from the following link:
http://www.piriform.com/
Download and install it. Open the software choose registry option and scan for issues. After the scan is finished you can click the fix selected issue option to fix the errors.
After fixing the registry you can try installing the newer version of picasa and see whether the problem is still there..
Nov 16, 2010 | Global Star Software Picasa for PC
When i click the application in facebook, firefox is autoshutdown, and it says: firefox.exe has encountered a problem and need to be close. please help to solve this problem!
firefox may be corrupted, uninstall it and reinstall it do the following
Try to install a newer version of firefox.
This is a common problem with Firefox and the solution is also simple.
1. First go to Task Manager and end process “firefox.exe”.
2. Go to programs -> Mozilla Firefox -> Firefox (safe mode)
3. In the check list select for defaults and disable all add-ons.
4. Click make the changes and restart.
Scan ur pc with maleware.
The another solution is
· Go to 'Run' and open 'cmd'
· Restart Your PC
Another way is
· Open Regedit
· Navigate to:
· Find the Key :
· Data: N
· Restart Your PC
· Problem Is Solve
It is a registry error. Run a registry cleaner to fix the error. Firefox creates registry key it may be error in registry key. May be dll is missing so you can run registry cleaner to solve it.download reginout
Aug 22, 2010 | Mozilla Firefox
My windows installer registery is somehow missing files
This error is caused by an Installation file that is called .msi or application is file that installs a program and it happen when that particular program is improperly installed. If you suspect such a software than you should remove it and to avoid such problems you should avoid other software running while installing a new software to be on the safe side.
Please take a backup of your Windows registry at first
To backup the registry go to Start>Run box or Search Programs and files> type Regedit. When the registry window opens click File>export and give the name to the file and select and remember the location and enter. This will take the back up of the registry.
Now obtain a good registry cleaning software. I recommend ReCure or registry Mechanic make sure the versions are the latest. One of the best Registry software is Uniblue Registry Booster. It takes registry backup automatically. These software should be able to fix your problem.
It is also recommended that you see the following link, This software can also make a difference to you
http://www.instant-registry-fixes.org/windows-repair-installer-configuration-information/
Good Luck!
Jul 22, 2010 | Microsoft Windows XP Professional With...
Mozilla won't open but ineternet is on
Reinstall or Repair your mozilla Firefox Browser using this Mozilla Firefox 3.6 installer, by clicking the link: http://www.mediafire.com/?tmwyjem2kqm .
(Mozilla Firefox Installation Guide:
1.Double click the Mozilla Firefox 3.6 installater icon.
2.click "run" button.
3.click "next" button.
4.Mozilla Firefox will automatically create a shortcut browser icon for the application software.));
May 25, 2010 | Mozilla Firefox
Activation key
product key is required only while installing the software....once Office 2207 is installed u dont require the key to open MS Word..or any office application...whay do u want to change the key now ? in any case u cant change it unless u go thru backdoor entry of changing registry/software settings...
Dec 25, 2009 | Microsoft Office Professional 2007 Full...
Office 2007
sounds like a HD problem run error correcting utility, and defrag the hard drive, cleaning the registry helps too.
also make sure you have shut off any virus program some dont like it when a program is being installed especially norton ineternet security.
check the disk make sure theres no scratches on the cd.
also bad memory will cause errors. try removing a chip from the computer and installing. ive notice when installing OS's like win xp if you have a bad memory chip it will not install.
Also you can try a different CD rom drive, the one you have could be failing.
Good luck
Jul 15, 2008 | Microsoft Office Professional 2007 Full...
Microsoft Windows Vista Ultimate Edition Logo
47 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
