Question about Samsung SMH7178STD Microwave Oven
E4 message and what to do to clear it
We keep getting the E4 error message and was told the thermistor could be greasy. Can the thermistor be cleaned or is there some way to clear the error message?
  • Samsung Master
  • 9,098 Answers
That may be it. In some cases you can clean them, but if it has become brittle, it may snap. But it's worth a try.
First of all, I'd try a cold reset by unplugging the oven for afew minutes then trying again. If that doesn't clear the error, it's probably the thermistor.
The oven would have to be removed from the wall so the outer wrapper can be removed, then you can remove the sensor and attempt to clean it.A gentle scraping with the toothpick might work, or gently soaking it in hot water. Just be sure it's dry when reinstalled.
If needed, you should be able to order a new thermistor here:
http://www.samsungparts.com/search/search.asp
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Mar 16, 2008
Ge spacemaker xl jvm1340WW error message e2
please make this step , use the multimeter, and fix it. Merry Christmas.
F2 Oven cavity thermistor closed Check oven thermistor for continuity. Replace if zero or infinite ohms.
Dec 17, 2013 | GE Spacemaker JVM1640SJ Microwave Oven
Tip
Troubleshooting KitchenAid oven, range and microwave error codes
Here list of Kitchen Aid range and oven codes.
4 Digit Failure Codes
F1 - E0 EEPROM communication error
F1 - E1 EEPROM checksum error
F1 - E2 UL A/D error
F1 - E4 Model ID error
F1 - E5 Calibration shifted
F1 - E6 Latch signal mismatch error
F1 - E9 Stack overflow
F1 - E3 Wiring harness cavity size does not match stored value
F2 - E0 Shorted touch pad
F2 - E1 Keypad cable connection error
F2 - E5 Cancel key drive line open
F2 - E6 Cancel key drive line open
F3 - E0 Oven temperature sensor (RTD) opened (upper oven on double oven models)
F3 - E1 Oven temperature sensor (RTD) shorted (upper oven on double oven models)
F3 - E2 Oven temperature is too high (Cook mode)
F3 - E3 Oven temperature is too high (Clean mode)
F3 - E4 Oven temperature sensor (RTD) opened (lower oven on double oven models)
F3 - E5 Oven temperature sensor (RTD) shorted (lower oven on double oven models)
F3 - E6 Drawer sensor open
F3 - E7 Warming drawer sensor shorted
F4 - E1 Meat probe malfunction - shorted
F5 - E0 Door Switch
F5 - E1 Self clean latch will not lock
F5 - E2 Latch during CLEAN error
F5 - E5 Self clean temperature not reached within 45 minutes.
F5 - E6 Door is open, but latch is locked
F5 - E7 Self clean latch will not unlock
F6 - E0 Return line not connected
F7 - E1 Common switch wire defective
Two digit codes:
F0 ERC Board failure
F1 ERC Board failure
F2 Oven temperature is too high
F3 Oven temperature sensor open
F4 Oven temperature sensor shorted
F5 ERC Board failure
F7 Function key stuck on ERC
F8 ERC Board failure
F9 Oven door lock failure
Microwave and Microwave combo error codes:
F1 - E3 or F1 - E4 Electronic control malfunction
F2 - E0 or F2 - E1 Keypad connection error
F2 - E3 Keypad held down too long, or keypad is shorted.
If you get an error code, try first resetting the code:
1. Disconnect power for about two minutes.
2. Connect back power.
3. If code re-appears, test and eventually replace faulty part.
Regards.
on Mar 27, 2010 | KitchenAid KHMS155LSS 1000 Watts Microwave...
F2 error message
please follow this step , use the multimeter and fix it. Merry Christmas.
E4 error message
The E4 error code is a result of a malfunctioning defrost sensor. If the error code is on the right then it is the defrost sensor in the upper chamber.
Attached is a link to Avanti service and parts. Provide them with the model number of your wine cellar and they will be able to provide you with a price and information on the part needed for repair.
http://www.avantiproducts.com/index.php?page=contact
If you have the owner's manual or are able to speak with a service technician through Avanti, then this can be a diy repair.
Sep 06, 2013 | Avanti WCR5450DZ
Cook's essential pressure cooker has an E4 error. Tried everything and cannot get the unit to start
Make sure the inner container is dry... plug he unit off then on again.
Eventually, the "E4" display would appear. I determined the steam vent valve (loose piece) was not seated on the vent hole in the cover so the pressure never built up. I removed the loose piece which consists of a metal cylinder and a black plastic cover with a handle.
Apr 23, 2011 | Microwave Ovens
My Kenwood Dishwasher shows an E4 error code
Howdy:) An E4 or E5 error indicate an abnormal water level which means too much inlet water. Here is the shortcut to the Kenwood PDF file with the user's manuals.
http://dl.owneriq.net/4/4e71b4c9-e100-4066-a29e-9c46abc1f5cf.pdf
You can cut and paste it into your browser's address window. Your model was not indicated in your message, but the error codes are standard throughout the Kenwood models. I hope you find this useful:)
Aug 25, 2010 | Microwave Ovens
?E - 5" message
From Samsung's FAQs:
"Some models are equipped with a sensor that can automatically adjust the oven's heating time based on the amount of steam in the oven. If your microwave is displaying E1, E4, or E5, there may be an issue with the gas sensor. For an E1 error, press the Cancel button and check on the food.
"Other microwaves do not give specific error messages and just display "8888" on the LED. If you get this error message, your microwave needs service.
"If the message is either ERROR or E-6, it indicates a mechanical fault.
"For all error indications, including the SE or 5E error, try unplugging the microwave from the outlet for at least ten minutes and then plug it back in. If the error persists, the microwave may require service. Please use our ASC Locator to find your nearest Authorized Service Center."
Or instead let us know if we can help further.
Aug 22, 2010 | Samsung MU3050 Microwave Oven
GE JES1290,
Not sure about an F14 error, but an F4 error is a shorted (or even just greasy) temperature sensor (thermistor). That could cause trouble with the convection and fan, etc. like you describe.
It looks like the thermistor on this model comes as part of the heater or one of the covers, etc.
If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
You can find a very good exploded view of it at:
http://genet.geappliances.com/IPCNet/Dispatcher?REQUEST=IPCNETGETPDF&file=00000000/00058700/00058754.p01.pdf
You can find parts here: http://www.geappliances.com/shop/prts/
Nov 11, 2007 | GE JES1290 Convection/Microwave Oven
ERROR CODE E 63 COMES ON AFTER 2 MINUTES ON SAMSUNG MICROWAVE
For all error indications, try unplugging the microwave from the outlet for at least ten minutes and then plug it back in. If the error persists, the microwave may require service. Please use our ASC Locater to find your nearest Authorzied Service Center
Oct 21, 2007 | Samsung SMH7174BC Microwave Oven
Microwave Ovens Logo
191 people viewed this question
Top Samsung Microwave Ovens Experts
William Miller
William Miller
Henry  Thomas
Henry Thomas
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
