Question about Sony KV-36FS100 36" TV
KV-36FS100 makes a high pitched noise,whether the volume is on or off.
Try this site
http://www.repairfaq.org/sam/tvfaq.htm
good luck!
Posted on Mar 14, 2008
SOURCE:
What may cause a high pitch hum.even when muted or volume turned down?
Samsung DLP making a buzzing noise, but works fine - High Def ...
www.highdefforum.com > ... > Rear-Projection TVs
Dec 11, 2009 - 7 posts - ‎5 authors
My Samsung HLP-5063 DLP starting making a loud buzzing noise recently. ... I've only used it to watch TV for a half hour or so at a time, as I have a new LED LCD in my room. ... Other than that, I can't figure out what might be causing it. .... a humming high pitch sound, it will be an issue with the color wheel. RCA D52W25 making high pitch noise - High Def ...
Apr 15, 2009
humming sound in my dlp - High Def Forum - Your High ...
Nov 6, 2006
More results from www.highdefforum.com
High pitched sound coming from my Samsung DLP TV - Open Forum ...
www.dslreports.com > Forums > Social > Open Forum
DSLReports
Oct 3, 2009 - 30 posts - ‎7 authors
Its so high pitched that some people can barely hear it, but I guess I have sensitive hearing. ... Anyway, this seems to be a fairly common issue and it is caused by either the ... You're probably hearing a transformer humming.
Jan 08, 2016 | Televison & Video
When turned on the screen is blank and makes a high pitch buzz
Samsung LCD TV with no video and high pitched sound - Digital TV ...
www.tomsguide.com/forum/54120-4-samsung-video-high-pitched-sound
Nov 8, 2015 - 25 posts - ‎12 authors
Our is the same model and has started making a very high pitched ... to acutally turn on and then when it does, the screen is still black and we ...
Is your LCD making a buzzing or high pitch noise ...
https://www.devside.net/blog/lcd-making-a-buzzing-noise
Dec 30, 2008 - In my case, the monitor was fine for the first two months. But then started making a buzzing noise... 1) when on, 2) worse when .... my Samsung TV ismaking high pitched noises even if its turned off. I will NEVER EVER EVER ...
TV not turning on; making high-pitched sounds - Tom's ...
Dec 13, 2015 | Televison & Video
High pitch noise from speakers
Hello there!
Sometimes High pitching its just that, static on the area, like if you are near a microwave, or near other electronic equipments, but, if the skreetching sound keep going or even if you do nothing it could be a line inside the sound card, or you need to clean the volume botton with special electrical cleaner. other that these, its contacts, or bad cap for the volume board inside.
Good Luck!
Carl
Apr 25, 2017 | Acer Computers & Internet
Kv-36fs100 power supply voltages
Just come over to me by Fixya comment with your email address. I'll send a copy of the repair book to this set to you by return mail. It has all details. OK?
Sep 02, 2012 | Sony KV-36FS100 36" TV
Need Replacement Front Panel
The Sony KV-36FS100 listed as the model number here DOES NOT HAVE A PANEL--uses a picture tube---if another model/brand let me know.
As far as the broken buttons---they may be available as a unit or not depending on the age of the set.
Getting an original remote would allow you to do without those--if you do not have the original remote (or it does not work) GOOGLE THE MODEL NUMBER OF THE SET WITH "remote" to locate a replacement.
Mar 24, 2012 | Sony KV-36FS100 36" TV
They are makeing a constant sharp noise a loud high pitched hum if you will
Right-click on the speaker icon in the lower right of your screen and choose Open Volume Control and check all volume levels (make sure they are not set to high). If this doesnt work then when you right-click, choose Adjust Audio Properties and search around for volume controls (maybe try the Speaker Volume button).
Aug 04, 2009 | Audio Players & Recorders
High Pitch Noise on 42" PLasma Gateway TV
how old is your plasma TV? try check the switch / volume of the sound settings.. Sometimes, when you always increase the volume, it will tend to alter the limit of sound and causing the sound to provide sound undesiredness. I suggest to check it with a liscensed technician.
Feb 05, 2008 | Gateway PLSM42TV 42 in. HD-Ready Plasma...
Speakers on Sony KV-36FS100
if you could find replacement speakers for this unit, which is probably not an easy task in itself, it would take some know-how and safety measures before you could likely do this yourself. Televsisions deal with Extremely high voltages internally and if you do not know what not to touch, you could find yourself very injured in no time at all... better bet is to simply purchase a small stereo of some sort that allows aux inputs and use this for your speakers instead of the tv speakers. probably cheaper than buying a tv, and hey, may even be worth the upgrade to a surround system of sorts...
Aug 15, 2007 | Sony KV-36FS100 36" TV
High pitch sound for Sony FD Trinitron WEGA KV-27HS420 27" TV
The high pitch squeal you hear is usually caused by a coil vibrating, normally in the horizontal circuit. I've also seen the ferrite bead on the horizontal output transistor do this, but, it is rare. I normally will repair this by finding the coil and "tightening" it. To tighten a coil, technicians use different chemicals, such as, a hot glue gun, rubber silicone or even finger nail polish. I will find the coil that screams by starting with the usual suspects and using a wooden dowel, barely touch the coil and if the pitch of the noise changes, then, thats the coil that needs repaired. If you do not know your way around the inside of a television, I never recommend you do so, since, this procedure must be done with the set turned on and you poke your hands around the inside of the set by the high voltage circuit. Hope this helps your decision.
Mar 04, 2007 | Sony FD Trinitron WEGA KV-27HS420 27" TV
Sony KV-36FS100 36" TV Logo
41 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
