Question about Samsung HL-R5078W 50" HDTV
Failure to start. PERIOD.
Is the wheel replaceable and where would i find one? i took the lamp out and it looks fine. i see the fan that cools the lamp. and the sound seems like its coming from behind the fan and i have no clue how to get behind that.
  • 92 Answers
Sorry it took so long to get back to you. i could get you the part# if you need. I just need the mod. #. as for getting at it its on the optical block. if you take the back cover off the TV you'll see two screws holding the metal frame to the bottom of the TV. take them out and the whole chassis will slide out. you need to be careful. there will be a couple of wire connecters that will have to be unplugged (some of them may strip easily). once you get the optical block out the color wheel will be right in the middle. follow the thin ribbon strip(1/4'') to the wheel. thwere should be four screws holding it in. lift it sraight up(notice the ruber gasket make sure it is set correctly when you replace the wheel). be very careful when putting the new wheel in place as you can tell it is fragile.
good luck hope this helps
Posted on Mar 19, 2008
Remove c-24 errorminolta di450/500
Sir/Mam,
C0F24 Code is the code for the sensor that monitors the drum. I would remove the drum cartridge two black screws pull out the drum assy. Remove the drum be careful do not nick or harm the drum the sensor is located on the left side of the to the rear of the of the drum looks like to little eye of a bug. Dust with a brush NO VACUUM static could destroy it. Re-install drum and re-install cartridge. When the last time a PM was done Developer replaced and Drum replaced?
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Dec 14, 2014 | Minolta Office Equipment & Supplies
My toshiba mod. 52hm95 lamp cooling fan is making noise and i am having trouble locating a replacement
Fan like noise may be a fan or the color wheel---color wheel spins at high speed(lamp faces it) and when failing you will have a high pitched or fan like sound---hard failure and you will hear a grinding sound.
May 16, 2012 | Televison & Video
Jvc projection will not work
May be a fan failure. Mine did the same thing a couple of times. i unplugged the tv, cleaned the cooling fan and plugged back in..the tv worked fine after that.
Apr 20, 2010 | JVC TS-CL110UAA Projector Lamp
Toshiba 62hm196 just replaced lamp 2 weeks ago and this one is blown to, fan is working fine is it just a bad lamp or could something else be causing failure? When i inserted the replacement it fit...
It could be the ballast. The ballast is what fires the lamp and an over or under voltage to the lamp could cause it to blow prematurely. A clogged fan could also be causing the issue if the lamp is not cooling correctly but you said the fan was fine.
It could had just been an defective lamp, send the lamp back to where you bought it and tell them it was defective. There also should be return instructions that came with the lamp and also warranty information.
Nov 08, 2009 | Toshiba 62HM95 62" DLP HDTV
When I turn it on I get a buzzing whine, picture is fine, and now noise has a rattle to it. Would this be the color wheel or maybe the cooling fan?
could be either. remove the lamp. you'll see on the lamp door a plastic protrusion. this is to press the door switch. find that switch and hold it in with a screwdriver. now turn the projector on and look inside the lamp housing in the direction that the lamp would be pointing. do you see the colorwheel spin? it should spin with a high-pitched whir. if you hear the bad noise when it starts up, replace the colorwheel. otherwise, locate the bad fan and replace it.
Oct 17, 2009 | Optoma EzPro 732H Multimedia Projector
Fan Failure Error
the temp sensor probably wore out when the fan did. just replace the sensor. usually located on the lamp housing or near the fans. looks like a transistor.
Sep 28, 2009 | Eiki LC-XG210 Projector Multimedia...
STANDBY LIGHT BLINKS 6 TIMES
Just because you have replaced lamp does not mean that this one is not Bad,Did your order orignal Sony Lamp? Also have you CK Ballast board it is what fires lamp? You could have Bad Ballast Go to E-Bay thats were i have found Good Deals on Lamps and Ballast Boards Find them on Auction ,Also your lamp should still be under warranty find out if so get another one CK power supply board look for any capacitors to be bugled/Puffed up on Top if they are they are Bad this can cause lost of start,and if you have a bad fan can cause startup failure.Fan that keeps Lamp cool.most have at least 3 Fans.Let me know if you need any more help Heres you another tipp fined out about warrant on your Light Engine Sony Had Alot of Bad Light Engines and has up warranty on Sets for this Part IT IS VERY Costly they start at $2,500.00
Aug 22, 2009 | Sony Grand WEGA KDF-60XS955 60" Rear...
Samsung HLP4663W needs fan replaced.
Apparently I was in denial about the color wheel. With my son's help, I pretty much confirmed that it was NOT the fan. I could have replaced the fan after pulling the boards out to do the color wheel, but didn't want to shoot myself in the foot. I had my son hold the lamp saftey switch so we could turn the set on with the lamp access panel off. Then after the buzzing started, I VERY, VERY carefully reached in & touched each of the 2 fans to see if the pitch of buzzing changed, or if the fans were vibrating at the same frequency as the buzzing noise. It did not change one iota. So I went with an educated assumption that it was in fact the color wheel (just like all the posts in the threads had said). Our set was born in 10/04, and the color wheel was much easier to do than the one in the excellent step by step post that I found elsewhere. The procedure for accessing the fan (if the need be) is basically the same as the colorwheel replacement procedure, as far as removing panels & boards, etc, and gaining access to the fan (you can't do it just thru the lamp access panel). It took me & my son about 2 hrs (including the fact that we forgot to reinstall the colorwheel hood/shroud the first time we reassembled). We also didn't have that jumper to deal with either. HOWEVER, while the picture looks great for the most part, I think I may have to use the service menu to set the color levels correctly. The problem being with the black levels I think, because in a dark scene in a movie, shadows look blotchy, almost rainbowy in a somewhat pixelated sort of way. The new colorwheel came with a little sticker with the new CCA color setting values as well, but in researching the service menu access codes, I read one post where someone said that simply accessing the service menu (even if it's just to see how many hours you have on your lamp, without even changing any settings), will reset all your settings. I don't know if this is a problem for me, as I never changed the settings before, and never had it serviced by anyone else.
Jul 22, 2009 | Samsung Televison & Video
Infocus screenplay 7200 fan failure with new lamp After powering on, red LED blinks 4 times which means fan failure of the fan that is part of the lamp module. Already returned initial new lamp and got...
Not sure if this helps with the 7200 bu had a 4805 with a failed fan issue. There are two fans inthe unit, one smaller one that cools the color (colour) wheel and the larger one that cools the lamp. This unit had a problem with the larger lamp fan not turning. Unplugged and disassembled the unit to get the fan out and tested the fan using a 9v battery and a couple of wires (best to uplug the fan from the controller board so you are not forcing voltage into the unpowered controller board... that said, I did it hooked up just peeling back the label in the centre of the fan and touching the wires to the solder contacts) The fan worked fine so figured the controller board was the issue, so this wasn't going to be a simple "buy a new fan" issue.
Here is where your mileage may vary...
I decided that it would be OK to just run the fan. Unplugged the fan and powered it from the 9V battery and assembled the unit and powered it up. Found that there was 7v available on the power board at the second pin that was alwasy on when the power switch was on (thats the positive 7 V pin, but measure it with a meter since we are talking about a different projector) and just wired the fan direct to pin 1 and 2 (1 is ground on the 4805, 2 is +7V) and so now whenever the main power is on the fan runs, so after ti cools down I just power off the main power when not in use... or let the fan run if the noise isn't an issue. Crude but effective fix.
Mar 13, 2009 | InFocus ScreenPlay 4805 Multimedia...
Samsung HL-R5078W 50" HDTV Logo
95 people viewed this question
Jerry Greenberg
Jerry Greenberg
