Kenwood DV-6050 Multi-disc DVD Player
Problem for Kenwood DV-6050 Multi-disc DVD Player
Problem after installing new Lens for LG DVD Player !!
By Viki_23 on Mar 14, 2008
I have bought a new lens for a DVD Player. But it needs to be unlocked, before it can be used. I have fixed the lens in the player, but when i started it, there was no laser beam emitted by the laser diode. I want to know what should i adjust to get that lens working properly? I want to unlock the lens. There are 2 presets on the lens, I tried adjusting them, but still it is not emitting the laser beam. Plz help me.
 Thanx & Regards.
Best Solution
posted on Mar 14, 2008
Very Helpful)
fairlane
Rank: Guru
Rating: 88%, 416 votes
Hi
I've been working on DVD players since they were invented, and was factory trained by Sony, Hitachi, and Kenwood, but I must admit, I'm not understanding your question.
The laser diode fires through a lense, that is supended on tiny wires, and moved into focus by an electro-magnet. Now, I have replaced lenses that have popped off due to poor adhesive from the factory, but I have no idea what you mean by "unlocking the lense"
If you mean that you have replaced the entire laser ***'y, and it is not emitting, then that is likely because the shorting bar has not been removed. It protects the laser during shipping and storage, and must be removed. If you compare it to the old laser, you will see pins shorted together by a tiny metal bar, or in some cases just solder...if this is not removed, the laser will not emitt. If you put the old one in and it does, then 99% that is the problem...if the old one does not, then the laser is probably not your problem. Hope this helps, and be careful to always look at the laser at an angle to check for red light, so you aren't performing home laser eye surgery...not a good idea!
P.S. After re-reading your question, on some models, it is possible to replace the lense ***'y, because the electro-magnet has failed in some way, and does not move the lense, but if that is the case, I don't know why the laser would suddenly stop emitting, just because that was changed...normally it is all one ***'y. Good Luck!
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Kenwood DV-6050 Multi-disc DVD
Questions and Unsolved Problems for Kenwood DV-6050 Multi-disc DVD
Do you recommend Kenwood DV-6050 Multi-disc DVD Player?
Answer
Answer
i get a bad disc message when I insert a disc any solutions?
Answer
Hi i am Arijit From INDIA , I have asemble a new dvd player , But I have faced a problem with it my... (More)
Answer
Ever since I began buying players I've had the same issue: Most will play fine or OK for a while... (More)
Answer
I have hust been offered aMemorexMDVR2120 recorder and I need to know if it is compatible with my... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top DVD Players Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(21591) 042-9690
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
