Question about Kenwood KVT-617DVD Car DVD Player
Car staereo tuner
How do i tune my stereo to amplify my dvd sound
    Problem Solver:
  • 5 Answers
Ha ha ha ha i only laugh because i now know whats wrong with your system the same thing that was wrong with mine ok cue to the sound not comeing on you have a external amp , you should well anyways just disconnect the remote wire the blue wire that you had first hooked up now connect the second blue wire to the remote wires for the the amps now when you play dvds or cds you will now be able to hear due to the remote always sending signal instead of signal from the radio which is for the antena if you wer to have an electric one
Posted on Jun 14, 2008
SOURCE:
How can I get a manual for a Jensen multifunction player tuner wall mount stereo. AWM965
Here you go.
PDF]AWM965 - Jensen RV Direct
https://www.jensenrvdirect.com/.../awm965_owners_manual.pdf
Translate this page
Features. Features of the Jensen AWM965 mobile audio system include: ... Mounting the Radio. Route power ... Press the MUTE button (3) to silence the audio output in tuner, CD, DVD, USB or auxiliary input mode. ... your portable CD / MP3 / iPod or other media player) into the AUX A/V IN (AUX 2 IN) ... Manual Tuning.
manual for Jensen multifunction player tuner wall mount stereo AWM965...
Mar 23, 2017 | Jensen Car Audio & Video
Connect with componet cables.
The only digital audio input for this TV will be via the HDMI input. Of course, even with HDMI in, you're only going to get a simple stereo output from the TV. You can use the analog L & R audio inputs for a very similar sound from the TV speakers.
The digital multi-channel audio (Dolby Digital, THX, 5.1, 7.1, etc) encoded in the program should be connected to a suitable multi-channel amplifier with either a TOSLINK (optical), RF (coaxial) or HDMI cable for theatre-like sound. This can be done by (a) cabling from the source (DVD, BluRay Disk, Set Top TV Tuner, etc.) directly to a multi-channel amp and speakers, or (b) from the HDMI output of these devices (DVD, BluRay Disk, Set Top TV Tuner, etc.) into one or both of the TV's HDMI inputs. This will provide only stereo sound output from the TV speakers. You should connect the TV's TOSLINK optical "Digital Output" jack with an optical cable to the amplifier's TOSLINK optical input jack to obtain theatre sound.
To listen to the program shown, you would select the amplifier input assciated with the optical, RF or HDMI input that is connected to the source (DVD, BluRay Disk, Set Top TV Tuner, etc.) if connected directly. If the TV HDMI input(s) are used, they are output to the TV optical output and should be connected to the amplifier optical input. The amp input associated with the optical input should be selected to hear the program with theatre-like sound.
Dec 13, 2012 | Panasonic Viera TH-42PZ80U Plasma TV
My pioneer radio wont stay tuned in
You need a 12 volt battery connection at the stereo.
Aug 11, 2012 | Pioneer Deh-1420ub Car Stereo Cd Mp3 Wma...
I have a kenwood stereo for 2000 saab 9-5. the tuner works but whenever i change it to cd you can no longer hear any music. it must be the wiring but i dont know which color wire is connected for the cd...
It sounds you are using an amplifier and using the blue wire (power antenna remote turn on) instead of the blue/white wire (amplifier remote turn on). Try hooking up the blue/white wire to turn your amp on. When leaving tuner mode, the blue wire shuts off, turning off the amplifier.
Sep 28, 2011 | JVC AM FM CD DET FACE CAR STEREO
My amp stopped workin, when i turn the stereo on, the green light is on, then when the music starts to play it turns red and stops working,
The red light on amplifier relates to power supply while the green light is indication of sound functionality. An amplifier that allows sound to generate should display both red and green lights. Howeever, some amplifiers would display only green as long as the sound is functioning.
Solving the problem
First, a red light still on means the power connections to the amplifier is fucntional least requirng repairs.
Second, the green ligh should turn on once the stereo were tuned up to produce sound. If the stereo is still on only least produce sound on the amplifier, check on the connection wires between stereo to amplifier that may have disconnected due to woofing or dubbing sound generals with unfirm wiring.
Third,
Jan 28, 2011 | JVC KS-AR7501D Car Amp
Need connecting wiring for Sony ampilfier and tuner
FM-TUNER out connect into tuner in your amplifier
Jul 06, 2009 | Audio Players & Recorders
Cant figure how to hook my stereo up
what to remember is pre-amp is before the amplifier then the amplifier to the speakers, go this route, Tuner for radio? from the radio tuner out go to the pre-amp tuner input, then from the pre-amp OUT go to the AMPLIFIER IN, tuner, cd, dvd, tv, any source, if you are using a 2 channel amp and pre-amp this is relatively easy, a little more detailed for multi-channel pre-amps and amps but follow the same path, sound source signal ie. tuner to pre-amp, pre-amp out to amplifier and speaker hookup to amp channels,
Jan 29, 2009 | Audio Players & Recorders
Alpine cva-1004 no audio video ok
Many aftermarket car stereo has to output trigger wires, one antenna and one amplifier. Antenna trigger only works in radio mode for the power antenna to operate. Amplifier wire operates in any mode the stereo is in. Check to make sure you hooked up the correct blue wire to your amplifer.
Bob
Nov 13, 2008 | Car Audio & Video
No Sound - boat stereo
Assuming that the four speakers are connected to the amplifier, then the amp is the most likely problem component. Does the amplifier show a power light when the system is turned on? Note that there is probably another fuse in the amplifier power wire, near the battery.
Mar 16, 2007 | iLO XM-MP3-CD Car Stereo
No Sound
most ram trucks came with a infinity system. the amps are in the front doors, mounted to the 6x9 speakers. and they power the tweeters in the columms, and also rear speakers if you have them. I had to replace the entire system.
Aug 23, 2006 | Pioneer DEH-P47DH CD Player
Kenwood KVT-617DVD Car DVD Player Logo
66 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Mike Duncan
Mike Duncan
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
