Question about Dewalt 18 Volt Compact Drill Kit
Keyless chuck problem
DeWalt 18Volt model DW 929 Chuck is the 510 series
The problem is I can not close the chuck.It will close about 1/3 and it jams tight. what is the problem? donannsc@mts.net
  • 3 more comments
  • Funtana Mar 20, 2008
    Thanks for the info. The problem is inside the chuck. I need information on how to disassemble it. Funtana
  • Anonymous May 31, 2008
    I need to change the chuck on my drill and I can't get it to come apart. help please.
    Thank you,
    Karen
  • trotters862 Jul 16, 2008
    HOW DO I GET THE CHUCK OFF OF A DC925
  • Gary Brackett Oct 13, 2008
    I CANNOT GET THE CHUCK OFF A DC925 DRILL. NO SCREW IN THE CENTER OF THE CHUCK. TWO HOLE IN THE SIDE OF THE CHUCK. ANY ADVICE WOULD BE GREATLY APPRECIATED.
  • danny1958 Jan 12, 2009
    i have a dewalt 925 hammer drill and chuck broke now i can;t remove chuck there is no screw in the end of it .gear is all broke chuck just spines now can you help me remove it thanks'
I had the locking screw come loose in the center and bottom of the chuck it has a left hand thread and is a torx head . It had backed out and prevented the chuck from closing.
Posted on Mar 18, 2008
The DW 929... Time for a new chuck.
The DC925s... the Rohm Keyless Self Tightening Chuck.... If you can clamp the short end of a large size hex key in the jaws and put the other end in a vise. Shift the drill into gear setting #1 (low, high torque). Grab the battery end and twist the whole drill very slowly counterclockwise and it should come loose.
If you have a broken jaw or something else where you can't clamp on a hex key... then not sure. The chuck can be completely disassembled but have never tried while it's on the drill.
Posted on Mar 27, 2009
    Champion:
  • 313 Answers
If you close chuck as you can & see if the jaw are sticking out.use a hammer & tap the chuck jaw, then open & close the chuck do it again x2. remove the screw & there you go
Posted on May 31, 2008
Dewalt instruction manual
The black thing at the end is the "keyless chuck". Grasp it just behind the silvery tip of the chuck with one hand, and grasp the knurled ring just behind THAT area with the other hand. Twist the "front" hand counterclockwise while you twise the "rear" hand clockwise. That will loosen the chuck so you can change bits.
Aug 06, 2014 | Dewalt Dc987k2 Xrp 18volt 12 Drilldriver...
How do I get the chuck off of my DeWalt DW 117 1/2" VSR Drill Serial #1229?
Open the chuck jaws and look down inside the chuck. You will see a screw head that is holding the chuck to the drill. Once you remove the screw, the chuck should pull off easily.
Jul 31, 2014 | Dewalt Drills
I have a Magnetic Drill Press DW 151, and I am trying to replace the chuck. I can not figure out how to remove the chuck. Any help would be nice thank you.
WARNING !! SOLUTION # 1 BY dleemacc_0.jpgDarryel Hubbard
IS WRONG . FOR THE DEWALT
Magnetic Drill Press DW 151I ALMOST DESTROYED A $500.-!,000 DRILL READING HIS ADVICE
THE ABOVE DRILL HAS A 1/2" X 20 THREAD THAT THE CHUCK
THREADS ONTO. LEFT TO REMOVE AND RIGHT HAND TO REPLACE YOUR NEW CHUCK . YOU CAN TAKE A PIPE WRENCH AND AFTER PLACING THE DRILL ON THE SIDE PUT THE PIPE WRENCH AT/ON THE END OF THE OLD CHUCK AT ABOUT 2 o'clock. Once set up slap
the pipe wrench very hard/fast with a suitable hammer . It took about three times to knock the chuck loose and then I removed it with my hands. A little crude but it worked. Have a good one.
Dave Shelby
Jul 15, 2011 | Dewalt DW151 magnetic drill presses
Want to Replace chuck Keyless chuck always loosens and bits fall out.
Inside the chuck barrel there is a screw which unscrews counter clockwise, then
the chuck itself should unscrew counter clockwise as well.
May 09, 2011 | Ryobi 18volt 12" Cordless Drill Model P206
How can I replace the keyless chuck on my Dewalt DWD215G?
Open the chuck wide open. In the center is a retaining screw, they usually have left hand threads. Remove the screw. Take an allen wrench1/4" to 3/8" in size and fasten the short side tightly in the chuck. The chucks are usually right hand thread, so take a small hammer and strike the allen wrench to turn the chuck to the left to loosen it. Once you have the chuck off, verify the thread size of the drill motor shaft, then go to McMaster-Carr and choose the one you need.
Apr 16, 2011 | Dewalt DWD215G 12Inch 10AMP Heavy Duty Mid...
How do you remove the chuck on a 18volt Dewalt drill.
the chuck is held to the drill by a small allen head screw that is down in the base of the chuck -- it is a reverse thread.
after the screw is removed - the chuck should pull off.
c...
Jan 24, 2011 | Garden
I have a DeWalt DW 235G drill that needs a new chuck. How do I get the old one off. I took out the screw ...then what?
Put the small end of a 1/4" allen wrench in the chuck and close the chuck on the wrench the place the drill on your bench with chuck hanging over the edge and hit the allen wrench with a hammer and it will shock the chuck loose. Hold on to the other end of the drill when hitting allen wrench.Reverse for reassembly
Jan 24, 2010 | Dewalt Drills
Cordless Drill, Keyless Chuck stuck in full open position.
if chuck is wide open ,look down inside there should be an allen screw or bolt at the bottom of the chuck it should undo anti clocwise and the chuck comes off
Aug 18, 2009 | Dewalt DW056 18 Volt Cordless Impact...
Drill chuck swap
1. Turn the screw clockwise to take it out.
2. Then you needs 3/8 allen key & insert the short side of the allen key & tighten the chuck.
3. hold the drill at the edge of the table & wack the allen key
counter clockwise & do it again as needed.
4. dewalt keyless chuck will fit but you might add a washer to insure the chuck is not rubbing the clutch collar.
5. putting it back together the other way.
Jun 01, 2008 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Dewalt 18 Volt Compact Drill Kit Logo
1,890 people viewed this question
Top Dewalt Drills Experts
Jim Thurston
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
