Question about Brother DCP 115C All-In-One InkJet Printer
Printer will not print black ink. New brother cartridge has been replaced but will not work.All coulour working fine.only black a problem
  • 1 more comment
  • jabezdc Mar 14, 2008
    Tried the water but did not work. Also tried other cartridge but not work.
  • jabezdc Mar 15, 2008
    It is so good to have people like you to help us with problems, however, I was unsucessful in my attempts of your solution. thanks anyway. Duds Car
    Appreciate help, but did not work. will see repairman. Thanks very much.............. jabezdc
    Scholar:
  • 78 Answers
More than likely you have a problem with your printhead not your cartridge but no genuine cartridges cause the most problems. It either dries out, clogs up or a piece of jammed paper gets stuck on the printhead.
Run the cleaning cycle a few times to try to resolve or open the scanner cover and try to see paper under the carriage/printhead on the right hand side just under the cover.
Otherwise the printhead requires replacement.
Posted on Mar 14, 2008
  • 3 Answers
Okay ill try your suggestions guys,,hope it work...thank
Posted on Apr 02, 2008
    Genius:
  • 1,226 Answers
Hello!
clean the black cartridge maybe dry up and fix it firmly. touching to the holder.
verify that the new black cartridge is not empty. else clean the pin touching to the holder.
may this help,
melnavz
  • 1 more comment
  • Emelio Navaja
    Emelio Navaja Mar 14, 2008
    What happen? why did you not leave comment so that i know whats wrong winth my solution.
    Ok please try another black ink if it is work in it. if no available ink then, try to soak the ink pin onto the lukewarm water for 30 seconds and wipe it out until dry and then insert it back to the ink holder.
    hope this work now.
  • Emelio Navaja
    I have done research on this and encounter same problems with no luck solution. I n this case i will suggest you to check the circuit of your printer .. if affraid to do so , maybe you should let the repairman do it for you.
    I will notify you later if i found solution of your problem.
    best resgards, melnavz.
  • Emelio Navaja
    Emelio Navaja Mar 17, 2008
    Thanks for your comments. Hope you will continue using fixya soon. Its oue pleasure to help you.! melnavz
Hello! We have a Brother MFC-J615 printer & we have been having a problem recently with the Black ink. It just randomly started to not print any black ink, but the other colors are just fine. The ink...
It sounds like you're not using the correct ink for the printer.
Each printer requires a different formula and thickness of ink for it to work correctly.
Have you recently started using a new bottle or topped up with a different ink in the system?.
Jun 29, 2011 | Brother Office Equipment & Supplies
New ink cartridges not printing
The ink cartridges that you replaced are brand new or refilled ?
Thanks
Proton
Sep 07, 2008 | Brother MFC-5840CN All-In-One InkJet...
I ran out of the other color cartridges, and just bought a new black ink cartridge only. So can it work without the other color cartridges, and only on the black ink cartridge, because every time I try to...
No many of the printers will need to have both the color and the black cartridges to work...
You will have to purchase and install a new cartridge to get it working correctly.
heatman101
May 17, 2011 | Brother MFC-290C Printer
New brother laser printer hl-2140 with new ink cartridge . All printed pages are covered with black ink. Slide the cleaner and even change cartidge, but same problem.
Please try to re align the print heads and service the carraige assembly of the printer ( Place where you slot in your cartridge). if it doesnt work then there is a leakage on the ink piping system.
Replace the Ink service station.
Sep 23, 2010 | Brother HL 2140 Laser Printer
Black ink won't print even though the cartridge is
It could be you just have a bad cartridge, If it's new, take it back and get a new one to make sure it's not the cartridge. If you get the new one and it still doesn't print black, then you have a bad print head. Meaning it would need to go to a service dealer to replace or repair the print head.
Thanks Mark
May 14, 2010 | Brother DCP585cw AllInOne InkJet Printer
Black ink wont print on my brother DC-145c. I have
you have to check if the printer is online or offline and check the port paramerters after all reinstall the printer driver.
Apr 21, 2010 | Brother Multi-Function Center MFC-240C...
Printer wont print
Try remove all cartridges then put back it one by one.Make sure the color cartridges are not empty too.The printer need all cartridges not empty to initialized and working.
Nov 25, 2009 | Brother MFC 490cw Color Inkjet...
My black ink printing all of a sudden stopped..ink in cart.all other colors work fine
All brother machine have a one year in parts and labor this machine have a print head problem.
Oct 05, 2009 | Brother MFC 210C All-In-One InkJet Printer
Printer wont print black.already replaced with new ink but still wont print black
did you take the tape off the new cartridge and is the print head burned out for the black? if you installed the diagnostic's on it then run it and see what it says, otherwise expect the print head to be cooked, however it is possible to get a bad ink cartridge try tapping it on your finger and see if ink comes out if it does not then the ink cartridge is dried out or no good, about %15 of print cartridges are bad on just about any brand printer some more than others.
May 31, 2009 | Brother DCP 165C Compact Color Inkjet...
Balck ink not working
brother mfc-5440 ~ same exact issue on not printing the black AFTER purchase new cartridge (again!) ~ i should have checked here first.... NO MORE BROTHER printers in our future & will tell all our friends, too....
Mar 08, 2008 | HP Photosmart C6180 All-In-One InkJet...
Brother DCP 115C All-In-One InkJet Printer Logo
741 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
