Question about Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony Trintron KV32Fs12
This TV was working fine, but the other day I could not turn it on - from the remote or the set - so it's not the remote. There's no power to the set at all. The plug had been a little chewed by either my cat or the previous owner's-but superficially, no wires exposed. I replaced the plug anyway, but that didn't help. I don't see ay other problem with the power cord. The only thing that's happened between it working and not is I got a few drops of water on the top of the set while watering a plant, but I dried it right away it didn't go to the back of the set. Then I set a metal bowl on the top of the set. Did I short it out? Can it be reset or fixed?
  • Graeme Ross
    Graeme Ross May 11, 2010
    Hi there, if you got water down the back of the set once watering a plant, then it is entirely possible that it has happened before, particularly as drip saucers overflow say 1/2 hour AFTER you have watered. As a TV serviceman I have told customers this for years
    DO NOT PUT WATER OR PLANTS THAT NEED WATERING ANYWHERE NEAR THE BACK OF A TV
    Keep the plants well away from it or problems will happen. Murphies Law says if it possibly can happen... then it will!!!
    I am saying that's on it, OR above it, even with a "drip catcher" in place. You are still asking for trouble.
    The metal bowl will not have affected anything internal that requires resetting. If you believe that you did not get any water down the back - remembering that the set is still powered up and active when in standby, then you may just have a power supply or other failure unrelated to the spill... BUT, please get the plants away from the TV. I have fixed so many water damaged sets over the years from plant spilovers and storm rain coming in sideways through open window behind set. Water kills TV's.
    You may need to get a repair man out to look at it. The high voltages involved with TV do not make them something that can be repaired by the novice.
    regards
    Graeme
  • 1,512 Answers
Hope the advice given helped you. If you have any questions, feel free to get back to me here.
regards
Graeme
Posted on Mar 16, 2008
SOURCE:
HI I HAVE SONY TRINTRON TV I NEED TO RESET THE TV
I already seem this on that model and it was a short diode D503 part # BY228GP.
Apr 22, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
I want the codes for my remote to control the vcr/dvd rather than just the tv
The Sony remote that came with your TV will not be able to code to your DVD / VCR combo unit, combo units have to be operated by their original type/style remote, because they operate on very specific frequencies.
Now you may be able to code the combo units remote to operate the TV, but usually not the other way around, it just won't work.
Good luck !
Jan 27, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
SONY KV32FS12 WOULD NOT START WITH REMOTE NEITHER WITH TV START BOTTON. FRONT RED LIGHT FLASHES WITH INTERMITENT MODE SEQUENCE.
You should open the TV case, then look at horizontal Circuit, check for the voltages here on main transistor collector, if there's a voltages around 115 V - 135 V, possibly you should check this Transistor, replace it if necessary....
Oct 18, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony trintron--red lights
The 2 blinks is a diagnostic code that should indicate the problem circuit. This is unique to each model though. Can you confirm that the model in question here is KV-32FS120?
Thanks,
Dan
Jan 14, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Tryin to link universel remote control to sony trintron tv
press and hold set key  press tv then enter one of the following codes as one of them will work for your tv 028   119   126 127   128   129 130   182   199 228   260   705
Dec 28, 2008 | Sony FD Trinitron WEGA KV-20FS120 20" TV
Sony Trintron Model # KV-27S22 Flashing screen
Hello
I got it fixed today at the TV repair shop down the street.
Thanks
Nov 11, 2008 | Sony HT-DDW840 System
Remote stopped work for my kp-61hs10
Sounds to me like a problem in the tv, not the remote. A short maybe, or a bad connection somewhere.
Dec 22, 2007 | Sony KP-61HS10 61" Rear Projection...
Sony FD Trinitron WEGA KV-32FS120 32" TV Logo
74 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
