Question about Canon NP 7130 Black and White Copier
Blank Copies Copier was showing code to replace toner. I put in a new toner cartridge now copier goes through the motions but pages come out blank. I've tried to reinstall cartridges but still no change. No error lights/codes are showing.
  • cas311 Mar 17, 2008
    Thanks for the suggestion unfortunately this didn't work.
Cas311 You can take off the main board and check the back tension spring on the developer unit. The plastic tab that holds the tension spring on the developer housing is probably broken. bill
Posted on Jul 17, 2008
  • 51 Answers
The Unit where you've put the toner cartridge could be to far from the drum. Make sure your developer unit (unit where you've put the cartridge in) is locked in place.
Posted on Mar 14, 2008
I replaced the cartridge and now it wont copy anything
If you mean blank copies then you either have installed a bad cartridge or perhaps you did not pull out the toner seal tape from the new cartridge before you installed it. If not then just remove the new cartridge and check one of the 2 ends of the cartridge for a small tape sticking out. Pull that out of the cartridge which will release the toner supply to the developer roller. Then re-install.
If you did this already then test for a bad cartridge by shaking the old toner cartridge back and forth a few times and put it back into the machine. It should work well enough to at least test for blank copies.
Good Luck and Thank You for using Fixya.
Sep 04, 2010 | Canon PC1061 Copier
The copier only prints the left side of the page
Sometimes the simplest solution is the best solution. On pretty much all small Canon copiers, the issue of 1/2 blank copies or blank area down the page is the toner cartridge. Just remove the cartridge and shake it from side to side to level out the toner then re-install. This will fix the problem at least 90% of the time.
Jul 13, 2010 | Canon imageCLASS D320 Digital Copier
My al-1631 gives blank copies. just replaced toner. no warning lights of any kind. no message lights. it just prints out blank paper. could it be the drum? can't find instruction manual. purchased...
Was the copier working fine before you changed the cartridge? If so I think your cartridge is the problem. If it started making blank copies right after you changed it. If this is not the case the first thing I would say is it is not the drum. Try opening and closing the right side door. There are contacts in the door that will cause blank copies. I have had several customers do this and it fixed the problem. You can also try pulling out the toner and then pull the drum unit partially out and re-seat it. Then re-install the toner.
Good Luck
Jan 05, 2010 | Sharp AL 1631 Copier
Copies blank
This is normally the corrona wire that needs to be replaced in the transfer unit and drum unit.
Sep 14, 2009 | Minolta EP4000/5000 CS/PRO Copier
Copier prints out blank paper
its is a bad, stuck laser shutter. It needs replaced with updated one. You could rip out the shutter but it is agaist the law to remove the safety feature.
Jun 20, 2009 | Canon imageCLASS MF6530 Monochrome Laser...
Toshiba e 650 Copier was working and copies were fading so we
When you changed the toner did you remove the strip on the new toner to release the toner
Jun 12, 2009 | Toshiba E-STUDIO 650 Copier
Blank copies on an ar208s sharp copier
Inside this machine has 3 sections. Toner cartridge, developing unit and drum unit. First pull out the toner cartridge then you will see a blue anodized screw, loosen this screw then pull this section ( developing unit ), if there's already toner inside the chamber, clean it and pour the all the developer into the chamber then put back the developing section, tighten the blue screw and install the toner cartridge.
May 12, 2009 | Sharp AR208s copier AR208s All-In-One...
Blank vertical streaks
the toner cartridge is running low on toner and it needs to be replaced
Mar 26, 2009 | Canon imageCLASS D320 Digital Copier
Model al-1540cs, copier produce blank copies
THERE ARE TWO CORONA THAT PRODUCES BLANK COPIES, ONE IS IN THE DRUM UNIT ON TOP OF THE DRUM UNIT. THE OTHER IS IF YOU STAND IN FRONT OF THE COPIER OPEN THE COVER TO THE RIGHT, THERE IS A WIRE LOOKS LIKE A GUITAR STRING IF IT IS BROKEN OR MISSING, NEED TO REPLACE. GOOD LUCK
Dec 04, 2008 | Sharp AL-1540CS All-In-One Laser Printer
Canon PC941 Copier: Wide white bar down middle of copies
Try replaceing the cartridge the toner has run out.
Any problems please get back to me.
Thank You
Mar 25, 2008 | Canon PC-940 Black and White Copier
Canon NP 7130 Black and White Copier Logo
133 people viewed this question
old marine
old marine
