Question about Sanyo MM-8300
To unlock code no. of sanyo mm-8300
SANYO Model MM-8300
while opening the unit lock code appear, i can;t open because i have forgotten it.
  • 3 more comments
  • u2celphish Mar 31, 2008
    i have a sanyo mm 8300 sprint phone its lock and wont open on startup
  • faithd Mar 31, 2008
    SANYO MM-8300
    LOCK CODE. TRY TO USE FIRST AND LAST 4 DIGITS BUT FAILED TO UNLOCK.
  • Anonymous May 20, 2008
    ive tried everything 2 unlock this phone n i want 2 restart it if dat will probably help
  • Poohnjackywa Jun 02, 2008
    what is cdma workshop.... why won the phone unlock on startup??/
  • Anonymous Nov 10, 2008
    Same Problem
Use cdma workshop
Posted on May 26, 2008
Call *2 - sometimes the rep will help you over the phone and other times they will tell you to take it in to the store to have it reset.
Posted on May 15, 2008
I have a sanyo dvd player dwm-395. how do i unlock it w/o remot
For the DVM-390 model, I believe this solution should work on the DVM-395 model - Push and hold down the Open/Close button until "UN-LOC" appears on the FL display (or "Disc Tray Unlocked" appears on the TV screen).
Dec 24, 2008 | Sanyo DWM-390 DVD Player
Sanyo MM-8300: ALL the keypads are frozen and won't work. Any solutions?
One thing you could test for is a thermal-fault in the phone's circuitry. To do this, you put your phone in the fridge over-night then, turn it on the next day and try the keypads while it's still cold from the fridge. If that doesn't help and you're brave enough to venture into the inner-workings of your phone to attempt repair/cleaning, you can read my post here- keys won't work on sanyo mm 8300 phone.
Hope this helps, TechnoWolfy.
Apr 20, 2008 | Sanyo MM-8300
Keys won't work on sanyo mm 8300 phone
I used a very small eyeglasses-repair flat-bladed screw-driver that was the same width as one side of the tri-angle screw head to remove the screws on half of a sanyo scp-8300 phone that I found on the road. I do advise caution when releasing the hidden plastic clips around the edge of the phone where the seam between top and bottom is. Once open, you will find a ribbon-cable that leads to the top half of the phone, a rubber pad that has all the keys on it, and the phone's circuit-board, where there is a white plastic sheet overlaying the actual physical buttons mounted on the circuit-board. My advice would be to gently clean the rubber key-pad with warm water and dish-soap. Also, check for sticky gunk around the edges of the key-holes in the plastic case of the phone, if you find some- carefully wash it off with a wet tissue or a cotton swab, use rubbing alchohol if it won't clean off. But, be aware that some plastic can melt or turn gooey when cleaned with alchohol, or it might just remove the color from it. Hope this helps, TechnoWolfy.
Feb 12, 2008 | Sanyo MM-8300
Changing language on sanyo MM 8300
hi there
you can change back to default english by pressing shortcut keys.
press menu/ok
select settings
press options(right softkey)
then select language
now slect english.
hope this helps.
Feb 07, 2008 | Sanyo MM-8300
Keys will not work
Sounds like you locked the keypad.
I know you stated all the keys don't work, but let's give this a try.
Press the "unlock" key (the key in the upper left)
Enter your lock code (usually 0000)
Let me know if this helps.
Jan 11, 2008 | Sanyo MM-8300
Sanyo mm-8300
Call Sprint tech support at 1-888-211-4727 see if they can help.
Nov 30, 2007 | Sanyo SCP-3100 Cellular Phone
Unlocking a Sanyo 7400
try this type the code ##726400# on the home screen it will come up with some options
view
edit
done
click edit and type ur number in
027.......
then
173.......
with the second thing (173.......) do not put 027 in it went ur done that it will tke u back 2 the main menu and click done and it will resstart ur phone u will still have every thing but ur code will be the last 4numbers of ur phne number and that will sovle ur problem hope it helps
Oct 18, 2007 | Sanyo MM-7400
Sanyo SCP-8300
I'd suggest a new battery, if money is no problem but otherwise, if you have a volt-meter of some kind, you could read the voltage output of the charger and compare that to what it says it should be in the input-output list usually printed on the underside. If it's fine, I'd try carefully cleaning the phone's battery and charger contacts with a small amount of rubbing alchohol and some cotton swabs or tooth-picks lightly wrapped in toilet or tissue paper. If it still refuses to work, you could see if a sales-clerk at your local phone store would let you try a new battery to see if it would work. Otherwise, you could attempt internal repair/cleaning like I outlined here- keys won't work on sanyo mm 8300 phone.
Oct 09, 2007 | Sanyo MM-8300
Powering it Up
if the battery is full charged. Just hold the Power button On untill u get a screen. Good luck
Jun 03, 2007 | Sanyo MM-8300
Need help unlocking my phone from Qwest so I can use with Alltel...
Some local wireless stores can do this for a small fee. Try finding a wireless supply store and see if they offer this. Most phone companies won't do it because they want you to stay on their network, and/or they want you to buy their phones.
May 29, 2007 | Sanyo MM-8300
Cell Phones Logo
1,103 people viewed this question
Top Sanyo Cell Phones Experts
Computer Repairing
Computer Repairing
Jeffrey Thomas
Jeffrey Thomas
Level 1 Expert
270rexton
270rexton
Are you a Sanyo Cell Phone Expert? Answer questions, earn points and help others
