Unfortunately there is no add-on to just install, but here is a solution which is pretty close:
1. Find the folder storing the .ini files for your Opera browser. On Windows this folder is usually C:\Program Files\Opera\defaults. Depending on your OS just locate your Opera main folder and navigate to defaults.
2. Save the urifilter.ini file from this address: http://www.technobeta.com/download/urlfilter.ini
in the folder
This is all! Opera will now block the main ads present on the Internet.
! the defaults folder gets overwritten at each update, so make sure you repeat the process when you install a new Opera version
!! The urifilter.ini file at http://www.technobeta.com/download/urlfilter.ini gets updated quite often so you might want to repeat the process from time to time to make sure you keep all those annoying ads away
This is the best solution which Opera can offer, though it's not by far as efficient as the most common Firefox addons..
Hope this helps,
wbwTeam
Testimonial: "This is to convey my heartfelt thanks for the Help I got here. "
Free opera 2015 update Opera 28.0 Build 1795.47 Free Download
Install addblock https://addons.opera.com/en/extensions/details/opera-adblock/?display=es-ES
AdBlock Plus is available for Mozilla Firefox, Google Chrome, Android & Opera Browsers.You can download Customised lists to block a special group of adverts, especially the type of you're talking about. Plus, you can BLOCK a control separately. If you see anything like Dating or anything and wanna block it, Use AdBlock Plus.
