Question about Kenmore 24032\24036 Top Load Washer
Kenmore Washer No Spin >> Motor problem
I removed the pump and motor. I then placed the motor on the ground, reconnected to power, jumpered the lid switch, turned to spin cycle, motor just hums and shafts do not turn. I can turn shafts by hand. Shafts fit well into bearings and not loose. Coupler was still OK.
Please tell me I do not need to buy a $140+ motor for a 6yr+ machine.
The tub is also hard to turn, however I read this is designed as the clutch frees with the spin cycle.
  • Celdon Mar 14, 2008
    Took the motor. Motor is shot. Difficult to justify fixing as will need new motor and should install new pump and coupling. Over half way there for a new washer. Thanks for the help.
  • timmer77 Mar 16, 2008
    i have a kenmore top-loader also, and just had to siphon the water out as it would not drain...physics rocks! but just now i tried fiddling with the rotary timer and got it to do the whole drain-spin thing like it's supposed to. everything else on the machine seems to work ok: no funny noises or excessive vibration. does this mean that the motor coupling is on it's way out? or what else might be the impending doom....would love to hear some ideas
It's probably the motor coupling. Same thing is happening to me, but I can not gain access to the motor
Posted on Mar 14, 2008
  • Mark Wymer
    Mark Wymer Sep 12, 2013
    Lay the washer on it's back. All you need to do is remove the pump. It's literally a two minute job to get the motor off.
  • 30 Answers
Not_a_fixit is correct. If your agitator does not spin, it is the motor coupling. Then again, if your agitator tries to spin, it is the dog agitators.
Hi The washer will not spin at all. Thanks
Washer Does Not Spin
If your washer doesn't spin, check to see if the clothes have jammed or are unbalanced in the drum before calling a repairperson. Unbalanced clothes will also cause a washer to shudder or "walk." If straightening out the load doesn't stop the washer from shaking, look at the feet underneath and be sure they are properly adjusted to keep the washer sitting level on the floor (you just turn them to move them up or down).
or try to follow this instruction
1. Open the lid and reposition the clothes. Close the lid and retry. The washer may not spin at all if the tub is unbalanced.
2. Examine the lid switch for wear. Replace a worn lid switch by first using a screwdriver to remove the top of the machine. Remove the cabinet holding the old switch in place by unscrewing the two console screws, tilting the console back, removing cabinet clips, and unlocking the lid switch block. Unscrew the mounting screws, and disconnect the ground wires before removing the old switch. Insert the new switch in it's place.
3. Look for excessive glazing or cracks on the sides of the belt. If these signs appear, remove the old belt by tipping the washing machine over on it's side, and unscrew the clamps securing the pump coupling with a screwdriver. Place the new belt over the transmission pulley, and then over the motor pulley's nearest edge, slowly turning the motor pulley to pull the belt around and into the pulley.
4. Replace the washer's motor by firmly grasping on the metal slip-on connectors holding the wires in place, allowing you to pull the connectors apart. Use a screwdriver to unscrew all of the screws holding the motor in place, and remove the old motor. Insert the new motor in its place. Secure the new motor to the machine with screws, and reconnect the motor's wiring harness.
5. Replace the washer's pump by removing the service panel on the back of the machine with a screwdriver and disconnecting the washing machine drain line and the rubber pump outlet hose. Remove the fasteners holding the pump to the bottom of the machine, along with the drive belt from the pulley below the pump. Replace the old pump with a new one, and reinstall the drive belt back on the pulley, reinsert the fasteners and reconnect the rubber pump inlet and discharge lines.
May this help your problem.
Thanks good day!
Sep 12, 2011 | Kenmore 44102 Front Load Washer
Washer won't spin
Hi
One of the most common problems with washing machines, however, is that they won't spin. Usually this is caused by an issue that easily can be fixed, but other times it can be more serious. In some cases, just the balance of the load can cause the machine not to spin.
First open the lid and reposition the clothes. Close the lid and retry. The washer may not spin at all if the tub is unbalanced.
Also check this link to get a detailed idea related to your issue:-
http://www.repairclinic.com/Washing-Machine-Troubleshooting?red=Washing-Machine-Repair-Help#itdoesntspin
Please get back to us if you have further query or else please accept the solution.
Sep 03, 2011 | Whirlpool Ultimate Care II LSQ9564J Top...
Kenmore model 110.24642300. Basket/drum doesn't spin, though it sounds as if the motor itself is working fine. It isn't the latch on the lid. I think there's a belt or clutch issue inside. ...
Hi
Thanks for contacting fixya.com
Sep 03, 2011 | Kenmore 22422 Top Load Washer
My washer won't spin and the belt is fine. What do I do?
Hi
For that reposition the clothes. Close the lid and retry. The washer may not spin at all if the tub is unbalanced.
Other than lose or worn belt there are various reasons that cause washing machine not to spin.
Check the lid switch for wear. Replace a worn lid switch by first using a screwdriver to remove the top of the machine. Remove the cabinet holding the old switch in place by unscrewing the two console screws, tilting the console back, removing cabinet clips, and unlocking the lid switch block. Unscrew the mounting screws, and disconnect the ground wires before removing the old switch. Insert the new switch in its place.
So there are various conditions when a washing machine wont spin. Please check this link to get a detailed idea related to your problem:-
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Aug 06, 2011 | GE WBSR3140DW Top Load Washer
Drum will not spin in any cycle
Hi
Then check for lose or worn or crack in belt. If these signs appear, remove the old belt by tipping the washing machine over on its side, and unscrew the clamps securing the pump coupling with a screwdriver. Place the new belt over the transmission pulley, and then over the motor pulley's nearest edge, slowly turning the motor pulley to pull the belt around and into the pulley.
Aug 05, 2011 | LG WM1814CW Front Load Washer
It does not spin - error
Hi
However there are various reasons as to why a washing machine won't spin. Also check this bellow link to troubleshoot your issue:-
May 03, 2011 | LG Washing Machines
How To Repair a Washing Machine That Won't Spin?
Instructions: 1)Open the lid and reposition the clothes. Close the lid and retry. The washer may not spin at all if the tub is unbalanced. 2)Examine the lid switch for wear. Replace a worn lid switch by first using a screwdriver to remove the top of the machine. Remove the cabinet holding the old switch in place by unscrewing the two console screws, tilting the console back, removing cabinet clips, and unlocking the lid switch block. Unscrew the mounting screws, and disconnect the ground wires before removing the old switch. Insert the new switch in it's place. 3)Look for excessive glazing or cracks on the sides of the belt. If these signs appear, remove the old belt by tipping the washing machine over on it's side, and unscrew the clamps securing the pump coupling with a screwdriver. Place the new belt over the transmission pulley, and then over the motor pulley's nearest edge, slowly turning the motor pulley to pull the belt around and into the pulley. 4)Replace the washer's motor by firmly grasping on the metal slip-on connectors holding the wires in place, allowing you to pull the connectors apart. Use a screwdriver to unscrew all of the screws holding the motor in place, and remove the old motor. Insert the new motor in its place. Secure the new motor to the machine with screws, and reconnect the motor's wiring harness. 5)Replace the washer's pump by removing the service panel on the back of the machine with a screwdriver and disconnecting the washing machine drain line and the rubber pump outlet hose. Remove the fasteners holding the pump to the bottom of the machine, along with the drive belt from the pulley below the pump. Replace the old pump with a new one, and reinstall the drive belt back on the pulley, reinsert the fasteners and reconnect the rubber pump inlet and discharge lines.
thank you and hope this helps
Feb 09, 2011 | LG WFT1071TP Top Load Washer
Top load washer does not spin or agitate
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump
removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (110.#######) and you'll see a list of major sub-components with diagrams and parts.
Two possibilities:
Newer model Whirlpool / Kenmore washers use a Lid Switch as a safety device. Unless the switch senses that the lid on the washer is closed, the washer will neither agitate nor spin.
Older models only used the switch during the spin cycle.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
This is a Whirlpool PDF on how these washers operate. It has a diagram on jumping the switch as well as a detailed section on how the transmission works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
It also has a troubleshooting guide.
To bypass the switch, you only have to disconnect the power to the washer, tilt the console back, unplug the switch and using an short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the washer back in.
Following is a description of how to gain access to the console and how to remove the cabinet if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=913ba652cd504fb162f87d892bcb427b
With the jumper in place, try to re-start the washer.
If it works, the Lid Switch is a relatively inexpensive part.
If the washer still doesn't work, check the motor coupler.
Kenmore / Whirlpool top load, direct drive washers use a "Motor Coupler" between the motor and transmission.
It's used as a fail safe device and consists of three parts.
Two of the parts are the same, plastic units with three prongs that fit on one of the motor output shafts and the other on the transmission input shaft. Between them is a rubber piece with six holes.
The power from the motor is transmitted through the rubber piece to the transmission.
The other shaft on the motor directly drives the pump.
If the motor coupler is broken, or worn, the motor may not be able to send full power to the transmission for agitating or
spinning.
See the following for how to remove the cabinet, pump, motor and motor mounting plate to inspect and replace the motor coupler.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=135
If the coupler looks damaged, it's a relatively easy fix.
Pry the plastic pieces from the motor and transmission. Some people use a claw hammer but I've found that using a small (6 inch) pry bar works well.
Carefully fit the plastic pieces over the motor and transmission shafts and press them in place (Use a 1/2" of larger socket to put pressure equally around the pieces.
Put the rubber piece on the transmission plastic piece.
Replace the motor mounting plate.
Carefully line up the plastic prongs on the motor based plastic piece to the three un-used holes in the rubber piece. If they don't line up right, the coupler could be damaged.
Mount the motor, don't forget the two screws, put the pump back on the motor and use its' clips.
Put the cabinet back on, don't forget to plug the lid switch back in and re-mount the console.
Jun 12, 2010 | Kenmore Washing Machines
Kenmore Elite 11020952992 Washing Machine won't spin or agitate.
LID SWITCH OR COUPLER:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.20952992&pathTaken=partSearch
Two possibilities:
The first thing to check is the Lid Switch.
If the motor coupler is broken, or worn, the motor may not be able to send full power to the transmission for agitating or spinning. The "clicking may be the plastic prongs hitting each other.
Apr 18, 2010 | Kenmore Washing Machines
My kenmore washer will not agitate or spin. it makes a noise when it is trying to agitate the clothes or in the spin cycle.
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Look in the section for the motor, pump gearcase and you'll see the Motor Coupler.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
If the motor Coupler is OK, I'd test the lid Switch:
Following is a description of how to release the console for access to the pins.
Mar 19, 2010 | Kenmore 24032\24036 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
395 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
