Question about Hitachi 26LD6600 26 in. HD-Ready LCD Television
Have sound but no
I have sound but no picture. the screen is lit.. does not respond to the remote
or buttons on tv. cannot turn off the set.
If I unplug the set for a few minutes it resolves the problem.
I am wondering how long this will solve the problem
Posted on Mar 14, 2008
  • 103 Answers
You most likely have a bad lcd panel drive board.We have seen on occasion the cable between the panel(top side) and the main circut board has come un-plugged.Hope this helps.
What can cause an LG 47LN5700-UH TV not to turn on or respond to the panel buttons or remote control?
TV in totally unresponsive in many if not all areas. Only thing they all have in common is the set's power supply. They are big culprits.
Check the board for burnt rsisitors, diodes, bulging capacitors.
Aug 21, 2015 | LG Televison & Video
Haier HLH406BB 40 in. LCD HDTV - tv will not turn on. is not responding to either panel or remote power buttons. red off input light is still lit.
hi sounds like a power supply fault could be capacitors, look for tech in your area good luck
regards
shaun
Jan 15, 2014 | Televison & Video
I have a universal remote systemlink 3 RCA. I need the code to program it. I have Goldstar TV. Thanks.
1.Use one of the following three digit codes for your TV set:
004, 005, 006, 012, 019, 056, 057, 058, 155, 156, 171, or 1722. Manually turn on the TV set.
3. Press and hold the CODE SEARCH button until the indicator light is lit. Then release the CODE SEARCH button. (The indicator light is located above the TV button).
4. Press and release the TV button. (The indicator light will blink and then remain lit).
5. Enter a three digit code found at step 1 using the Number Buttons.(After the code is entered the indicator light will turn off).
6. Aim the remote at your TV. set and press the OFF/ON button. If your TV. set turns off, then proceed to step 7. Otherwise, repeat step 3 to 5 using the next code on the list. Press CHAN up button to double check for accuracy of the code. the programming is complete if the TV set responds by going up a channel. Otherwise repeat steps 3 to 6 using the next code on the list.
7. Press CHAN up button to double check for accuracy of the code. the programming is complete if the TV set responds by going up a channel. Otherwise repeat steps 3 to 6 using the next code on the list.
8. If none of the codes work, you will want to use the following to go through the codes manually (this will take some time):
Code Search for the right TV code on a Universal Remote (systemlink 3 RCA)
1. Turn on the TV.
2. Press and hold the CODE SEARCH button until the indicator light lights. Then release the CODE SEARCH button.
3. Press and release TV button. The indicator light will blink once.
4. Repeatdly press and release the OFF/ON button until the TV turns off. It may be necessary to press the OFF/ON button up to 200 times before the TV turns off.
5. When the TV turns off, press the ENTER button. Now the Device is programmed for the TV set.
Aug 05, 2011 | RCA 3-dev Universal Remote Remote Control
My tv won't play my DVD player. I don't have the original remote, but it is programed to a universal remote. Whenever I press the "TV/VCR" button all kinds of numbers pop up on the screen and the tv...
Your TV is responding as if the Game button was pressed on the original remote. The additional stuff on the screen is to let you set the best brightness and other settings for video gaming. These screens should disappear on their own in 10 seconds if no buttons are pressed on the remote. See the manual http://www.symphonic.us/support/manuals.aspx and fill in the model number. If the remote were still controlling the TV, the CH up and down buttons would let you choose the Picture settings to change and volume up and down buttons would change the setting.
The TV/VCR button on the universal remote may be swapping the remote to control the VCR only. (Thus losing the ability to control the TV.) (What does the manual say about the button for the universal remote?) You may want to consider a different universal remote - programmable or http://www.remotes.com/remotes/servlet/rs?a=Search&o=c&uid=0&m=ST419E&uuid=12844254442790 which has an exact substitute.
Check your cables for the sound issue (try new ones) and make sure that they are fully seated in the jacks.
I hope this helps.
Sep 14, 2010 | Symphonic ST419E TV
WS-5551 only on/off button works, won't respond to remote at all
take off the speaker grill, you will see 2 wire plugs, turn the tv on, disconnect both plugs, if it now works with the remote then you need to replace all of the front switches, or leave them unplugged and use the remote, if this doesn't work, you have a bad dm board or signal module which could get very expensive.
Sep 15, 2009 | Mitsubishi WS-55511 55" Rear Projection...
No Picture, No Sound While Watching
Resetting the TV
If the buttons on the remote AND the buttons on the TV case do not work (channels do not change and you cannot open or navigate the menu), the TV has stopped responding. Reset the TV as follows:
NOTE:
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1. Unplug the TV power cord from the power outlet.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
LCD TV TroubleshootingThe defective LCD TV may have the following common symptoms:
Symptom: No picture on screen but LCD TV still has sound.
Solutions: The problem is cause by defective inverter. Replacing ivnerter will solve hte problem. Symptom: Screen flash on and off between 1/2 to a few seconds, but power indicate light stays on and TV still has sound.
Solutions: The problem is cause by defective inverter. Symptom: Blue Screen but no picture
Solutions: The problem is cause by defective Main Board(AD Board). In some cases, this problem may cause by the defective Screen Controller board. Thsi board is mounting on teh back of LCD TV Scree. Symptom: Power light stays on but no display and sound
Solutions: The problem is cause by defective Main Board(AD Board) or Power supply board. Symptom: No Power or Power indicate light does not lits
Solutions: The problem could cause either by defective Power supply board or defective Main Board(AD Board). Symptom: Screen is half dim and half bright
Solutions: The problem is cause by defective LCD Panel.It needs to be replace.
Hope it may help you;
Regards;
VOTIT
Jan 29, 2009 | RCA L37WD250 37 in. LCD HDTV
Polaroid Flat Panel TV FLM 373B
I had the same problem with mine, and figured out how to repair the control box. If you would like to have me perform a service on your set go to www.mikecampagna.com/Polaroid
Apr 13, 2008 | Televison & Video
Code
Orion Code is 035
The Instruction given is for programming a remote to control a TV set. Please substitute CABLE or VCR in place of TV to program for other devices.
1.Find the three digit code(s) for your TV set.
8. Try the code search method If there is no more code left to try.
Dec 16, 2007 | Televison & Video
Hitachi 26LD6600 26 in. HD-Ready LCD Television Logo
115 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
