Expert
- Posted on Mar 29, 2010
Re: Hard disc is corrupted
You can possibly restore your system by following these steps.
Step 1: Turn off the PlayStation 3 by holding the Power button on the front of the unit till the Power light is red.
Step 2:
Touch and hold the Power button, you will hear the first beep, meaning the PlayStation 3 is powering on.
- Continue to hold the Power button and after about 5 seconds, you will hear a second beep, indicating the video reset.
- Continue to hold the Power button and after about another 5 seconds you will hear a third beep and the system will power off (Power light is red).
Step 3:
- Touch and hold the Power button, you will hear the first beep, again for the PlayStation 3 to power on.
- Continue to hold the Power button and after about 5 seconds, you will hear a second beep for video reset.
- Continue to hold the Power button and after about another 5 seconds you will hear a quick double beep. At that point release the Power button. If you succeeded in activating Safe Mode, you will see a message on the screen saying, "Connect the controller using a USB cable and then press the PS button."
Connect a USB cable to the controller and the PlayStation 3 and press the PS button to enter Safe Mode.
Then you will see the Safe Mode menu.
This last step can possibly erase the data you have stored on your harddrive, so I recommend the options in this order...if one of them works stop and don't try the others, that way you may be able to retain your data.
- Restore Default Settings
- Restore File System
- Rebuild Database
- Restore PS3 System
