Question about Video Game Consoles & Games
Own Atari 2600. Atari not responding to television. (FUZZY SCREEN) One of three problems: 1. I AM NOT CONNECTING SYSTEM CORRECTLY TO TV. please instruct me how. parts i have are: Radio Shack RF Modulator ATARI PART # c016353 Adapter b/t power source (wall outlet) and ATARI console. 2. THE CONSOLE IS DEFECTIVE. how will I know? is there a visible "ON" light when plugged directly into wall? 3. NO CONNECTION DUE TO WRONG ADAPTER I thank you in advance for your expertise resolve to this frustration.
    Brigadier General:
  • 6,966 Answers
If you are using the Radio Shack RF Modulator, your TV must be set to either Channel 3 or 4. The RF OUT of the modulator should be connected to the ANT/CABLE IN of the TV using a short coaxial cable with the proper terminators/connectors. Most Radio Shack RF Modulators are directly plug to the wall outlet.
The Atari 2600 should be connected with the use of RCA to RCA cable to the RF Modulator. Yellow is normally Video and the White/Red is Audio. Chances are that the RF Modulator is Stereo but the Atari is Mono, you can use either the red or white. If memory serves me right, the Atari has already a built-in RF Modulator.
You can try connecting the Atari straight to the ANT/CABLE IN of the TV bypassing the Radio Shack.
This pages might be of further help to you;
Atari Power/AC Adapters;
Atari Replacement AC Adapter;
Some useful tips about the Atari 2600;
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Mar 14, 2008
  • Louie  Role
    Louie Role Mar 20, 2008
    Hi again,
    Any developments with your concern?
    Genius:
  • 1,226 Answers
Hello!
When powering the stuff there should be light indicated that there is a power on it. how ever if these not been observed, power adapter maybe busted. try to fix it or replace it. Please refer to the atari manual for the correct operation of your stuff.
hpe this help,
melnavz
Atari 2600, only get black and white, no color
Well i think that the rf switch might be causing the problem snowy tv scrren no colour or fuzzy tv screen then its the rf switch thats causing this type of a problem then. If using a digital tv you need to plug it into a VCR or a DVD player for it to work then.
Dec 14, 2011 | Atari 2600 Console
My son just got a atari 2600 console but it will not power up swap the 9 volt and still not power up
Well put it this way yes it a power system failure to fix this problem you basiclly will have to install a new mother board for the console from another atari 2600 console like from ebay. If you find a crappy atari 2600 console with a working motherboard you might just be able to switch it and I fix NES SNES N64 sega gamecube and atari 2600 consoles too. This has a high probility of not working if you don't know what to do or on how to fix it. 8 out of 10 it might not work after this.
Aug 21, 2011 | Atari 2600 Console
I have an Atari 2600-A What type of power cord do I need to connect game and TV?
an rf tv cable with phono at one end and TV aerial socket at the other. any old console one should fit and work such as the Sega systems
Apr 02, 2011 | Atari 2600 Console
Tried connecting direct to both an LCD and older set using the coaxial lead straight from the console.Cannot get anything at all.Do I need an rf modulator or no.
Quite the opposite - The Atari 2600 sends a modulated RF signal over the cable, it needs to go to the ANTENNA port of the TV, and you need an adapter. On eBay, look for
ATARI 2600 RF TV SHIELDED CABLE + ADAPTER
http://www.atariage.com/howto/connect.html is a really good guide.
Nov 26, 2010 | Atari 2600 Console
How on the atari 2600 does does the console connect with the tv?
Hi Atari 2600 console us a old style cable called an RF cable and connects to the TV arial inlet. see www.gameoz.com.au as they stock this cable and gear
Sep 22, 2010 | Atari 2600 Console
How do I overcome a fuzzy picture on my digital TV when using an atari 2600
Hi you might want to try using a higher quality RF cable see www.gameoz.com.au they stock some.
Sep 16, 2010 | Atari 2600 Console
Atari CX-2600 wont work
You have a video splitter connected? It is set to "game" or "computer," rather than TV. Is there snow on the screen? As if there is no video signal? Or, is there a blank screen (as if the power is on but no video).
There is a channel setting switch (channel 3 and 4, if I remember correctly). Make sure you have it on the same channel.
If you don't think the system is even coming on and if you know how to use a multimeter, see if you are getting voltage at the powerjack on the 2600. It should be 9 volts dc.
Hope this helps,
Bill
Apr 04, 2010 | Atari 2600 Console
Atari 2600 does not have picture when turned on.
I just got a Atari 2600 as well and can't get it to produce a picture. The transducer and the chips are getting warm when I turn it on, so I know it is getting power. I have tried to clean everything with rubbing alcohol but nothing has worked so far. I have also tried about 7 different games all do nothing.
Is there some part or component that commonly goes on these systems? I have a friend who also bought a 2600 and he is having the same problem.
May 27, 2009 | Atari 2600 Console
2600 atari
To connect your Atari to your TV, you'll need to get a "phono to f" adapter. These are available at RadioShack (part no. 278-255) for about $5.00 This adapter takes the phono plug from the Atari and changes it to a standard coaxial adapter. If your HD TV doesn't have an input for standard cable wires, you'll need to get yourself an RF modulator to switch the coax to RCA. If you have an old VCR with an unused cable input, that will work as well.
Mar 28, 2008 | Atari 2600 Console
Atari 2600 fuzzy screen
Hello, Are you using a newer flat panel or and older TV? IF you are using a newer TV the picture will never look very good. IF not, did you try working with the RF adapter? Check all connections. If all else fails try to get another RF adapter to see if that helps. I remember this being a bit problematic even when these were new. Wish I had a definite answer for you! Good Luck - Dr. Know
Dec 23, 2007 | Atari 2600 Console
Video Game Consoles & Games Logo
226 people viewed this question
Top Video Game Consoles & Games Experts
Marvin
Marvin
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
