Question about Sony VPL CS1 Multimedia Projector
Sony VPL-CS1 projector
Projector does not come on.
Lamp/cover and Fan/temp leds come on when on button is pressed.
  • 1 more comment
  • Clarence Rose Mar 28, 2008
    Dear Marrie,
    There is no visible damage to the lamp.Need help in checking the ballast. Test points and voltage levels.
    I do not have the circuit diagram
    Thanks for the help.
    Regards,
    Clarin
  • hotspotlight May 09, 2008
    Iam have the same thing happening the blub is good but when i plug in the power cable the 2 lights start blinking and projector never turns on.
  • ValpoSmitty Feb 05, 2009
    I am also experiencing this issue and would like to test in-houseto see if this can be repaired. I have two non-functioning and would like to combine working parts so at minimum I can get the remaining lamps in stock used up and get our full money's worth out of these portables.
    If there is a circuit diagram available that would be great.
  • 563 Answers
Hi there
You should first check if there is any visible damage on your lamp. If not then it could be a faulty Ballast ( lamp powersupply )
Posted on Mar 26, 2008
What could be the issue if my projector turns itself off after only running for 1-2 minutes?
It maybe a problem with your lamp as they can run for a short while then shut down.
When it shuts down do you get the lamp or temp indicator coming on?
Feb 01, 2013 | Sony VPL CS1 Multimedia Projector
Both the LAMP/COVER and FAN/TEMP indicator lights come on, not blinking
with both lights solid. according to the manual all it says is (there is an electrical failure inside the unit, please take to an authorized servicer). if you are able to do this yourself you will need the schematics and a voltmeter to start testing your voltages. your lamp is fine so dont waste your money replacing that anymore. if you would like the service manual send me an email to fixya@markservicepro.com.
Oct 30, 2007 | Sony VPL CS1 Multimedia Projector
My Sony VPL CS1 projector was working on Monday and is not working on Wednesday. Smells hot but fan is running. Light was on but now it is not on and the Lamp/Cover light is on.
hi,
check the lamp cover is it open or not. there is switch for sensing, is the lamp cover is open or not. may be it became faulty. also check the lamp is it burned or not . if found burned replace it.
ok
Dec 22, 2010 | Sony VPL CS1 Multimedia Projector
Press the power button to switch it on, the sony logo lights up and it switches on as per normal operation, it then switches off after a few seconds and the temp/fan light flashes
hi,
may be your projectors lamp colling fan have some problem. may be it is get jammed due to dust or it may be faulty. without fan the lamp will get over heated. that's why the temp/ fan lights flashes.
jus check it . need further help feel free to contact.
ok
Dec 20, 2010 | Sony Projector Lamp for VPL-HS51
Sony VPL-CX61 lamp/cover blink. Power on, it
hi,
your projectors lamp cover may be open. or there is some thing happened (may be contact problem) with the lamp cover open sensing switch. just open the door and close it. and then try again.
ok
Dec 20, 2010 | Sony VPL-CX61 LCD Projector
Hi I have a problem with my Sony VPL-CS4 LCD Projector. The problem is, when turning on AC the LED's: LAMP/COVER and TEMP/FAN turns on blinking, and consulting the torubleshooting section of the manual, it...
Attend to the issues. Lamp cover may mean the cover is not fitted correctly or the switch is faulty like wise the fan issue may mean no rotation so it will not start.
Nov 06, 2017 | Sony VPL CS4 Multimedia Projector
Sony svga vpl cs1 projector horizontal roll
first of all open the projector and clean it form a bursh then cheack a losing if stips and jumpers thats it
Apr 24, 2010 | Sony VPL CS1 Multimedia Projector
Hello with Sony VPL-CS1 projector in standby mode
overheated or lamp is past it's time. you may need to change the lamp, replace the lamp timer. while you're in there, clean it out.
Apr 18, 2009 | Office Equipment & Supplies
Sony VPL CS1 Multimedia Projector Logo
574 people viewed this question
Top Sony Office Equipment & Supplies Experts
shaun taylor
Jaime Hernandez
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
