How Do I Tune VCR to the TV
We have a Panasonic VCR model NV-MV20GL and I am having trouble tuning the VCR into the TV which is also Panasonic. All the cables are correctly fitted, the VCR obviuously works mechanically as it will fast forward, rewind tapes, etc both with the remote & pushing the buttons on the VCR itself but obviously with no picture coming through as following the instructions I cannot bring up the menu on the TV by pressing the menu button on the VCR remote controller to start the process of tuning the VCR to the TV. I am sure it will be an obviously simple solution to this problem but I'm dumbfounded at the moment & look forward to hearing what the simple solution is.
Cheers.
  • ypukguy Mar 14, 2008
    Thanks very much. That was most helpful. But don't worry, I'm sure we'll be back to you when we get our next peice of new technology even though this problem was somewhat old technology.
    Cheers.
  • Anonymous Apr 24, 2008
    I have a sumsung T.V and L.G. VCR I cannot seem to tune them into each other do I have the wrong cords plugged into each other ? I have tried putting the cords into different points but with no luck have spend most of the day trying please help
I have a panasonic analogue television, and I cannot tune in a Goodman VHS VCR to the television. I have no remote controller for the television, and use the buttons on the front of the set to change stations 1-5. I have however found AV on the television screen and the indication is that the VCR is trying to come through when switched on. I have got a remote controller with the VCR. Can you help me please ??
Posted on Dec 10, 2008
My bush vcr will not tune in to my bush tv
Posted on Oct 27, 2008
  • 667 Answers
You have have to use your input button on your tv remote until you get to your vcr. For instance some tvs will show on the screen component 1 for for cable, component 2 for your DVD player and so on so on depending on which jacks you have it plugged into.
Posted on Mar 14, 2008
How do you tune a Panasonic VCR model number NV-HD100 in please
You need to connect the RF ( cable or TV) to the input and connect the output to the TV. Now select the menu to auto scan the channels. The you can select timer to set the channels,time and date.
please find the link below for support.
http://www2.panasonic.com/consumer-electronics/support/Video/VCRs.75427
Apr 05, 2011 | Video Game Consoles & Games
He svhs outputs two vertical white lines on blue screen, what does this indicate please
It sounds like you are describing a test signal used to help tune the vcr to a TV. There should be a switch somewhere marked "test signal". Find it and switch it to off. It should go then. It could be on the back near the aerial connections.
Feb 04, 2011 | Panasonic NV-HS1000 S-VHS VCR
I have acquired a Panasonic NV-FJ620B-S Video Cassette Recorder which has 2 x scart sockets on the back. 1 marked AV2 DECODER/DECODEUR(EX) the other AV1 (TV). The AV1 scart connector works fine on the TV...
Have just visited the Panasonic UK website and the User Manual for the Panasonic NV-FJ620B-S is available free. It lists on page 11 all the details. I'll e-mail it you Tom to see if it helps.
Jan 25, 2011 | Panasonic NV-FJ620 VHS/S-VHS playback VCR
Panasonic vcr - audio working, no video
I think this sounds like the old test signal so you can tune in the RF on a TV. Have a look around the back see if you can see a test switch.
You can also look it up in the manual. If you have lost that you can download it free from the Panasonic website.
Feb 10, 2010 | Panasonic NV-HD680 VCR
I have just acquired a Panasonic NV-HV60 vcr without a remote control. How do I tune it to my tv please?
The simplest way is to get a universal one. If you need the user manual for the vcr you can get it free from the Panasonic website.
Nov 10, 2009 | Panasonic Televison & Video
Cannot Tune TV through VCR
I need model number and brand of your VCR and TV to suggest solution.
Thanks.
Jun 12, 2009 | Panasonic Televison & Video
Unable to tune the channels into the tv.
send me a picture of the front panel I will tell you how.
Apr 28, 2009 | Televison & Video
Panasonic NV SJ205 changing RF settings
Your VCR has input to record video-audio signal. Here is 2 options to record program in vcr.
1= You need to hook up video-audio cable at Monitor Out in TV and video-audio in at VCR. select Line-1 or Line-2 (where you hook up cable) in vcr and insert cassette with Record Tab intact, VCR is ready to record TV program. select desired channel on tv and hit record button of vcr, recording will start.
2= Plug RF antenna / cable wire in RF In of vcr and tune desired channel in vcr (get help of vcr's user manual for that) and push record button to start record directly in vcr.
Have further query, let me know please.
bye.
Sep 09, 2008 | Panasonic NV-SJ205 VHS VCR
Programming panasonic vcr
First, check in the VCR setup and see if it set for cable or off-air/broadcast/antenna (not always named the same).  If it is set for off-air... then it won't tune cable channels beyond 13.  It must be set for cable mode in order to tune those upper channels (mid-band, superband etc.).
I assume you have the VCR hooked up correctly- cable into VCR antenna/RF input, VCR RF/to TV output to the RF/Ant input of the TV.
Oct 15, 2007 | Panasonic AG-1980 S-VHS VCR
Televison & Video Logo
2,603 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
