Question about SanDisk Sansa e250 MP3 Player
Sandisk e250 won't turn on after i downloaded music
  • 8,596 Answers
If the player runs out of battery while transferring songs, you will get this sympton.
Go ahead and do this, in case the DB is corrupted:
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
Posted on Apr 08, 2008
5 Suggested Answers
6ya staff
SOURCE:
ThaMp3Doctor
Corey Knoettgen
  • 8596 Answers
SOURCE: sandisk
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on May 26, 2008
Anonymous
  • 31 Answers
SOURCE: Sansa e250
Make a copy of one of the files, and try changing the extension to .mp3.
Posted on May 30, 2008
YourZEN
YourZEN
  • 820 Answers
SOURCE: All music from SanDisk e250 disappeared and it's not working well
When the message "no songs" appears in the player, next Sandisk instructions might help you to restore the player:
http://kb.sandisk.com/app/answers/detail/a_id/3/kw/no%20songs/p/555%2C662%2C618%2C622/r_id/101834
If you don't have the music on the computer any more, be sure to make a backup first as told in this link.
All support for the e200 series players:
http://kb.sandisk.com/app/answers/detail/a_id/4487/session/L3NpZC9kRUQ0SVlaag%3D%3D/sno/0#e200
For more help just add a comment.
Posted on Apr 21, 2010
  • 102366 Answers
SOURCE: I don't no how to photos on My sandisk sansa e250
Use the supplied Sansa Media Converter program to convert and transfer your photos (and videos). If you don't have the SMC, you can download the Windows version from
http://www.megaupload.com/?d=3IPZO6Q0
Posted on Jan 28, 2011
I do not have any software on my computer anymore for my sandisk mp3 player. how can i redownload the necessary program (s) to be able to remove and download music to my device?
You do not need software to use the Sansa e250. You can simply plug it into your computer, and use it as a portable drive. You can drag your music files directly onto the player from your computers file explorer.
Hope this helps!
Mar 18, 2011 | SanDisk Sansa e250 MP3 Player
Trouble getting the software for my sansa sandisk c200 series mp3
I am also a user of SanDisk. They will not give any CD with it. Try using below steps to download the music.
1. Movies and Music should be in MP3 format.
2. Plugin SanDisk to Computer.
3. System will open new drive in "My Computer" name as Sansa e250 .
4. Copy music,movies and past it into Sansa Drive.
There is another good feature in SanDisk.
You can also record the song from FM Radio.
At the time of listining song from FM press Rec button. Song will get saved in your SanDisk.
Thanks,
Vaquar
Jan 04, 2009 | SanDisk Sansa e250 MP3 Player
Sansa e250
Apr 18, 2008 | SanDisk Sansa e250 MP3 Player
Please Help!
Please try to reset the device by holding the power button for about 15 to 20 seconds..that should reset the device...If that doesnt help go to the sandisk website to download the firmware application...
Mar 19, 2008 | SanDisk Sansa e250 MP3 Player
Can't download music onto my Sansa e250
If you have more than one USB port try another port. If not try downloading Yahoo! Music Jukebox.
Dec 27, 2007 | SanDisk Sansa e250 MP3 Player
Downloading music
how do you download music onto a sansa sandisk?? I tried using itunes but it wouldnt work.
Dec 23, 2007 | SanDisk Sansa e250 MP3 Player
Problem downloading music
You must convert to mp3 or acquire a DRM license
Nov 20, 2007 | SanDisk Sansa e250 MP3 Player
Problem with deleting music
It might have reformatted the songs by accident. Just try to redounload the songs you want and dont download the ones that you wanted to delete in the first place. This happens a lot with Sandisk e250 mP3 players
Jan 02, 2007 | SanDisk Sansa e130 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Ekse
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
