60hz to 120hz
Any way to get the clarity of a 60hz samsung like in a 120hz ssamsung, or boost it somehow...?
  • 504 Answers
If you are asking if there is a way to make a 60hz tv a 120hz tv, no, there is no way to do that. The clarity is mostly dependent on the signal and the TV. For instance, if you have a 1080P television and are getting a 1080P signal (from a Blu-Ray player or HD DVD), then you should be getting a very clear picture. It will be a little smoother if the TV's refresh rate is 120hz or 4ms as opposed to the standard 60hz or 8ms. If you have a high-def satellite or cable box, you should get 1080i if the channel is broadcasting that way, but you cannot make the TV do something it was not designed to do.
Posted on Mar 14, 2008
I've recently ordered a Proscan PLED5529A 55" 1080p 120Hz LED HDTV, However, a Proscan PLED5529A-B 55" 1080p 120Hz LED HDTV was sent. What is the difference? One difference i've noticed in the...
Same issue here. I'm debating to send it back as most specs are pointing to the A-B model as being 60Hz. I can't really tell of it's pushing 120 or 60 (ignoring the fact that the screen says 60Hz.) It almost "feels" like it's 120 but can't say for sure. Can anyone please confirm that the "A-B" version is indeed 120 or not? Thanks!
Mar 02, 2013 | Proscan Televison & Video
How do you chang from 60hz to 120hx fefresh rate
THe only alternative is buying a transformer by 60HZ vs 120hz,
OR you can go some repair motor shop and reconvert the transformer by the frequency that you need.
sincerely.
ERNESTO CUADRA
Dec 15, 2011 | Samsung HL Televison & Video
I cannot get the samsung un40c6400 to run in 120 hz. It will only show in 60hz.
It doesn't support 120hz refresh rate, what signal are you feeding into it that has 120hz?
Feb 15, 2011 | Televison & Video
I have a samsung 6 series led tv which says it plays at 100hz, however on screen it only ever says its playing at 50Hz. How do i get it to run at 100Hz?
120 hz and 60 hz any ways heres the thing it is running in a 120hz but its always going to say 60hz because its not a true 120hz your tv is upscaling it to 120hz its called auto motion plus you can adjust it under settings but it will always say 60 hz never 120hz cause it dosent do it true you can call samsung or read the forums at cnet.com i have the same t.v. just the 46 in samsung and sony are very shady in the way they word things
Jan 06, 2011 | Televison & Video
Avol ALT42FD120 - frame rate change 60-120hz?
Hi. It is entirely possible that the set is already running at 120Hz after all. The display 1080p 60Hz is merely the signal it is receiving and the earlier TV's that used to claim 100Hz/120Hz merely did so using line doubling only to give a clearer picture by filling in the blanks between scanlines. If your picture is already very clear, then I wouldn't worry about it
Mar 21, 2010 | Samsung 52 in. Flat-Panel LCD HDTV
Display says 60hz always
Ignore it. That rate (60hz) is what the cable provider is refreshing at as the signal is sent to the box, but the TV will then refresh at 120hz. I know that the manual does not state this, but the TV is working correctly. Go to the "menu" and "picture" and set it accordingly.
Aug 02, 2009 | Samsung LN55B650 55 in. LCD HDTV
Game plays in 1920/1080p **60Hz**. i have a LED 120Hz TV.
the tv only gives out as much as it can, you cant improve it, srry
Jun 11, 2009 | Sony Playstation 3 (PS3) Console
DOES PLASMA TV HAS 120HZ AUTO MOTION PLUS
This particular model has a 60Hz refresh rate. At this point there are no broadcasts or video sources outside of special labs that can generate enough data to produce a refresh rate of 120Hz. Expect this to become available in a year or so. Please realize that the human eye can not see changes faster than about 30 frames per second. The current standard refresh rate of 60Hz is twice that. The only change you could see (unlikely) would be a slightly smoother flow for fast moving scenes. Typical movement on the screen will not likely see a difference.
Dan
Mar 16, 2009 | Samsung PN50A650 49.96 in. Plasma HDTV
Hi i just a new samsung 40" 630 kcd tv. i was wonderingi s it possible to make it work at 1080P 120Hz right now it shows as 1080i at 60hz. I have a Verizon HD box
hi just to let you know the samsung 630 is a great tv i like it alot so im gonna try to tell as much as i can right now nothing is playing in 1080p so you will not have to worry about that but when it does start to you will be ready your tv is running at 60hz what the 120hz does is just add extra frame you really wont see the difference only when you watching blue-ray
Jan 10, 2009 | Televison & Video
Televison & Video Logo
111 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
