Diamond TV I have a Diamond TV, and each time it is turned on I get a horizontal line across the screen approx 1/3 from the top. It does not subside. The tV is approx 6 years old.
  • Anonymous Mar 14, 2008
    Thank you so much for your advice. We will give it ago.
    Kind Regards
    Scholar:
  • 60 Answers
The vertical height driver that controls the height of your picture has weakened and needs to be adjusted. If you are somewhat handy you can do this yourself. It requires that you gain access to back of the set & remove the cover. Once removed, locate the vertical height & centering adjustments. Sometimes they are located on the main board & other times are located on the color gun driver circuit board that is plugged into the end of the picture tube.
Respond to this post if you need additional assistance. Good luck!
Posted on Mar 14, 2008
SOURCE:
Have horizontal lines across the screen and some
Yeah we have the same exact problem here. Defective TV....ours would correct itself after 30 mins, but now it's blurry all the time. I'm never dropping 2K on a SONY tv again.
Aug 01, 2010 | Sony Bravia KDL-46VL130 TV
Tv screen is black except for 1 horizontal line of color
The line is there because the vertical deflection unit - the one that spreads that line across the entire screen to form the image - has failed. Replacing it is a job for a professional, or at least an experienced amateur, and the parts will be quite difficult to find for such an old tv .
May 28, 2010 | Panasonic CT-36DV60 36" TV
Have Panasonic TH-50PX60U HD Plasma. Purchased
Filter capacitors (more than 1) in the main power supply
May 02, 2017 | Panasonic TH-50PX500U 50 in. Plasma...
Permanent horizontal line approx. 4" from top of screen
if this line is in the picture, that is possible burn in screen. if you have a black bar at the top or faint white lines that come down from top this is caused by defective filters in vertical circuit or bad vertical output. mch
Feb 20, 2009 | LG 50PC3D 50 in. Plasma Television
Hoizontal Bar across RCA Model 24F501TDV Color TV
you may need to change your resolution on tv settings as well as cable or satelite settings if you have one of those
Dec 12, 2008 | RCA 24F501TDV 24" TV
Horizontal white lines across top of TV screen
Hi I had the same problem. Broken white lines across the top of the screen. This is called overscan. You need to go into the Setup menu, other settings. 16:9 overscan needs to be on. Hope this helps.It solved our problem.
Sep 15, 2008 | Panasonic CT-2006S 20" TV
Philps TV problem
When I turn the TV on, I get a horizontal line across the screen approx 1/3 from the top. My TV make is Diamond and is approx 6 yrs old
Mar 14, 2008 | Philips Magnavox 27MS343S 27" TV
Horizontal 'pinstripe' lines on all channels
sound like the screen control on the flyback is set just a little too high. the flyback has the red wire attached to the tube. the flyback has 2 small adjustable controls. if you look close enough 1 is marked focus & on is screen. turn the screen slightly to the left & look at your picture. the screen is like a master brightness & if it's up too high you will see what is called retrace lines. good luck.
Jan 16, 2007 | Daewoo DTQ-20N3FC 20" TV
Televison & Video Logo
128 people viewed this question
Top Televison & Video Experts
Ekse
