Back to:
Tags:
Datalogic Gryphon M100 Handheld
Not reading anymore
posted by nomad49 on Mar 14, 2008
the scanner beeebs, but no longer communicated with the computer when scanning a code. Any advise mosrt welcome, Marcel
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Sep 24, 2008
Not Rated (0)
Eiggus
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
I've just had the same problem at my college. Check that the cable is plugged into the keyboard ps2 rather than the mouse ps2.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on not reading anymore:
I don't want to Accept this solution
Solution #2
posted on Sep 03, 2008
Not Rated (0)
Guest
Rating: 0%, 0 votes
The only thing I can assume is the problem is is that the COM ports have become mixed up. I believe the scanner needs to use COM3 and it could be that this may be being used by another device. We had this problem a while back and no matter how many times we re-added the device it would take a COM port higher than 4 or 5 and not any lower. If you can reset all the COM ports and re-add the scanner device then that should work.
Thank You!
Can you Help with these Barcode Scanners problems?
Barcode Scanners
i have a dymo turbo 300 thermal printer and i want to...
Barcode Scanners
I have loaded the Flat PLU keys easily enough, however now...
Barcode Scanners
hellow . how i can use the scanner of canon mp 140...
Barcode Scanners
How can I run my HP ScanJet 2200C on vista need help...
Our M100 works fine for the tracking numbers for DHL and...
Loading problems.
Repair Service
Find Barcode Scanner Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
