Question about Midland 75-822 40-Channels Handheld CB Radio
75-822 cb that has extremely low audio output
HI, I've got a 75-822 cb that has extremely low audio output from the speaker in both wx and cb mode.
It is barely audible until the volume is turned to at least 3/4 volume, you have to turn it to max volume to understand anything. the radio seems to transmit and receive fine (people can hear me, and I can hear them, thought the audio output is very low)
  • ShminkyBoy Mar 15, 2008
    Thanks for replying - I don't think it is the speaker, as the volume coming from the external is also very low. I don't know if the info helps, but, neither internal or external speaker distort at max volume, it's just not loud.
    Is there a way to increase the gain coming from the audio amplifier circuit on these?
    I've found some schematics here: http://service.alan-germany.de/CB/ALAN42...
    And I've also found a block diagram here: http://members.tripod.com/~Malzev/cb-fun...
    (I learned that the alan-42 radio is really an export 75-822 that's branded with the Alan name. the internals are identical otherwise)
    Since I'm unsure of how to proceed and what to modify to get what I want, I haven't actually changed anything yet.
    On a related note, What is the proper way to increase AM modulation on these? I've been told by other operators that my modulation is also low when I transmit.. I don't want to just go changing things around without knowing what "too much" is or how to measure it...
    Thanks again
  • ShminkyBoy Mar 25, 2008
    I guess I wasn't supposed to rate answers that didn't really help.. oh well, I ended up returning the unit for a refund. Thanks for trying anyways
  • 46 Answers
Hello..if you can try to connect a external speaker or phones..if the volume is ok..than i think it is time to replace your internal speaker..pse tll me....good luck...Ron
Posted on Mar 15, 2008
Hi, I have a Uniden CB UH013, All works OK other then very low volume when receiving. Checked all connections and internal and external speakers are low volume. People receive quite clearly. The radio was...
There is a small capacitor that drops value next to the audio output ic, usually heat sinked to the inner chassis, " ic should be checked" for hairline crack and performance, to answer your question it can be repaired.
Apr 29, 2012 | Uniden Radio Communications
There isn't enough audio, how can I turn it up?
install a computer "Amplified" speaker to EXT SPKR. The computer speakers run off 12 volts. Most do--then crank it up loud as you want. If output is not loud...go to Defcom radio mods.
Apr 11, 2011 | Cobra 18 WX ST II 40-Channels Base CB...
The volume is barely audible even with it turned all the way up. I have tried different audio cables. It occurs in different modes also, CD Tuner, etc.
Maybe you have it muted or a Tape Monitor engaged??? Never troubleshoot anything at high volume. If you can't hear it at medium it's effectively noth there. A flip of a misplaced switch would possibly blow your speakers.
Jan 16, 2011 | Optimus STA-3500 Receiver
Low volume output from radio. appears to transmit and receive properly
Hi, my name is John. Welcome to FixYa. Turn your volume up to MAX, then turn your RF GAIN to MAX. If same, plug in a external speaker in back of radio into the external speaker jack. see what happens. If loud, re-place the speaker in the radio. Let me know how it goes, glad to help you and thanks for choosing FixYa....John
Oct 31, 2010 | Cobra 29 WX NW ST 40-Channels Base CB...
Re Sony VAIO F12 (new unit): Audio is barely audible using onboard and external speakers, even though volume bar indicates volume is at highest level. Any way to increase audio volume? Thanks.
1. Yes, check to see if you have the volume up for the wave file turned up that is on the program you are using to listen to the Mp3 or sound wave with.
2. check the speaker connector/ Use another speaker that is know to be good and test. Use a set of earphone in the output jack also to test the output.
If these things are doing the same then you have failing sound card and it needs replacement.
Aug 10, 2010 | Sony VAIO FR130 Notebook
Low volume on my HP Pavilion dv6-1245
Open the audio panel (settings -> control panel -> Sounds and audio devices -> volume). Check that the volume slide is all the way to the right. Also, click on the "speaker volume" button and check it is all the way to the right
Mar 21, 2010 | HP Pavilion dv6000z Notebook
Internal wiring schematic for a JBL 4311 WX-A
the conductor xxx\blk is the minus or black( from speaker) the outher is positive\red pin from speaker) the woofer is bigest speaker inside is connected on the crossover at low output, tweeter at high output, if you connect wrong you can burn speakers and crossover, you can test with very low volume on amplifier.
1st connect low to woofer, it only her low freq below 500Hz like drums and bass, if connect on med out the speaker is working as handpocket old radio audio. if connect on high the speaker is like no audio out. (the woofer take about 60-75% of amp power).
2nd connect the midrange at mid output you can listen to human voice cristal clear. if connect on high output you listem like esteric female shouting.
And connect the tweeter at the empty output
Take particular attention on polarity terminals, if you exchange the polarity you have a moofle sound traped inside of speaker, and some structered box noise who may open the box panels in future.
Feb 16, 2010 | Audio Players & Recorders
Cobra 75 wx st
Hi and welcome to FixYa,
Initially, pls a couple of ideas you may want to consider/explore or try/check:
  • PA/CB switch must be to CB;
  • RF Gain max clockwise;
  • Squelch counter clockwise;
  • Volume to your desired level;
  • Mute (off);
  • external speaker/speaker connection;
  • audio amp, verify if there is TX modulation;
  • antenna, antenna cable. SWR should be low.
Good luck and Thank you for using FixYa. Happy New Year.
Pls be informed that due to my current rank and rating, even a Helpful would be detrimental to my status. Should this solution not address your concern, it would be appreciated if you could just not rate this at all. Cheers.
Jan 01, 2009 | Cobra 75 WX ST 40-Channels Handheld CB...
Low volume and problems with squelch
Check your speaker for a short.
Jul 06, 2008 | Cobra 29 LTD CB Radio
ASUS P5B-MX MoBo Very low sound output.
inthe realteck sound system there u need to adjust the settings in the software set the settings to 2 channel
Oct 24, 2007 | Gigabyte GA-945GM-S2 Motherboard
Midland 75-822 40-Channels Handheld CB Radio Logo
1,130 people viewed this question
Top Midland Radio Communications Experts
Steve
eradiostore
eradiostore
Are you a Midland Radio Communication Expert? Answer questions, earn points and help others
