Question about HP PSC 950 All-In-One InkJet Printer
Printing works but the scanner wont work with windows xp
Ever since I upgraaded to windows xp, only the print and fax features work. I can not can, nor can I find the printer on my desktop or anywhere when I search for it. ( I would like the printer to appear on the desktop because it has features to keep on top of ink, pick out your photos from your photo card, ect.)
Can anyone help ?
  • Anonymous Dec 04, 2008
    i cant scan or fax from hp 950, why? i can print without any problem..
    President:
  • 2,351 Answers
Download & save the HP950 software to your PC. Run the program. After the install you should have your icons back on your desktop & down by the clock as well.
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=228&lc=en&cc=us&dlc=en&product=60259&lang=en
Please download & install the (HP Imaging Software Critical Update) too.
Posted on Mar 14, 2008
  • Mike Peluso
    Mike Peluso Mar 14, 2008
    & Please vote.........
Scanner & Printer Features are missing in the system setting.
Print scan card not in unit? ( a SD card on left rear under a cover)
Feb 05, 2014 | Ricoh Aficio Mp171spf Copier,Fax,Net...
I can't found any scanner driver.....i can print but scann....it's impossible SCX-4300
What OS are you running? I don't see any full-feature software but the Samsung site lists a print driver, a scan driver, a universal print driver and a universal scan driver for Windows 2000 through Win7 x64. Similar drivers are also available for the Mac OSX. I'm not certain of the features in the "unified driver" for Linux. The full-feature software is available for Windows.
To find these drivers, go to http://www.samsung.com/ph/consumer/monitor-peripherals-printer/printer-multifunction/mono-multifunction/SCX-4300/XSS/index.idx?pagetype=prd_detail&tab=support . Click on the Downloads tab and then select Driver. The windows files are all .exe files.
For the SmartThru software go to the above link and select Software instead of Driver. With this software, you will be able to launch a scan from the printer if the monitoring program is running. You should be able to start a scan from the computer with any OS and the Samsung drivers.
Windows XP, Vista and 7 can all acquire scans with Windows software. You can use Paint in all three (File > Import from Camera or Scanner > New Scan). Vista and Win7 add Windows Fax and Scan (New Scan). Vista came with Photogallery and it acquires scans like Paint. (You can download it for XP or Win7.) The Mac also can acquire scans with included software.
One issue that can cause a scanner problem is a bad cable. Scanning requires bidirectional communication with the printer and thus may fail when the printer works. Replace the data cable and make sure to use a direct connection (no USB hub or print server) if you can launch the scan but then it stops.
I hope this helps.
May 15, 2011 | Samsung SCX-4300 Monochrome Laser...
Trying to get the fax to pc feature working with HP LaserJet 3050. It was working fine on Windows XP x86 but now I'm using Windows 7 x64 & the software that came with the printer will not work. I've...
HP does not make a toolbox software for Windows 7 64 bit. The stance they seem to be taking is that the unit is 3 years old, tough luck, buy a new machine or settle for printing only.
Feb 02, 2011 | HP LaserJet 3050 Printer
Epson problem
Here is the download page
http://www.epson.co.uk/Store/Scanners/Epson-Perfection-4490-Photo/Drivers-Support?supportLandingPage=true
To scan to PC you need to use a prog with twain support the basic one in XP is paint.(start/all progs /accessories/paint/file/from scanner or camera) the scan appears huge but that's just the way paint does it save and open with another prog for printing (eg windows fax and picture viewer) and it wil be printed normal size.
When installing drivers do not connect scanner until told to do so by the install prog.
Sep 16, 2009 | Epson Perfection 4490 Photo Scanner...
Scanner
Try updating the drivers. Take this link to Hp and either enter model number and then operating system or let Hp detect your hardware and select drivers.
http://www.hp.com/#Support
Aug 27, 2009 | HP PSC 1315 All-In-One InkJet Printer
I CAN`T SEND A FAX
Fax machines are sorta like printers, sorta like scanners, and sorta like dial up modems all wrapped into one expensive box.
1. First thing to make sure of is that you are hooked to a phone line. most fax machines have a phone handset that you can make calls from. Call someone and make sure that works. If So, you are able to connect to phone networks, and should have no trouble sending or receiving data. If you have a dead line or no sound, check the line and check the power. (its always the easy stuff that is overlooked, just check it and make sure).
2. If this fax machine has computer interface, (usb port or parallel cable port), see if you can scan with it. Drop a document into the scan area and see if the computer can scan an image from the scanner. If the scanner works, you can scan images into the fax machine to be sent to the fax number. (If your fax machine does not have a scan to computer feature, skip this.)
3. if your fax machine has a print from pc feature, try to print a document to it from your computer. If you can print, then the printer works, and you can receive faxes. (if your fax machine does not have a pc printing feature, skip this)
4. Here is how a typical fax machine works. You place the document or image into the scanner feed area. You press a big button that usually says "fax" and then, a screen pops up saying to dial the number. You dial the number and press SEND. once you press Send, the machine will scan the document, dial the number and sing a little dial up modem song awaiting a response from the receiving machine. the receiving machine acknowledges the fax, and the singing is no longer audible (but it continues because the modem song is actually data transmission/reception). after about 20-60 seconds, the fax completes and the call ends. As for the particular model you have, the functions should be about the same, though the buttons and arrangements may be different. FYI, you can send a fax straight from the PC too, if you have a dial-up fax/modem card.
Jul 03, 2009 | Brother Multi-Function Center MFC-665CW...
HP Printer
Try this :-
Installing the printer driver in Windows Vista
Verify that the printer is turned on.
Connect the Universal Serial Bus (USB) cable to the printer and to the computer.
A Your devices are ready to use window might display on the screen. If the window displays and does not close automatically, close the window.
Print a test page to verify that the printer is working correctly.
Using the basic printer functions
Printing: - Open the document to be printed in the software application in which it was created.
Click File and then click Print.
Scanning: - Scanning with Windows Photo Gallery
Click the Start (c5af1ed.gif) icon.
Click All Programs.
Click Windows Photo Gallery.
Click File and then click Import from Scanner or Camera.
Click Import.
Click Scan.
Scanning with Windows Fax and Scanning
(NOTE: This feature works only with Windows Vista Ultimate, Windows Vista Business, and Windows Vista Enterprise)
Click the Start (9c4e39e.gif) icon.
Click All Programs.
Click Windows Fax and Scanning.
Click New Scan.
Click File and then click Scan.
Scanning with Paint
Click the Start (b95b750.gif) icon.
Click All Programs.
Click Accessories.
Click Paint.
Click File and then click From Scanner or Camera.
Click Scan.
Importing and viewing images on a memory card
Remove the memory card and then re-insert the memory card into the appropriate memory card slot on the printer.
(NOTE: See the User Guide that came with the printer for more information on how to insert the memory card in the printer)
On the Auto play screen that displays, click Import Pictures, View Pictures, or Open folder to view files.
Follow the instructions that display on the screen.
Using the advanced printer functions
(You might find that some of the advanced features are no longer available when using this basic driver. You can upgrade to an HP product that is fully compatible with Windows Vista if the advanced features are necessary.
To help you decide what product to upgrade to, click here for information on upgrading the product go to this link or copy and paste it into Browser :-
http://h30216.www3.hp.com/ASA/Controller?adi_hasScript=1&_AD_195R22=110&adi_scriptSID=DF57657645AF158516628FE76C76392C&sysid=84&appid=10251&_ad_stoken=sup&jumpid=re_r10602_advisors/adi/sd
Jul 22, 2008 | HP DeskJet 3940 InkJet Photo Printer
How to get scanner working
Windows XP
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=228&lc=en&cc=us&dlc=en&product=1128297&lang=en
Click on:
HP Photosmart Software and Drivers: USB Support
Windows Vista
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=2093&lc=en&cc=us&dlc=en&product=1128297&lang=en
Click on:
HP Full Feature Software and Drivers
On the next page, scroll down to "download only"
Click on the button.
In order to get the scanner drivers you need the large package install from www.hp.com. Above are the links for windows xp and windows vista scanner software.
Feb 13, 2008 | HP Deskjet F340 All-In-One Printer
Scanner
Download and install full software and driver package for your machine from brothers web site, it sounds like you have installed the print drivers but not the scanning software.
Oct 27, 2007 | Brother MFC-5440CN All-In-One InkJet...
HP PSC 950 All-In-One InkJet Printer Logo
65 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
