Question about Brother DCP 115C All-In-One InkJet Printer
Sir my Black Ink cartridge is filled,but not functioning into my printer DCP-115C...pls help.....what do i do.
  • 2 more comments
  • leighry Mar 28, 2008
    The printer says there is no cartridge in in, but there is and they are all full. I have tried to activate the cleaning but it just tells me there is no cartridge. It has been working fine and there is plenty of ink but...it suddenly comes up with this.
  • Anonymous Mar 30, 2008
    samw here....
    Black is full, printersays it is all ok, i hev cleaned it 10 times, no trace of any black on the test-print
  • Vincent Tan
    Vincent Tan Jun 10, 2008
    YAH, DS S MY FIRST PROBLEM TO POST IM A COMP.TECH AND INK REFILLING TECHNICIAN. BUT, I HAVE SOME PROBLEM WITH BROTHER PRINTERS. COZ DS S OUR NEW BRAND THAT WE CARRY. HOPE U CAN HELP ME. SOON I CAN SHARE MY IDEAS HERE IN UR NICE WEBSITE. MY PROBS IS THE CARTRIDGE IS FILLED ALREADY LC47BLK, BUT THE PRINT IS TOO BLURRY. I ALREADY CLEANED 20 TIMES BUT NOTHINGS HAPPEN. PRINT BLURRY AGAIN
  • Anonymous Jun 17, 2008
    tried cleaning,also put tape over bottom and pierced new hole.ink is comming out onto printer
  • 3 Answers
Unfortunately the DCP series are part of Brothers new POS technology range.
These often suffer two common problems.
1. Alignment issues.
The work a round is to turn off BiDirectional Printing.
2. The ink sensors fail.
The work around is to put tape over the bump in the ink cartridge.
This makes the printer think the cartridge is always full.
Be careful though not to let them run dry or you might clog the system or head.
Note: both issues can be repaired by a service center. But is this cheap unit really worth the cost? :(
SiliconJaguar
Posted on Jun 11, 2008
  • vk4akp Jun 11, 2008
    OH, Forgot to mention there is a calibration feature in the printers console. Try running it a number of times as it seems to have a cumulative effect. But if this fails, just turn off bi-directional printing.
    SiliconJaguar
Hi there, how do you re-calibrate the machine?
Thanks
Posted on May 31, 2008
My YELLOW Ink cartridge is filled,but not functioning into my printer DCP-115C...pls help.....what do i do.
Posted on Mar 24, 2008
    Genius:
  • 3,587 Answers
Clean and re calibrate it
Posted on Mar 15, 2008
2 Suggested Answers
SOURCE:
Mix-it-up
  • 832 Answers
SOURCE: YuP
Do you use generic ink? If so use original brother ink due to diffrent chemical consistence.
Insert new orig. cart. make sure all carts are at full level:
press menu then start b/w copy then fourtimes arrow up.
machine will switch to maintenance mode ("!" will flash).
Use the arrow-up key to go to the digit and the set key to enter it:
press 7 then 6 then 4 then start b/w copy
machine will initiate the carts and do some power cleaning.
When ready press
7 then 6 then 3 then start b/w copy.
machine will run a power purge.
Press 9 then 9 to leave then maintenace mode.
Do run a test print.
If you still have absolutely no BK the head is clogged and needs relacing.
If you have some bk wait a day and repeat the power purge sequence twice.
If there is no effect ph needs replacement, too.
Posted on Mar 14, 2008
Just changed brand new black ink cartridge but printout for black is very faint even though the best print quality is chosen. All other coloured ink cartridges are more than half filled. Pls help.
You got it! Just take out the ink cartridges and take a cotton ball and dabble a small amount of alcohol on the ink outlets, then place back in and print right away, it is more than likely tha the port is dry. Please let me know if I can help further, a pleasure to help out! Guy
Sep 29, 2010 | Brother DCP 115C All-In-One InkJet Printer
Hi, my Brother DCP-115C Brother printer keeps telling me my black ink is empty despite putting brand new cartridges in, can you offer any help. Thanks.
Black electrical tape is the answer and it’s because the tape is BLACK. Even if u put black tape on an empty cartage the printer will still try to print.
The tape goes on the side of the cartage that faces the back of the printer (where the sensor must be).
Dec 11, 2008 | Brother DCP 115C All-In-One InkJet Printer
Brother 115C printer says no ink when plenty.
i bought new inks and inserted them , when in fact its only the yellow inks is empty yet it sends me message that found no cartridges.. waah. this printer been with me for 8 years and had it clean last year only.. what to do?
Jul 09, 2008 | Brother DCP 115C All-In-One InkJet Printer
YuP
When ready press
Mar 14, 2008 | Brother DCP 115C All-In-One InkJet Printer
Helo Sir
we'll see if this one comes back around, shall we?
Mar 13, 2008 | Brother DCP 115C All-In-One InkJet Printer
Brother DCP-115C
good chance....Print head is blocked very common, what sort of inks were used?
 Not economical to repair, buy new!
Oct 19, 2007 | Brother DCP 115C All-In-One InkJet Printer
Brother dcp 115c
Seems to be a problem of your cartassy. The foil is damaged. The ink is inside the printer! So be careful. Try to open dcp: http://www.hstt.net/refill-faq/inside.html#Brother_mfc215c Use pictures how to open cover. After that try this: http://www.fixya.com/support/t184082-brothers_mfc_210c_ink_tray_needed_pin
Sep 04, 2007 | Brother DCP 115C All-In-One InkJet Printer
Brother DCP 115C All-In-One InkJet Printer Logo
467 people viewed this question
James Cagle
James Cagle
Jim Keysor
ctnozil
