Question about Dometic Rooftop RV Air Conditioner
ROOF AC UNIT ISSUES
I have a Dometic duotherm unit on a 2005 motorhome - actually 2 units with dual zones. The problem started last year with the rear unit icing up and having some issues with not turning on and off at appropriate times based on the temp. I relocated the sensors from the factory locations and that got better, I also figured out that if I let the air flow from the ducting rather than from the main unit it didn't ice up and drip as much. Although I didn't get it checked out last year like I should have, I am having more problems this year but with the heat pump & furnace side.
The problem is that the rear unit is triping the breaker and running very hot, the air coming out of the roof unit is as hot if not hotter on heatpump setting than it is on furnace setting. In addition, even though the front unit is set on HP the furnace comes on sometimes instead, the outside air temp. is well above the level that would cause the furnace to activate normally. I have cleaned the air filters with no improvement. Any advice would be appreciated.
Dave
    New Friend:
Sorry I'm not familiar with this brand. I recently acquired an RV from a real estate deal. My sellers couldn't take it with them to Montana so they sold it to me for $500 when they're house sold. I'm excited to get it running. It's supposed to have a fairly new AC unit but the engine isn't running. Good luck with yours. http://www.canyonrvrepair.com/Auto-Services-Auto-Repairs-Hemet-CA.html
Posted on Sep 16, 2014
You should check with Dometic or your manufacturer we are told that there was a recall on the Dometic Air Conditioners, although we never received a recall notice. Our Dometic Air Conditioner caught on fire burned up on our RV.
Posted on Apr 09, 2008
    Sergeant:
  • 288 Answers
Ice on the coil is caused by 3 things; 1, low freon charge. 2, inadequate air flow across the coil, this can be a filter or dirty coil (I think you addressed these) or the fan isn't blowing enough air over the coil. 3, the unit is running continuously. A heat pump has another cause, that is something defective in the defrost system, like the sensor, reversing valve, control board or relay. If the breaker is tripping its because the compressor is over amping. There can be an obstruction blocking the fan or something like #2. Or the compressor is going out. If the breaker doesn't trip on other settings, like cool, but trips on heat, then I would look at the airflow.
Posted on Mar 14, 2008
I have a Dometic DuoTherm ac/furnace unit in an rv. The thermostat got knocked off the wall and now the ac nor the furnace will work. Fan works in manual position only. What could be wrong?
When the thermostat was knocked off it may have damaged the wiring. I would start by checking continuity of all wires from thermostat to unit.
Feb 15, 2015 | Dometic Rooftop RV Air Conditioner
When you turn on the rear ac it sounds like it humms and then trips the breaker. Any ideas? Thanks, John
it could be the capacitor gone bad. without it the compressor can draw lock rotor amps.
Aug 02, 2014 | Coleman Dometic Duotherm Rv Air...
On 1994 southwind motorhome rear ac unit clicks but fan doesnt blow but it lights up as unit is on
Check in your unit for a switch on side wall or near ceiling for selecting which AC unit gets power. Should be front, back, or both. Usually black knob to turn. Sounds like 12 volt power getting to it that tells it what to do, but also need to switch over to allow 120VAC power to actually supply power to it for running fan, compressor etc. Be sure to check all breakers in panel as well. You will probably not be able to run both at same time unless plugged in to 50amp or plugged in to 30amp, and generator running as well. I'm thinking a 94 only has 30amp power cable anyway.
Oct 26, 2013 | Dometic Rooftop RV Air Conditioner
My DuoTherm 600315.404 is dripping condensation inside.
need to make a air box that keeps cold and room air separate make sure freeze probe is into coil
Aug 05, 2012 | Dometic 57915531 Air Conditioner
The RV i'm working on has 2 roof units,both start to cool then comp cuts off , there is 1 thermostat with dual zones,its on a 2006 motor home,it dorsn't seem like both would be bad
Can you get 1 to run good at a time, or does same happen when 1 only is run? Some RV's have an energy management system incorporated, that cuts power back to certain appliances when necessary. There were/are some units (RV's) that needed to be plugged in as well as generator running in order to run 2 AC units at same time. Let me know.
Jun 01, 2010 | Dometic Rooftop RV Air Conditioner
I have a suburban lp furnace and duotherm air/heat pump roof unit. duothern thermostat. 20 amp breaker kicked ( reset breaker) & furnace quit. NOW furnace fan comes on but does not light, and the front...
I'm not sure what the problem may be but you could try calling All Seasons RV Appliance Parts & Service. There number is 1-800-344-0673 they have helped me in the past. That and there tech calls are free so it wouldn't hurt to give them a call.
Jan 23, 2010 | Dometic Rooftop RV Air Conditioner
Roof air unit too loud inside; quiet outside.
When you say loud, do you mean as in airflow noise, or vibration like noise? I take it this is a ducted system as well. Does it have quik cool option on ceiling assy.?
Jul 28, 2009 | Dometic Rooftop RV Air Conditioner
Leaking palomino popup trailer
improper sealing around ac if no ac the molding that runs down the center or around the perimeter of the roof do a search on rv leaks on you tube this will help you on your quest also in my personal opinon i would trade the unit cause two years or water damage you are going to have mold in the unit so just get rid of it
Jul 09, 2009 | Rv Motorhome Dual Co & Lp Gas Alarm...
I have a duotherm double unit A/C setup on a 2003 Triple E Commander - I reset the thermostat by pressing the top and bottom buttons on start up - "FF" code shows up, but now it doesn't recognize Zone 2...
In the main unit, remove the inner shroud and then pull down the control unit (two phillips screws). Remove the access cover on the control box to view the dip switches. The switches should be set to Zone 1 and Zone 2 to on and then the furnace to on (if so equipped). If the zones are not in the in position, then set them to the correct position and reset the thermostat again. If they are correct, try turning them off, resetting the thermostat and then turning them back on and resetting again. If this does not work, then you have a bad thermostat or control box.
Hope this helps,
Jeff
Jul 05, 2009 | Dometic Rooftop RV Air Conditioner
Ac Problems
You must have too many things running on that circuit. Check your connection to the power box.Loose connection on the receptacle can cause the breaker to trip or too many things running on the same circuit. If the breaker is old it might need to be replaced.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
May 10, 2009 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
635 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Tim Whalen
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
