Question about Maytag Neptune FAV6800AW Top Load Washer
84 tds error code
I have an 84 tds error code
  • Abraham Holland May 11, 2010
    Have checked manual for FAV6800AW washer and found no mention of error code tds or 84 tds. Is the model designation correct" If not, what is it? and what is actually happening on the machine?
Oce tds 750 error code 08008
Hello, i got TDS 750 from Oc? and the error code is 08010.
Thinks for your help.
Oct 23, 2013 | Office Equipment & Supplies
I need a solution for konica 7145 error code 26-3
F26-3: TDS (Toner density sensor output abnormality) Abnormal output from TDS (Toner density sensor) TDS output ripple voltage failed to reach 0.5V
Possible that developer needs to be replaced or Toner is not supplying into the developer Unit.
Service Manual available to your model at: http://fixmfp.com/index.php?route=product/product&path=60&product_id=52
Sep 06, 2013 | Office Equipment & Supplies
Oce tds 600 error code 08005
you can see you'r answer here:
http://www.copytechnet.com/forums/other-copier-brands/90112-oce-tds-600-08005-error-code.html
Sep 01, 2013 | Office Equipment & Supplies
Oce tds 800 error code 06701
This is a sensor problem. What i did on my TDS 800 was open the top door(A) and bent up just a tad bit the sensor that is on top that clicks when you close the door. What was happening was that after i cleared the jam the code was still saying to clear the jam, which there was none. After bending it up and closing the doors it started working right away.
May 30, 2012 | Office Equipment & Supplies
Stops will not spin had censor replace still will not spin.
Is the wash tub banging around in Spin Cycle with a wash load then failing with a dC or UC unballance error code?
If so the TDS is working as designed. Try a Spin Only cycle with no clothes in the wash basket. If it completes then the issue is most likely a clutch malfunction of your FAV6800A or FAV9800A machine. See this post Clutch Fix
Did you replace the TDS sensor or did a repair person? If it was a repair person did they try a Wet Load Spin Cycle after the TDS replacement?
If a repair person was called and the TDS replaced what troubleshooting steps did they take to warrant changing out the TDS? I would ask if the range of montion check of the TDS was checked for properation signaling action to the Control Board in Service Mode.
Oct 13, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune FAV6800AW Top Load Washer? makes a
more than likely it just needs a little leveling...lift front of washer . there are 2 leveling feet on each front corner under the washer.. they turn like a screw ..just adjust these feet till its level and you should be ok....shake the washer by hand . if it doesnt move it shoud be level,,,,an unlevel washer makes terrible noises ...as you know..thanks and have a great day
Jan 03, 2010 | Maytag Neptune FAV6800AW Top Load Washer
KONICA 1015 COPIER - P.27 ERROR MESSAGE - - WHAT DOES IT MEAN?
2. Toner was added prior to adding developer and performing the TDS adjustment. Developer must be added FIRST at new machine set-up so that toner does not fall on the uncovered TDS sensor.
Run 47 mode, output code 51 until the code does not reoccur (may take 5 to 10 attempts) OR open the developer unit and clean the excess toner from the area of the TDS sensor. Then tilt the developer unit to allow fresh developer into this area.
3. Poor connection at CN95. The toner density sensor (TDS) is abnormal (0.2 V DC or lower). Reconnect CN95 (located under the front of the developer unit).
4. TDS failure. If version 16.0 is installed, P27 is displayed when the TDS is disconnected or fails. Check for proper connection prior to replacing the TDS.
Jul 10, 2009 | Konica Minolta Office Equipment & Supplies
Error code P27
Description
P26 or P27 at power up or during copier operation.
Solution
PROBABLE CAUSES:
1. Open connection from the TDS sensor to the main CB or lack of developer. The TDS output is abnormal (0.2V DC or lower).
Verify that the sensor output is above 0.2V DC by monitoring CN6-A9 on the main CB while running the main motor in diagnostics (47 mode, output code 40).
Repair any poor connections to the TDS sensor and supply developer if necessary.
2. Code occurs after resetting the PM counter and P26 occurs if machine is powered OFF/ON, because the L-detect (TDS) adjustment was not performed
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jun 01, 2009 | Konica Minolta Office Equipment & Supplies
Error code P27
P27 is a TDS sensor error. You need to check the connectors on you developer unit. Open front cover, push down on copier then lift green handle. remove screw just above toner suppy unit and remove your drum assembly. Next remove your developer unit(two latches hold it in place). your TDS connector is located under your dv unit(you will have to remove the black cover). When finished reinstall drum assembly then turn on copier. If problems persist turn copier on while holding down 47 then press 40 then start.you should hear a motor running (let it run for 1 min.) If you don't try P40 or 01. Turn copier on then back on. If the problems persist I recommend a service tech. your DV or TDS sensor needs to be replaced.
May 28, 2009 | Konica Minolta Office Equipment & Supplies
Maytag Neptune FAV6800AW Top Load Washer Logo
334 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
