1992 LXI TV AND THE CHANGE TO DIGITAL
WILL MY 1992 LXI CONSOLE TV WORK WITH THE DIGITAL
CHANGE COMING LATER THIS YEAR. I LOST MY MANUAL AND I WANT TO KNOW IF IT IS COMPATABLE WITH THE NEW UPGRADE CABLE IS CONVERTING TO.
I HAVE SATILITE TV THROUGH DIRECT
MY MODEL NUMBER IS 56448218291
  • 9597 Mar 25, 2009
    Can't connect DTV Converter to my 1992 LXI model 580.40478290. The converter box says to turn to CHANNEL 3, but my LXI does not display a channel 3. The converter box does not have a 'screw' cable for the type of antenna that comes with the TV.
    The Antenna is the type that has rabbit ears and insert into a small hole in the top of the TV and a 'push type' plug that is inserted into the back of the TV.
    Is there anything I can do short of purchasing a new television?
You should be fine. Direct TV advertises that they are already broadcasting in full digital. So your box or DVR will act as that converter.
Posted on Apr 27, 2008
Remove tranny from a 1999 sebring 2.5 lxi does the engine come with??
Yes the motor comes out the top..transmission out the bottom. sounds like you need help.maybe buy a Break down manual for your year vehical it shows how the whole thing comes apart
.good luck
Jan 26, 2015 | 1999 Chrysler Sebring LXi
I own a toshiba Regza 46rv530u and have owned it for about 2 years. Never had any problems until right now! None of my hdmi ports are working. I have not changed any settings on the tv or my game consoles....
Hello
Check your TV for other inputs, ie, AV, antenna etc. If these inputs are working fine, and only HDMI has the trouble, check the HDMI cable. Reset the TV to its original factory settings according to its manual says. Check these and inform me if you fails to get the HDMI input. OK.
Sep 28, 2011 | Toshiba REGZA 42RV530U 42 in. LCD HDTV
Need to find manual for lxi tv model # 43968?
Hi
I was surprised to find this old manual online - this one needed some serious searching! You can download your manual (free) direct from here:
http://www.managemylife.com/mmh/owner_manuals/20357/LXI-Direct-View-Digital-27%22-to-40%22-TV-97110044?brand_name_search=43968
Click the link and the file will open. Although the file appears in a small window within the page, you can still save and/or print the manual. If you are unable to open the file, you may also need to download Adobe Reader:
http://get.adobe.com/reader/
If you have any difficulty opening the file or need further assistance, please post back.
Please rate this solution if you find it helpful. Thanks.
Oct 28, 2010 | Televison & Video
I have a LXI projection screen tv. I bought it new in either 1989 or 1990. It worked fine until today. When I try to turn it on, it tries to come on but goes right back off.
The power supply is most likely faulty. Newer tv's power supplies have been going out in 1-3 years. The capacitors overheat and wear out and burn out through time.
Other possible cause would be a high voltage transformer but i am not sure if you have one on your model. You can test any components with an ohmmeter.
You can get parts and manual at shopjimmy.com
Oct 12, 2009 | Televison & Video
RCA DTA800B1 coverter box & LXI 13" TV - need remote code
You may have to try using a separate universal remote control.
Feb 07, 2018 | Apex Digital AT1308 13" TV
I need to put the altinatior back in
Make sure your car is not in a year change. If so you could require parts from a early model or later model.
Apr 09, 2009 | 1999 Chrysler Sebring
I have a Slim-View LXI TV Model # PTV 515 AHO1 Has no Picture
while i dont have a true answer, I can tell you its a magnavox tv sold by sears produced back in 93. Ours just started doing this last week. I couldnt find any help online so we replaced it with a new led flat panel. WOW what a difference, the LXI was great for the past 17 years but the new tvs are better. We put the LXI in the garage because we couldnt throw it away. That tv was like a family member, if i figure out how to fix it i will post the how to.
Feb 24, 2009 | JVC Televison & Video
Manual for LXI color t.v. (need code)
Kindly try these codes: 012,024,036,037,040,048,051,074.To Program it you press and hold the TV button, then enter a three digit code then release the TV key. See if it controls the device. Good luck. hope this will help. regards
Jan 14, 2009 | Home
Blue gun lites but no picture from it
you should be able to go to any used appliance shop and get what you need. most of them carry on hand parts or can order whar you need
Dec 25, 2008 | Sony KP-51WS500 51" Rear Projection...
Lxi television
I am looking for how to change my tv into video mode without the remote and found an answer for your problems....
http://www.howtomendit.com/answers.php?id=4239
Aug 30, 2007 | Televison & Video
Televison & Video Logo
150 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
