Question about Gaggia Super Automatic Espresso Machine Syncrony Compact
Machine kaput My water light is on and the reservoir is full. Also when trying to brew coffee it was running very slow and now no coffee will brew. I have already tried cleaning out the machine to no avail.
    New Friend:
Try turning on the frothing wand ... the water light should reset once the water has come through.
Posted on Nov 29, 2009
6ya staff
SOURCE:
Doesn't always brew all the water, stops early
All coffee makers do this over time from calcium, lime, and mineral deposits building up inside the tubes and heating coil. Fill the reservoir with a 50/50 mixture of water and white vinegar and run a normal brew cycle, turning it off and on if necessary to completely empty the reservoir. Repeat this 2 or 3 times with fresh mixture of vinegar and water until it brews the reservoir empty without the need to cycle the power. Follow this procedure with plain water 2 or 3 times to clean the vinegar out. This should get it working like new again. It's best to use distilled water for brewing coffee as distilled water does not have the minerals that regular tap water has and therefore will not clog up the machine.
Mar 02, 2014 | Cuisinart Grind and Brew 10 Cup Coffee...
After brewing a cup, lights are flashing and it needs to be unplugged to reset to brew
It's time to descale your brewer. Run a full reservoir of pure white vinegar through, and then a full reservoir of water, "brewing" and dumping one cup at a time. You might have to do two reservoirs of vinegar if you've never rescaled it before.
May 23, 2012 | Keurig Elite B40 Coffee Maker
How do you adjust the water level
After the first brew the machine should brew excactly the amount of water added to the water reservoir. Since the reservoir always keep half full then you should add the maximum amount you need in two steps.
Apr 07, 2012 | Grindmaster B-SAP Coffee Maker
Reservoir is full - unit will not flush or brew - pump is running but no water is being pump out of the reservoir. Replacing the reservoir does no good - blue lights are continuous - no blue blinking...
Hi, Give it a couple of good slaps on the back...there is air stuck in the pump...
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Sep 02, 2011 | Keurig B60 Coffee Maker
Drips only a little bit of water tried viniger thru did not help.. 2 bottles
1.Power off machine.
2.Using a metal paperclip, insert it into left side of top needle. It must insert at least 1" deep.Insert it into slot on right side and again from back of needle.
3.Remove KCup cradle.Separate bottom from top.In the top section, insert the paperclip up into bottom needle from the bottom upwards.It will not go all the way thru and this is normal.
4.Reassemble KCup cradle and reinsert it back into coffee maker.
5.Power on machine.
6.Brew a cup of water only.There may be coffee grounds in the water and these should eventually clear during the remaining steps.NOTE: A large cup brew cycle should output a full 8 ounces (235cc).Less means there is still a blockage
7.Empty reservoir and fill with undiluted distilled white vinegar.Repeatedly run brewing cycle until Add Water light comes on.
8.Make sure Auto-OFF is NOT set and let last cycle of vinegar remain inside machine for 4 hours.
9.Refill reservoir with fresh water and repeatedly run brewing cycle until the water is clear and odorless.
10.Set Auto-OFF, if preferred.
Mar 28, 2011 | Keurig B70 Coffee Maker
Won't brew only drop at a time wiuth coffee grounds ]
5.Power on machine.
Mar 26, 2011 | Keurig Platinum B70 Coffee Maker
The water res. is full all the right buttons are pushed but coffee won't brew. What do I do next? It only has a small drip.
5.Power on machine.
Mar 25, 2011 | Keurig Elite B40 Coffee Maker
Did not make the large cup of coffee. Then we de-scaled the machine with vinegar. The computer seems off. The hot water is coming back into the water reservoir.
1. Power off machine.
2. Using a metal paperclip, insert it into left side of top needle. It must insert at least 1" deep. Insert it into slot on right side and again from back of needle.
3. Remove KCup cradle. Separate bottom from top. In the top section, insert the paperclip up into bottom needle from the bottom upwards. It will not go all the way thru and this is normal.
4. Reassemble KCup cradle and reinsert it back into coffee maker.
5. Power on machine.
6. Brew a cup of water only. There may be coffee grounds in the water and these should eventually clear during the remaining steps. NOTE: A large cup brew cycle should output a full 8 ounces (235cc). Less means there is still a blockage
7. Empty reservoir and fill with undiluted distilled white vinegar. Repeatedly run brewing cycle until Add Water light comes on.
8. Make sure Auto-OFF is NOT set and let last cycle of vinegar remain inside machine for 4 hours.
9. Refill reservoir with fresh water and repeatedly run brewing cycle until the water is clear and odorless.
10. Set Auto-OFF, if preferred.
Nov 21, 2010 | Keurig B50 Coffee Maker
Runs slow
There is a quick and inexpensive solution to the problem. Household vinegar. Pour about one cup vinegar into water reservoir, replace filter basket without filter allow it to cycle through. After it has finished brewing, you may repeat with another cup of vinegar. Once you are finished running the cycle with vinegar, fill water reservoir with water and cycle through. Be sure to run water through machine at least twice to rinse out all the sediment and or vinegar. Works everytime my coffee maker starts running slow.
Jun 17, 2010 | Cuisinart DCC-1200 Coffee Maker
KeurigB50 Coffee Maker will not brew. Gets to the
Jan 01, 2010 | Keurig Ultra B50 1-Cup Coffee Maker
Gaggia Super Automatic Espresso Machine Syncrony Compact Logo
119 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Pierre Laplante
Ekse
Marvin
Marvin
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
