Question about IBM NetVista PC Desktop
Keyboard my pc keyboard flashes but then doesnt stay on....my keyboard works fine on my other pc.I am trying to install windows on my new hard drive and I went into bios to change some stuff now I cant get the keyboard to recognize...what do i do?
  • 35 Answers
What is the connection type of your keyboard? is it PS/2 or USB?
well, if your keyboard is a PS/2 type, there might be a problem with the PS/2 keyboard port, because you've said that it works well with your other PC.
if your using a USB type of keyboard, well try to check if your SYSTEM BIOS supports USB Keyboards. because there are some PC doesnt supports USB keyboard on its BIOS. if it supports, well, enable the USB Devices on your BIOS settings to ON.
Posted on Mar 14, 2008
SOURCE:
Hi , went to bed at night laptop was fine. When I woke up and tried to open, The dell load screen appear and 1sec later it goes to the black screen with a white underscore blinking top left corner. Windows...
The hard drive may be going bad. Try booting into Safe Mode to see if it boots into Windows. Then I highly recommend backing up all documents onto a flash drive or portable hard drive.
Mar 22, 2015 | Dell Inspiron Computers & Internet
My Keyboard and Touchpad are not working
Try installing your Windows again.A bit hard to tell, cause it can be allot of things that went wrong..
Oct 23, 2011 | Computers & Internet
My laptop had been working fine, then the last
Hi yes try this, if no joy come back to me.
Normal 0 MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} To install new version of XP. Insert XP CD into drive, reboot pc pressing ESC button, or delete in some machines. This takes you into BIOS, change your primary boot device to CDrom, save changes and reboot. Select boot from CD once this appears and wait for files to be installed. Select the part of the hard drive you wish to use for your operating system (usually the largest) and select partition this drive. Delete any previous os, and reformat hard drive. (Be aware this removes everything saved on your hard drive, so always back up first) Re boot afterwards and reinstall operating system.
Jul 10, 2010 | IBM ThinkPad A30 Notebook
A new asus eee pc 1005ha boot problem
replace hard drive,
First remove 4 bottom screws, and Ram cover.
remove keyboard by pressing down on the 4 tabs across the top of the keyboard with a small flathead screwdriver. disconnect ribbon from body
once keyboard is removed unscrew the 6 black screws where the keyboard was they are the same as the other 4 bottom so do not worry about mixing.
pop open the top casing starting in the top right working your way around to the top left in a clockwise motion.
remove and replace the harddrive from here.
Find a PC install a program such as WinToFlash (freeware) and create an installable copy of Windows XP on a flash drive no smaller then 2 gb.
Put flash in USB slot
press escape as computer starts choose the USB drive
Format and install XP from flash
Mar 29, 2010 | ASUS Eee PC 1000HE Netbook
I got this really old HP Pavillion ZD7260us Laptop a friend left it to me with no HDD and no memory.So i went to buy a DDR PC270 512mb SO DIMM memory and an 80gig IDE Hard Drive. So i tried to install it...
try plugging a standard pc keyboard into the ps2 slot ,if it has one, if not use a usb keyboard. That should tell you if the keyboard is malfunctioning. As for using the hard drive with no caddy it should be fine as long as you pad it it securely, to stop it being knocked about etc when moving the laptop. Also you will need to enter the bios and set ideo 0(the hard drive) to auto detect. As it is more than likely detecting the old hard drive in the bios settings not the new one?
Oct 28, 2009 | Computers & Internet
The keyboard doesnt work
Either replace the keyboard or try and get the latest driver download for your keyboard
Aug 05, 2009 | Dell OptiPlex 360 Desktop Computer
Nothin works and nothin is detected
doesnt need batteries does it dl latest driverers form website maker try ohter ports
Oct 09, 2008 | Microsoft Wireless Optical Desktop Comfort...
Sandisk 4GB cruzer micro usb flash hard drive
try removing off the launchpad program from the pen drive through an XP system with this software and then try inserting it on the vista as an ordinary pen drive.
Mar 17, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Windows
hard drives dont read cd's
does the door close?
if not close it.
1)left clik my computer
2)double clik the cd rom drive, making sure theres a disk in it.
3)right clik on my computer
device manager
look for a yellow exclamation point or red X where the cd-rom is.
high light the cd-rom
right clik
uninstall
restart the computer
windows will detect and re-install the cd-rom drive.
try a cd
if that doesnt work update windows
also buy a cd-rom cleaner at your local electronics store
clean the drive w/th cleaner
try a cd
if updating your driver for the cd rom drive and all ive suggested then its time for a new cdrom drive
Dec 09, 2007 | Dell OptiPlex GX260 PC Desktop
The Keyboard not working, MS Wireless, laser, desktop 5000
i don't like the sound of you taking the hard drive out of a old computer and loading it in your new one without reinstalling windows especially with windows XP your choice i guess.
Did you try and couple the keyboard and receiver by pressing and holding the button on the keyboard for a while?
Dec 08, 2007 | Microsoft Wireless Laser Desktop 4000...
IBM NetVista PC Desktop Logo
301 people viewed this question
Top IBM Computers & Internet Experts
Ekse
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
