Question about Nokia 6133 Cellular Phone
I need help!
In my phone, whenever i try to send a picture message the phone automatically turns off by itself but then it turns on. so today, i tried to send a picture message then the same thing happened but my phone turned off and never turned back on. i figured that the battery was dead so i charged it. while it was charging i turned it back on but then once it turned on it turned off then it continued doing that for about 5 times until it finally turned back off. every time i tried to turn it on, it would do the same exact thing. basically, there's no use for my phone because by the time i unlock the keypad, it turns off.
    Brigadier General:
  • 7,752 Answers
Your main-board needs to be reflash or replaced
Posted on May 28, 2008
SOURCE:
Why can't I send or receive picture messages?
Why dont you go to the store and ask them to help. Is it the same model, newer model. Google the problem
Jul 08, 2014 | ALCATEL-LUCENT USA INC One Touch Fierce 4...
Whenever I try to send or receive a picture message on my HTC Inspire 4G I get a "generic network failure" error message. How do I fix it?
That usually occurs when your internet is not turned on. If you do not see that your 3G is turned on when you are trying to send a picture, you will get this error message. Go to your wireless settings and double check that your mobile network is turned on. If it is, you might need to update your profile (also under settings).
-ex Sprint rep
Jul 14, 2011 | HTC Inspire 4G Smartphone
Hi I have an htc 7 Trophy and can't send picture messages. When I try and send them the words 'Can't send message Try again' come up beneath the message. I have installed the Connection Setup application...
The max size limit of the file is 300kb!!! Pretty stupid when a picture taken with the phone at the lowest resolution is still too large and the phone doesn't automatically compress the image like my droid did. Im trying to find an app that will compress the images for you. If there is not one, then you will have to sync to a computer, resize, re sync to phone, then send a very low quality picture. Fail on windows or HTC, whoever is responsible
Apr 01, 2011 | HTC 7 Trophy Cell Phone
My Samsung Sway is glitching out.
Sine this is a device issue all you can try doing is a master reset or a reset settings. If that doesn't work then you would have to look into replacement options with your service provider.
Mar 14, 2010 | Samsung Sway SCH-U650 Cell Phone
Can't send or recieve pictures with the pantech matrix.
sounds like your network settings are set correctly you should contact at&t and they will send you an update directly to yur phone and it will adjust the settings
Nov 13, 2009 | Pantech Matrix Cell Phone
Picture Message Problem
try to free up some space. delete some of your files in your phone.
Jan 28, 2008 | Nokia 6133 Cellular Phone
Error message when trying to send pictures
i work at a cell phone support group called ict, we get this problem all the time with the lg phones. the problem is with the carrier select in the programming. have your phone reprogrammed...you will need to contact your service provider for you lock code, but you can usually get into the programming screen by dialing ##program# or ##data# from the main screen of the phone (you do not need to dial this number or hit ok once putting in the last #, it will automatically pop up if you are doing the right code. again, you will need your lock code from your service provider/carrier. once you have that go into the programming and go to carrier, high lite which ever carrier you are with, hit ok and the phone will shut itself off, turn itself back on and you should be able to send your picture without further problems..
...if it then asks you for a pass, call your service provider, they also need to give that to you and if it says error 256 after that, then call your service provider because the url needs to be changed...
hope this long winded post helps you guys.
Dec 26, 2007 | LG KG800 Cellular Phone
Whenever i try sending a text message, it always sends as a picture message
hey i was having the same problem, seemed to occur when cingular switched over to att, i resolved this problem by deleting all messages. when you are in the message menu select options then cleanup mesages and select all messages. hope this works for you as it did me. good luck!!
Aug 13, 2007 | Motorola Mobility MOTOKRZR K1 Cellular...
Nokia 6133 Cellular Phone Logo
212 people viewed this question
Top Nokia Cell Phones Experts
jonathan mariano
jonathan mariano
Ekse
