Question about Singer 14SH654
Trouble with singer ultralock 14SH654
Hello! The other day I was sewing along and my machine just stopped midstitch. The light still comes on so it obviously has power but I can't get it to work. I've taken the foot pedal apart but I can't tell if anything is wrong. Need help please.
The motor could have gone...........Did you smeel plastic burning?The footpedal may be broken.Ask a shop if you can buy one and return it if thats not the problem..
Posted on Mar 21, 2008
SOURCE:
Was sewing along,straight stitchin,machine simply stopped! Like no power anymore but light is on! 1 expert:foot pedal bad but PEDAL IS POWERING MOTOR! Correct resistance ohms?
If it's a mechanical machine (not computerized), it may need a good cleaning and oiling. Consult your owner's manual and use only good quality sewing machine oil.
Sep 16, 2015 | Sewing Machines
My Huskylock #905 serger overheated and stopped. I unplugged it and let it rest for a day. Still does not run. Light comes on but will not sew
I would try to oil it with sewing machine oil. If that doesn't work, you may have to get a new peddle. My peddle had to be replaced. It just stopped working.
Dec 23, 2014 | Sewing Machines
Red check light is on
So, turn it off and unplug the machine. Take your work out...
Remove the bobbin cover... look for thread balls, knots, etc.
Move the needle forward with the hand wheel. Does that feel normal? It might need adjusting and the check light and stop could be something to keep you from breaking the machine.
Mar 28, 2014 | Euro-Pro Shark 80 - 7133
Stopping at midstitch while free motion quilting.
did you try cleaning the drive area of the machine? you may have a lot of buildup of dust,thread,fabric, etc. that nay be interferring with the mechanical drive. You might have to remove the cover to get to the inside to clean. Use a small computer vac to clean up and a small dry paint brush to clean parts. Or get a professional cleaning.
May 08, 2009 | Singer Quantum 9940 Computerized Sewing...
Stops sewing
Sounds like the motor is stressing and a cut-off is operating to protect from overheating........ensure the bobbin area under the needle plate is clean and clear of lint, and that there is no thread jammed around in this area, also at the take-up arm and the cams at the far left of the upper shaftnear the needlearm.........if there is thread wrapped around anything, unwind it VERY CAREFULLY .....DO NOT pull and break it, be patient and move the handwheel gently in reverse while gripping the trapped thread, working it free slowly.
Of course it may be that the motor is old and needing a replacement, but as this machine is quite elderly and may have other complicating issues, you would be best to have someone take a look at it for the best decision of fix or replace, if it comes to that point.
May 13, 2008 | Janome Memory Craft 4000 Sewing Machine
Straight sewing but only a few stitches before stopping
Hi Gaden....It's obvious by your post that you have advanced knowledge in sewing/machines including maintenance, so I feel very confident that your issue can be resolved by updating your software. Please click on the URL below, and download the approriate updates that correspond with your equipment.......Please update your post so I'm aware of your status....good luck my friend http://futura-support.com/downloads/patch.htm
Aug 02, 2007 | Singer CE-200 Quantum Futura Computerized...
Singer 14SH654 Logo
200 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
Kelley Buchanan
Kelley Buchanan
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
