Question about Canon PowerShot S2 IS Digital Camera
Canon powershot s2is file transfer
I put all my images onto the computer and somehow managed to delete them all off the camera, can i put them back on somehow?
  • 101 Answers
You want to put the pictures from your computer back onto the camera? you can use a card reader and do a file transfer (drag and drop).
Posted on Mar 14, 2008
SOURCE:
My camera is fine and I transfer photos to my desk op . Now I also have a laptop which I want to transfer photos on to but can't find soft ware to do so.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy selected pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Jan 31, 2013 | Canon PowerShot SX10 IS Digital Camera
How to put pictures from a computer onto poweshot a480 camera?
First of all, if you've edited the pictures in any way (opening a picture in a photo editing program and then saving it without making any changes counts as editing) then the camera most likely won't be able to display the images.
You can transfer files (not just pictures) to the memory card using a card reader. Plug the card into the reader and it will appear to your computer as another hard drive. Simply drag-n-drop files to it the same way you copy other files on your computer.
Jul 18, 2012 | Canon PowerShot A480 Digital Camera
Images no longer download to the computer from the camera via USB cable. Blue light flashes and camera says it is transfering but nothing is happening. Program Manager says that Cameralaunch* file is not...
Not sure what is causing your error, but have you considered taking out the memory card and inserting it into your computer? You can manual transfer the pictures from that. Hope this helped!
Feb 05, 2011 | Canon PowerShot A520 Digital Camera
Trying to download my pictures from Canon Powershot A430 onto my new laptop Windows 7. Downloaded the disk and now trying without success to download my pictures onto the computer. Help??
Supported windows Operating system Windows 98 Second edition(SE)
Windows Me
Windows 2000 Service pack 4
Windows XP SP 1 and SP 2 Canon PowerShot A430 has no update about the new driver software for windows 7 Try doing this direct transfer in your computer 1. Connect the camera to your computer using the supplied USB cable of your camera. 2. Set the mode dial to (playback) and turn on the power.
The camera and computer will be able to communicate. 3. If there is no pop up window that has Canon CameraWindow, Click the [Start] menu and select [all Programs] or [Programs]. followed by [Canon Utilities], [Camera Window], [PowerShot-IXY-IXUS-DV 6] and [CameraWindow] 4. Download the images.
* Download the images using the camera or the computer.
* By default, the downloaded images are saved into the [My Pictures] folder. ** If the above process does not work you can just use the memory card of your camera and connect that on your laptop. (some laptop has built in card reader) The memory card works like a flash drive and you can just transfer files like transferring from one folder to another. ** Issue on the operating system compatibility.
Apr 14, 2010 | Canon PowerShot A430 Digital Camera
How do I recover images that I accidently deleted?
Yes, with a good image recovery software like asoftech photo recovery, it will be an easy job to recover deleted images from camera's memory card. follow the instructions here
http://www.asoftech.com/articles/how-to-recover-deleted-photos-from-camera.html
Dec 19, 2009 | Canon PowerShot A550 Digital Camera
My canon power shot SD960 IS has always transfered images to my computer until today. I charged the battery but it still tells me camera diconnected, did not transfer.
Hello
Thank you for using FixYa for your problem
Check the USB cable, put it into a different port on the computer
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Dec 02, 2009 | Canon PowerShot SD960 IS Digital Camera
Pictures won't upload onto camera
there is solution for viewing the other size files in ur camera sir.
because camera is designed to read only that size of images.
Jun 13, 2008 | Canon PowerShot A540 Digital Camera
Trying to play off-camera stored video, when replaced onto SD card in camera
Did you change the file name on the original video? Are you able to put the video back onto the camera? If you changed the file name, you can't put it back onto the camera. It also needs to be in AVI format which is the video format that the camera records in.
Hope this helps!
May 28, 2008 | Canon PowerShot S5 IS Digital Camera
Canon Powershop ds600
Ok, there are two options I'd suggest here. First option is to get a card reader, and copy the files onto a memory card this way. With many cameras it's possible to use the camera as a card reader, but many Canons don't support this function.
The alternative is to burn the pictures onto CD. Most photo labs will print images from CDs for you.
Hope this helps.
Nov 20, 2007 | Canon PowerShot SD600 Digital Camera
Canon PowerShot S2 IS Digital Camera Logo
Top Canon Cameras Experts
old marine
old marine
Doberman
Ekse
Are you a Canon Camera Expert? Answer questions, earn points and help others
