Question about Samsung SPP4231 42 in. EDTV-Ready Plasma Television
Plasma samsung sp-p4231
Can you help me, i was watching my plasma an the video went nothing on the screen but i can hear the sound
  • Anonymous May 11, 2010
    Do you have menus displayed on tv?
THE TV HAS NO MENUS , BUT IT I USE THE VIDEO OUT PUT FROM THE BACK OF THE TV , CONNECTED TO A MONITOR IT OK CHANNEL CHANGE ,I CAN SEE OD GET A DVD OUT PUT . YOU SAID THAT THE BOARD MIGHT BE BAD. IS THE PLASMA SCREEN OK . WHERE CAN I PUCHASE A BOARD IF ITS BAD
Posted on Mar 19, 2008
  • 29 Answers
Could be the Y-main board or the main board
Posted on Mar 15, 2008
SOURCE:
I have a thin white vertical line in the center of my Samsung Plasma SP-P4231. It is in front of the menu. It appears as soon as I hit the power button and stays on for the duration.
I know nothing about flat panel tv sets but in earlier times a thin vertical white line meant a fault in the line - the line oscillator or the line amplifier and an outside chance of a fault in the synch. circuitry.
It would probably need an oscilloscope and some experience to find the exact source.
Nov 17, 2017 | Samsung Televison & Video
What do you think is wrong with my television, it has sound but no picture. How can I fix the problem?
Hi there
I would go to menu on the remote , from there to picture go down the list, if you do not find anything there to help you. Go to Support and to the E manual .
26053790-x3zeawgeewbvgdzeyuixqaom-4-0.jpeg Kolbrun
Jan 14, 2016 | Samsung LN52C530 52" LCD TV
Samsung sp-p4231 turns on and off but no picture
system has a short some were. it could be an inverter board or main power board not working properly . when you switch it on does it click at the back of the tv... ?
Sep 17, 2013 | LG RU-42PX10 42 in. HD-Ready Plasma...
My Samsung SP-P4231 plasma television works fine for several hours and then the picture gets all wiggly and impossible to watch. If we shut the tv off and wait an hour or two and turn it on again, it works...
The tv main Tuner signal board have intermittent problems,sorry this problems it could be anythings wrong in the board as parts wise are dying in the tv Tuner signal board just not completely,that why it take times to show up,that the board where the tv incomming broadcasting signal cable plug into it.U can take things aparts and putting it back together again?Yes.Try website like Ebay.com to buy a refurbish main Tuner signal board for the replacement.Or take to the shop for the repair that it.
Apr 19, 2011 | Samsung SPP4231 42 in. EDTV-Ready Plasma...
My Samsung SP-P4231 has sound but no image. How can I fix this?
Go to eBay and search for BN96-01217A.
That is the power board used in SP-P4231 and the most common reason for the problem you have.
(not guaranteed, just statistically most likely one; if you care to check measure the Vs voltage at the power output - shoudld be about 87V and will probably be much less, say 30V)
Hope this helps!
bobby @ coppelltvrepair
http://www.coppelltvrepair.com
Dec 05, 2010 | Samsung SPP4231 42 in. EDTV-Ready Plasma...
Have audio but no video
no picture just sound on model# sp-p4231, what do i do
Jul 05, 2010 | Samsung SPP4231 42 in. EDTV-Ready Plasma...
SAMSUNG sp-p4231 sound, but no picture
try changing the display IC that would be the frequent cause of such problems
Jul 04, 2009 | Televison & Video
Screen black out
this is a upper buffer board problem, the board is not to expensive but the if you are not a repairman, I would not attempt it
Jan 18, 2008 | Samsung SPP4231 42 in. EDTV-Ready Plasma...
Samsung sp-p4231
This is how I approach this problem: I check for menu appearing on the screen: If it has menu, I look at connections. If it does not have menu then I check voltages from the power supply. I check for the following voltages. VSCAN, VS, VE, VSET and VA. If only one voltage is there, then, the PCB that needs to be replaced is normally the SMPS and/or the Logic. If all the voltages are there, the Digital PCB should be replaced. If it is missing one voltage, I disconnect the Y Main and X Main from the power supply and check if the voltage reappears. This symptom is normally caused by one of these two boards having a short on the missing voltage line. The defective PCB and/or the Power Supply (SMPS) need to be replaced. If you are in need of a technician, contact Samsung at: 1-800-SAMSUNG If you have any other questions, reply to this post and I will respond.
Sep 23, 2007 | Samsung HP-P3761 37 in. HD-Ready Plasma...
Samsung SPP4231 42 in. EDTV-Ready Plasma Television Logo
337 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
