Con't hard disk problem
I use fdisk and the hard is mounted correctly by its partation with 100 percent to its total disk space and I format using dos and it complete 100 percent but when I load windows hard disk malfunction or wont save programs
Set your hdd to "active" on fdisk option.
Posted on Mar 23, 2008
6ya staff
SOURCE:
How to make partition on hard disk
Welcome to Fixya
Dear User
You can Make Partition Using any Utility like Partition Magic or something like that.You can also Make Partition Using XP Installation CD at the Beginning of Installation before Format Option starts or asks.
If you are Using 98 start up CD.There is FDISK dos Option to Make Partition.There you are able to Make Partition by giving Some Space according to Hard disk SpaCE[yOU CAN GIVE IT LIKE percentage Basis...
Let me Know if you need further assistance....Hope you got it....Thanks for Connecting FixYa...
Sep 03, 2010 | Computers & Internet
I installed just as the instructions said and i cant get my pc to recognize my 1.5tb hard drive
First download this disk iso and add fdisk to the disk and burn ituse this link:
http://www.bootdisks.us/ms-dos/5/ms-dos-bootable-cd-images.html
download fdisk from this link FDisk 6.22
http://www.uv.tietgen.dk/staff/mlha/Download/dos/#FDISK
Once you have downloaded and burnt the disk, make sure the drive is showing in the bios, then set to boot using the cd/dvd-rom and insert the disk.
When loaded, at the command prompt type fdisk, find the 1.5tb hardrive and create a primary dos partition, it may take a while so be patient, once done take the cd-rom out of the drive and reboot the mechine, goto my computer and you should see the drive, and it will have a drive letter next to i. It want contain anything as it has not yet been formatted.
To format just right click on the drive and choose format, choose ntfs and press ok, it takes a while so again be patient, and you should now have a usable new drive. hope this helps, any problems post back.
Apr 06, 2010 | Koutech Systems IO FLEX-PSA150...
How to format hard drive
Insert your Windows CD and follow the instructions.
Oct 28, 2009 | HP EliteBook 6930p Notebook PC
I`m unable to install windows 98 in seagate 80 gb ide barracuda hdd
For W98, if you create the bootdisk from within windows, you will need to go here to download the newest version of FDISK.EXE then copy it to the bootdisk, allowing it to overwrite the older version. This way you will have support for larger harddrives.
FDISK LIMITATION WITH 64GB DRIVES:
Why does FDISK not recognize my disk (or RAID array) which is larger than 64GB?
There is a bug in Microsoft's FDISK under Windows 95B, 98 and 98SE that can be corrected by downloading a newer version. See Knowledge Base Article Q263044 for more information.
http://support.microsoft.com/default.aspx?scid=kb;EN-US;q263044
When you use Fdisk.exe to partition a hard disk that is larger than 64 GB (64 gigabytes, or 68,719,476,736 bytes) in size, Fdisk does not report the correct size of the hard disk.
The size that Fdisk reports is the full size of the hard disk minus 64 GB. For example, if the physical drive is 70.3 GB (75,484,122,112 bytes) in size, Fdisk reports the drive as being 6.3 GB (6,764,579,840 bytes) in size.
NOTE: This hotfix is not designed for 48-bit logical block addressing (LBA) hard disks, and it is not supported on hard disks larger than 137 GB. However, even if the drive is physically larger than 137 GB, if you create partitions smaller than 137 GB, this FDISK.EXE version will work correctly. (THE FORMAT COMMAND WILL SHOW THE DRIVE AMOUNT IN DOS TO BE OFF THE MARK, BUT WILL BE CORRECT WHEN YOU GET INTO WINDOWS ITSELF)
Direct English Version download:
http://download.microsoft.com/download/Win98/Update/8266R/W98/EN-US/263044USA8.EXE
This package installs the updated Fdisk.exe to the Windows\Command and Windows\Options\Cabs folders, on a computer running Windows 98 or Windows 98 Second Edition. If you are starting a computer from a Windows 98 Startup Disk in order to partition and format the hard disk, you should copy the updated Fdisk.exe from the Windows\Command folder to the Startup Disk, replacing the original Windows 98 or Windows 98 Second Edition version of Fdisk.exe on the Startup Disk.
Dec 25, 2008 | Seagate Barracuda 7200.7 ST380011A 80 GB...
Barracuda hard disk 80gb
More than likely, since you say you did a DOS install of the OS, you did not set the FDISK parameters to set your primary drive. Insert the DOS CD you used to format the system. Boot to a DOS prompt and run the FDISK command. It should have an option, I believe it is number 2 or 3 to "Set primary drive". Select your hard disk 0 as this drive and you should be fine at rhat point.
Sep 17, 2008 | Seagate Barracuda 7200.7 ST380011A 80 GB...
NOT booting WINDOW XP
Hey stanley154
try to boot your machine using window 98 startup disk or window 98 bootable CD. then type fdisk on DOS prompt. Then try to delete non dos partation and the create primary dos partation. Restart your machine, let it start window or the floppy until it return to dos prompt. Then you can type the format c: e.g a:\format c: or D:\format c:. After that try to run window xp.
all the best
zinja
Sep 17, 2008 | Acer Aspire 5500 5570-2609 Laptop
Unable to access my disk with any operating system
Hey,
Seems you got a broken down drive, you can try it on another computer to see if the issue persits or take it to a computer repair shop to get it tested, no not wallmart, some real computer repair place
Thanks,
Ekse
Aug 29, 2008 | Seagate HDD 40GB 7200RPM ATA100 2MB...
Open Questions:
Computers & Internet Logo
112 people viewed this question
Ekse
Marvin
Marvin
