The fact that you get enhanced ignition by physically enriching the fuel air mix indicates that the normal mix is too lean, either too little fuel or too much air. 1) Check for leaks of un-metered air in to the air ducting and inlet manifold. Look for cracks and poor joints to all vacuum lines including the evaporative emission recovery lines. 2) Check that the EGR valve is closed off at start up: this should stay closed until engine has warmed up. 3) Finally check that the coolant temperature sensor is working OK; the sensor should be informing the ECU that the engine is cold and the ECU responds by ensuring an enriched fuel mix (by prolonging the injection cycle) during engine warm up.
Sounds like your security is staying on.Try locking the car with the remote keys then unlocking If that doesnt work lock car again and unlock it with key in passenger side door..These should solve your problems if not tell me what you got after doing those things..
It is probably not the anti theft system if it cranks over fast then slow it is your timing chain. If you want to try resetting the anti theft system disconnect the battery cables for 24 hours and reconnect them.
