Question about Sony MDX-CA580 MiniDisc Player
NO sound from my sony mdx-c8200
Hi there.
I have a 2nd hand sony mdx-8200. The radio and voice prompts come through the speakers clearly but when i play an md no sound comes through the speakers but the display does all the right things. I do not have the stick control or remote so can not turn off the ATT like the manual suggest can anyone help??
  • Anonymous Sep 13, 2008
    I have the same problem, I got this unit from a friend that came from japan, but I think it is a non mdlp md unit, so gonna try to record an md in non mdlp md mode.
I had the same problem before with the same unit, and I found that the problem was only the recording format, you have to record your MDs in SP mode, this is because, the mdx-c8200 is a non MDLP MD compatible unit. So, if you want to listen your MDs on your mdx-c8200 just don t record em in LP mode, just SP mode.
Posted on Sep 13, 2008
Radio power is on but no sound coming from speakers/radio on 2005 Acura MDX. Sound works with CD's
Turn on the radio and increase the volume if you can hear a hiss through the speakers, chance is the aerial/antenna connection is not hooked up correctly. Another way to check is try tuning to an AM station if you get a signal on AM but not FM then it is The antenna. You may have to remove the radio to get at the connection.
Oct 05, 2013 | 2004 Acura MDX
I NEED A FREE SCHEMATIC FOR 2001 ACURA MDX STEREO MODEL 39101-S3V-A131-M1
Hi there:
I suggest to check this on 2001 Acura MDX Car Stereo Radio Wiring Diagram...
Radio Constant 12V+ Wire: White or White/Blue
Radio Ignition Switched 12V+ Wire: White/Red
Radio Ground Wire: Black
Radio Illumination Dimmer Wire: Red/Black
Radio Antenna Trigger Wire: Yellow/White
Radio Amplifier Trigger Wire: N/A
Front Speakers Size: N/A
Front Speakers Location: N/A
Left Front Speaker Wire (+): Blue/Green
Left Front Speaker Wire (-): Gray/Black
Right Front Speaker Wire (+): Red/Green
Right Front Speaker Wire (-): Brown/Black
Rear Speakers Size: N/A
Rear Speakers Location: N/A
Left Rear Speaker Wire (+): Blue/Yellow
Left Rear Speaker Wire (-): Gray/White
Right Rear Speaker Wire (+): Red/Yellow
Right Rear Speaker Wire (-): Brown/White
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Jun 29, 2012 | 2001 Acura MDX
Need wiring diagram for sony xr-c8200.need to know what color wire is the power wire.
red is switched or ignition power, yellow is constant power, black is ground.
Feb 18, 2011 | Sony XR-C8200 CD Changer
The speakers in my new 2nd hand car won't play
if one speaker in car is shorted or bad.It will cause the whole system to mute .You may need to have someone to disconnect one speaker at a time or pull out radio.Some systems have a seperate amp in rear of car .Check fuse for that amp//goodluck
Jul 30, 2009 | Car Audio & Video
Hi ive just bought a 2nd hand sub n amp,wired them up and i can only get the amp 2 work,my other subs work plugged into the same amp just to check but the xplod wont,im not getting anything wot so ever,i...
Hello empsglen,
If the sub voice coil is open, you will get exactly no sound. No crackling, nothing.
Use a multimeter to check the sub voice coil. If the meter reads infinity, the coil is open and to the amp, it's as if there's no sub connected, and you will need to replace it.
Hope this helps.
Jul 15, 2009 | Sony Xplode P5 Turbo Subwoofers Car...
There is a problem with my Sony icf-sw7600gr's speaker,it is not working (there is a faint volume however). Ear-phone works fine. What has happened to my speaker? Jack, Ireland
Seems speaker voice coil is not working due to stiffness and its irreparable. You should replace speaker of radio as per following part number..
1-529-942-11 SPEAKER (7.7cm)
Available in Part Store.
Apr 03, 2009 | Sony ICF-SW7600 AM/FM/SW Radio
No car radio / stereo for use with Garmin nuvi 750 GPS
Every Garmin Nuvi unit I've seen has a (loud) built-in speaker. The only demand our 250s and 265 make of the vehicle is a 12V power supply (and they'll even work without that for a while, until the battery goes flat).
A.
Dec 17, 2008 | Garmin nuvi 750 GPS Receiver
Sound problem
You have a shorted speaker or a speaker with a bad voice coil. This has been confirmed by the fact that the audio amplifier is shutting down (protection) but the unit stays powered on. The speakers will play for a few seconds or maybe even longer at lower volume, but any length or time or an increase in volume will immediateley shut off sound. This is due to the fact that a shorted speaker wire/connection will ground out or short to one another. If you have checked all connections behind the radio AND at the speakers and found no problems, then it is a voice coil on the speaker. A shorted voice coil will work until the speaker cone moves causing the short or until enough power passes through the voice coil's short to turn off the radio.
Solution:
1. You can use a voltmeter set to check continuity to test for a speaker short. Disconnect all speakers from the radio and connect one side of your meter to ground and the other to the speaker lead. An audible "beep" will confirm a short.
2. The other method would be to disconnect all speakers and re-connect them one by one until the radio's sound output shuts off again. This will be your shorted speaker.
I hope this information was helpful.
Apr 07, 2008 | Pioneer DEH-1800 CD Player
No volume will not give voice prompt
Make sure you don't have the sound muted. Have you tried plugging in a set of headphones into the headphone jack? If you can hear sound with the headphones, most likely, the internal speakers have failed. If you still can't hear any sound, the audio output stage on the motherboard1.gif has failed. In either case, you will need to send the unit back for repair. Be sure to have your serial number handy. Register it online https://my.garmin.com/mygarmin/marketing/register.htm
if you haven't already done so.
Hours:
Monday - Friday
8 a.m. - 7 p.m.
Central time (closed holidays)
1-800-800-1020 (U.S.)
1-866-429-9296 (Canada) or (913) 397-8200
Good Luck,
- Jim
Jan 20, 2008 | Garmin StreetPilot C330 GPS Receiver
Car compatibility
Bluesman,They Make adapter Kits,That can Plug in to your Existing Plugs of your Vehicle,Check your local Car Audio Dealer
Jun 20, 2007 | Sony MDX-CA790X MiniDisc Player
Sony MDX-CA580 MiniDisc Player Logo
230 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
