Question about Dell Inspiron 1000 Notebook
Dell Inspiron 1000 Disassembly
I was unable to find disassembly instructions for the Dell 1000. Therfore, I documented the process. Though it might help someone else.
1. Remove Battery
2. Remove DVD drive by removing 2 screws on bottom of the laptop. The two screws will have a lock next to the screws.
3. Remove screw on bottom of laptop labeled M. Lay the screw and memory cover aside.
4. Remove Hard Drive cover by removing 2 screws labeled H. Lay the screws and Hard Drive cover aside.
5. Remove 2 screws labeled H which are located under the Hard Drive cover. Gently pull on the Hard Drive removal tab and place screws and Hard Drive aside.
6. Remove 2 screws labeled D from bottom of laptop. These screws are located directly under screen.
7. Gently remove plastic keyboard retainer strip by opening the screen to a horizontal position and gently prying the plastic strip containing the power switch.
8. Carefully remove keyboard, unplugging the ribbon cable from the motherboard by lifting the outermost edges of the keyboard ribbon cable connector. This should allow the keyboard and ribbon cable to slide out easily.
9. Remove silver motherboard cover by removing 7 retaining screws.
10. Remove Fan by removing screws labeled TH7 & TH9
11. Unplug and remove fan.
12 Remove processor heat sink by loosing the 4 strange looking screws that have springs attached to them and are labeled 1 through 4. Loosen screws a couple of turns at a times starting at 1 and working through 4.
13. Unplug screen cable from mother board.
14. Remove screw attaching the screen ground to the mother board ground.
15. Hold on to the screen and Remove 2 screws from back of laptop labeled D. Screen is now loose. Remove and set aside carefully.
16. Remove 4 short screws from top of laptop. Screws are located close to the back of the laptop, under where the screen was.
17. Remove 8 long screws labeled P from back of laptop
18. Remove 2 short screws labeled P from hard drive slot.
19. Remove 2 silver screws labeled P from the top of the laptop. The screws are close to the power switch and to the right of where the fan was located.
20. Lift off laptop cover by unplugging the Mouse ribbon cable from the motherboard by lifting the outermost edges of the Mouse ribbon cable connector.
21. Remove motherboard screw labeled TH15
22 Remove Hard Drive Caddy by removing 4 screws.
23. Remove 2 silver VGA output screw/nuts
24. Unplug Speakers
25. Unplug screen switch by disconnecting CON4
26. The Mother Board is free to be removed.
  • Anonymous Mar 15, 2014
    star screw rounded out by ill fitting screwdriver. Now jammed in
The teardown information from rbrown67 was very accurate and easy to follow. It helped tremendously in tearing down my machine to replace the AC plug.
Posted on Mar 26, 2008
    Master:
  • 351 Answers
Dear RBROWN67,
you can find the service manual for you DELL Inspiron1000 Notebook , from these URLs:
http://support.dell.com/support/edocs/systems/ins1000/en/index.htm
http://repair4laptop.org/disassembly_dell.html
Hope these sites are helpful for you in future also.
Cheerup and Be Happy always
Posted on Mar 14, 2008
  • tinybeeber Feb 01, 2011
    There is no Service Manual for the Inspiron 1000. The first URL is the Owner's Manual and the second URL has no associated manual.
How do I disassemble a Dell 948 printer?
Ron Worth,
Dell does not have any disassemble instructions for the printer. You can click the link below for viewing the online manual.
Dell 948 AIO Printer
http://dell.to/1vAFZ3R
Thank You,
Dell-Jesse L
Dell Cares
Dell Social Media and Communities
Nov 30, 2014 | Dell 948 All-In-One InkJet Printer
1000-0143 Dell error
This error code is related to " Drive Smart read command failed."
POSSIBLE LINK to fix: -
http://support.dell.com/support/topics/global.aspx/support/kcs/document?c=us&l=en&s=dhs&docid=266787#HDD
Remove and reinstall the Hard Drive for the error codes:
  • 1000-0141
  • 2000-0141
  • 1000-0142
  • 2000-0142
  • 1000-0143
  • 2000-0143
  • 1000-0144
  • 2000-0144
  • 1000-0145
  • 2000-0145
  • 1000-0146
  • 2000-0146
  • 2000-0151
Please see the Service manual for instructions on how to remove and replace the Hard Drive. Be sure to remove and reinstall the cables for the hard drive if you are on a Desktop Computer.
After reinstalling the hard drive re-run the diagnostics if you receive the same error code Contact Us.
Run the Drive Self Test (DST) from the Utility Partition also known as the 32 bit diagnostics to determine if the previous error has been corrected. If the DST from the Utility Partition does not indicate a failure of the drive, we consider the error to have been corrected and the drive does not need to be replaced.
  • 1000-0146
  • 2000-0146
Mar 04, 2012 | Dell Latitude D810 PC Notebook
How do i restore to factory settings my Dell Vostro 1000
Try here...(http://support.dell.com/support/topics/global.aspx/support/kcs/document?c=us&l=en&s=gen&docid=DSN_336966&isLegacy=true#Issue3).........or here........(http://www.techsupportforum.com/forums/f108/solved-dell-vostro-1000-restore-from-recovery-partition-issue-445057.html)
Nov 20, 2011 | Dell Vostro 1000 Laptop
How to remove the back off an acer 5532 laptop
Which back do you mean? The cover that hides the Ram/Hard Drive etc... or would you like to disassemble the Machine?
Since you didn't mention the specific task you would like to do, I am unable to give you the specific instruction. Please check out the following tutorials:
1. How to disassemble and replace the keyboard
2. How to replace Ram
3. How to disassemble
If you need further help, let me know with more details.
Good Luck.
Thanks for using FixYa.
Jan 11, 2011 | Acer Aspire 5315 Notebook
I have a virus on my computer and hadn't turned it on in months, when I finally tried to get someone to look at it, I turn it on and it asks for a HDD password that I know nothing about. I am the first...
During the boot up process you will see on the screen press a certain key to enter set up
Press either delete or f2 during the boot up process to enter BIOS scroll down to set user password or supervisor password you can change or remove your password from there
hope this helps
Nov 24, 2010 | Dell Vostro 1000 Notebook
I forgot my bios password on my dell inspiron 1000. please can someone help me solve this?
Remove and then Re-insert the Battery Cell installed on your motherboard.
Hope That Help
Jun 28, 2010 | Dell Inspiron 1000 Notebook
How to replace a keyboard on dell inspiron e1505
The Inspiron 6400 and the E1505 share the same disassembly guide. Follow the link below to see an illustrated view of this procedure.
http://ahwee.com/how-to-disassemble-laptop-insp6400
Jun 01, 2010 | Dell Inspiron E1505 Notebook
Alot of keys aren't working.
================================= I have the same problem wih my Dell Inspiron 8000 and it had a keyboard issue with keys I, J, N, PgUp, H not working.
ut when I took off my keyboard and reseated the ribbon connector and it's been working since then.
=================================== Please read instruction for keyboard replacement: http://support.dell.com/support/edocs/systems/ins1300/en/sm/keyboard.htm =================================== If it still not working I suggest you get a keyboard replacement. ================================== Disassembly Tutorial for your Laptop: http://www.insidemylaptop.com/remove-motherboard-repair-dc-power-jack-dell-inspiron-1300-b120-b130-laptop/ ==================================
Let me know if you need further assistance. Please Rate. Thanks and More Power!
Apr 23, 2010 | Dell Inspiron B130 Notebook
I have inspiron 9300 and my screen has developed 5 vertical lines.repair or replace and cost please
Usually this issue isn't repairable, but is fixable by replacing the screen. This can cost from $75-$200 for parts depending on your model alone.
There are a couple on E-Bay for about $100-$125 for your model. I would recommend finding someone that has experience replacing computer monitors.
If you feel comfortable replacing it yourself (make sure you take the necessary precautions), you can find the Service Manual from Dell with disassembly instructions at the following link.
http://support.dell.com/support/edocs/systems/ins9300/sm/index.htm
Oct 26, 2009 | Dell Inspiron 9300 Notebook
Dell Inspiron 1000 Notebook Logo
2,431 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
