Question about Fisher and Paykel IWL12 Top Load Washer
My washing machine wont drain the water
At the end of the washing cycle , i normally can hear a thump and then the water drains , then followed by rinse , wash , drain , spin dry.
right now it doesnt drain so cannot continue . please help
  • 2 more comments
  • missdianna Jun 30, 2008
    I HAVE A FISHER & PAYKEL SMART DRIVE 708 IT WASHES BUT AT THE END OF THE WASH IT WONT DRAIN THE WATER AND GO ON TO RINCE OR SPINE IT HAS A HUMMING NOISE PLEASE HELP
  • jacobsarah Aug 29, 2008
    i have the same prob. was wondering how to get to pump fan. it is full of water and i got agitator and tub out but cant find pump fan. also there is a humming sound as well. the diagnostics say a pressure tube fault???
  • Anonymous Sep 03, 2008
    My Fisher and Paykel top load washing machine, will not drain or spin. It's only two and a half years old. What's up?
  • Anonymous Mar 29, 2014
    After setting the program to wash, the water doesnt drain out.
  • 30 Answers
Sounds like a blocked pump.The pump could be burnt out.
Posted on Aug 03, 2008
    Sergeant:
  • 351 Answers
If its making a humming sound the pump may be blocked turn the pump fan by hand to see if its free,
Posted on Mar 15, 2008
Cycle has stopped 31 mins from end and has lit up check water. No blockage and this should be the drying cycle. Is this a repairable problem or not as it is old?
On many older machines, there was only one water pump. During the wash and rinse cycles, the pump would cause the water to spray the inside of the cabinet. At the end of the cycle a solenoid would open a valve and the pump would then cause the water to be sent to the drain. There are a couple of ways to check for this. Ordinarily, you would hear a knock or thump when the solenoid operates. Another way to tell is if you still have a lot of food particles during the rinse cycle - particles that should have been drained out at the end of the wash cycle.
Some solenoids were not particularly expensive and are fairly easy to replace. If you post your make and model number, I can get more information for you.
Apr 05, 2016 | Dishwashers
Dishwasher draw not emptying water at end of washing cycle
I am assuming you have a Fisher Paykel or similar double drawer dishwasher. Based on your symptoms it is very likely there is dirt or some blockage in the drain sump which needs to be cleared. If you have followed the normal procedure of cleaning filters etc, and there is no difference then you will have to take a thin rigid metal wire and run it through the channel between the rotor cavity and the drain sump. There could be a seed or a bone chip sitting there. I am assuming the pump rotor runs normal and you can hear water flow through the drain hose into outlet drain. Please provide make and model number of dishwasher for help with better diagnostic.
Aug 28, 2014 | Dishwashers
My Simpson Eziset 550 will not drain after a (normal) wash cycle. When the drain hose is lowered to the floor drain water flows heavily from the hose (gravity). When the hose is returned to the sink d
Hi Erin just read your post,I have worked on these machines alot.Now I need you to manually drain the machine of all the water. Once drained i want you to select drain and spin cycle. Now push the start button,do you hear the pump working?If you do stop the machine and select normal cycle on small water level and push the start button.The machine will then fill.Once it stops filling stop the machine and select drain an spin cycle.Does the machine pump out? Now if you do not hear the pump, could be the pump is faulty or jammed.Does the water flow very fast when you lower it to the floor? Please reply with answers to these questions and I will try my best to help you.
Jan 25, 2014 | Washing Machines
I have a Maytag Quiet Series 200. In the beginning of the cycle, it makes a weird 'whirrrring' noise that goes away right after the first wash cycle. It's getting water. It's very noticable and I worry...
I have a quiet series 300 and it does that, too. I think it just balances the load before washing and is normal. I found this in the manual:
Normal Sounds
Your new washer may make sounds your old one didn
Sep 05, 2010 | Washing Machines
You can hear water behind the drum when you spin
I don't believe you have a problem with your washer. It is NORMAL to have residual water in the drain lines and drain pump following a wash cycle. You will be able to hear the water sloshing around if you move the drum or drain lines. This is the lowest point of the drain cycle and gravity will ALWAYS cause some water to be there. As long as the water is not visible in the spin basket inside the drum, and the washer is properly draining during the wash and rinse cycles, you have nothing to worry about.
If you have any questions, please post back and let me know. I hope this is helpful to you.
May 12, 2010 | Maytag Neptune MAH5500B Front Load Washer
Is some water in the tub of a top loading washer normal?
It is normal to have residual water in the drain lines and pump following a wash cycle. This is the low point of the drain cycle and gravity will ALWAYS cause some water to be there. As long as the water is not visible in the spin basket, you have nothing to worry about.
Some model washers also have a balance ring around the perimeter on top of the wash tub that is filled with fluid. This acts as a stabilizer to help keep the washer balanced during the spin cycle. If you have any questions, please post back and let me know. I hope this is helpful to you.
Apr 21, 2010 | Whirlpool WTW5200S Top Load Washer
Westinghouse LF708B washing machine wont spin,drains but wont spin Use to work when you thump machine but now wont spin at all
I have found that it is a blockage I manually drain the water through the botton of the machine then the cycle continues as a short term fix. I am not a professional though
Mar 09, 2010 | Westinghouse Washing Machines
Washing machine wont drain keeps bleeping ERR2
It will not spin with water in.
See if you can locate a filter, and clean same.
Jan 19, 2010 | Haier Washing Machines
Loud noise, then not so loud, but now electrical burning smell and little draining
the smell is your clutch and the lack of draining is a clogged washer drain protector. see these at www.repairclinic.com drain protector is part 541811 and clutch is 2670. go there enter model number and scroll down to the red 100 click it and look for these part numbers.
Mar 02, 2009 | Whirlpool LSR5132PQ Top Load Washer
Water wont drain from Machine or go onto spin cycle
either the level control switch has become blocked or faulty or the drain pump has become stuck.
disconnect from the mains and gain access to the rear look for a circular unit with two or three electrical connections and a plastic tube. this is the level control.follow the tube to its start and you will find a plastic connection that goes into the wash drum, remove the plastic tube from the switch end and blow into it. if there is no restistance then the system is OK at the drum end. next reconnect the tube to the switch and remove the opposite end, very gently blow down the tube and you should hear the switch operate. Test wether the switch is working by putting a meter across the switch and blow into the tube. if all of this is OK then the drain pump is at fault. locate the drain pump. it is connected to the outlet tube, try turning by hand. if it does not rotate smoothly remove the clips holding the pump body together and clear the obstruction.
Dec 27, 2008 | Hotpoint Aquarius WF210 Front Load Washer
Fisher and Paykel IWL12 Top Load Washer Logo
484 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Gerry Harvey
Gerry Harvey
michael_t919
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
