Question about Microsoft Xbox 360 Console
Replacement Disc Drive
I bought a replacement disc drive for my xbox360. its the same make and model. the only thing different is the product number. when i install it it plays dvd's but it will not play xbox games. it tells me to insert disc in to and xbox 360 console. is there something i need to install like software or a setup i need to do?
    Problem Solver:
  • 13 Answers
As above but to elaborate a little more you should look into scenyx website forum for how to's (google scenyx).
You have to have some technical savvy however to be able to safely and properly do it.
Posted on Jun 13, 2008
  • 3 Answers
You need to get the firmware from your original drive.
Each xbox drive has a unique number in the firmware that marries the drive to the console. so dump your firmware from original drive and flash it to the new drive
Posted on Mar 26, 2008
3 Suggested Answers
  • 92 Answers
SOURCE: When I put any game
An OS File Has Been Overwritten. Call Microsoft And Tell Them What Your X-BOX 360 Says. They Should Replace The OS
Posted on Jul 02, 2008
  • 25 Answers
SOURCE: when I insert a disc into my xbox 360 it loads
this happens to me also periodicly. just turn the console off and back on again. sometimes i have noticed that the position of the cd in the tray helps
Posted on Oct 07, 2009
Is there a disc that can fix a Dell 0147 optical error?
There is a slight possibility that a cleaning disc might work. They are basically a CD with mini brushes on them to clean the lens of the laser that reads the information from the disc. There is a chance that the drive's motor's or electronics on the inside have gone bad as well. I would say that the best way to tell the difference between the two situations, is to judge how much the disc drive has been used.
f you haven't used the drive in over six months, then the lens might need to be swept free of dust. On the other hand if you use the drive often for tasks like data backup, watching DVD's, or playing games that require a disc be inserted; then you probably have a disc drive that has failed and needs to be replaced. Some Dell's like the D630 that I have make replacing the disc drive really simple, but other models take more patience. Generally a replacement disc drive for a laptop is only 50-75$ at an on-line auction site like E bay.
There is a slight possibility that replacing the firmware for the disc drive could fix the problem. I would recommend Leaving any firmware upgrades to professionals, or tech. savvy friends. Firmware updates can break a drive completely. For example if the wrong drive manufacturer or model was updated, it could potentially brick your disc drive. By the way brick is a tech. term meaning to break beyoned repair rendering it completely useless.
the cheapest thing to do is get a CD cleaning kit. You might even be able to find one at the dollar store. Please don't be disappointed if this does not work. That means that the next logical step would be either replacing the internal disc drive, or buying an external disc drive.
Aug 31, 2011 | Computers & Internet
Tip
How to resolve Xbox 360 disc read errors. Xbox will not play disc.
Is your xbox360 having trouble reading disc? In this guide I will provide some common solutions to help you fix your disc read issues.
1)Remove any memory devices or usb flash drives.
2)If the disc you are using is excessively scratched, this can cause the xbox to have trouble reading the disc. You can use a damp soft cloth to try and clean the disc. Grab the disc by the edges and using a soft damp cloth lightly wipe the disc from the center going outward.
3)Try removing your Xbox hard drive and then play a disc. Turn off the console. Locate the hard drive on the top of your system(depending on how you have it positioned). Press the release button on the hard drive.
If your system can read disc without the hard drive attached then you may need to replace the drive.
4)Clear the Xbox360 cache. Clearing the cache may remove updates to certain games. Keep this in mind.
Go to System Settings in the My Xbox menu. Select Memory, highlight your storage device and select Clear System Cache. Try and play the disc.
If after the above steps you are still having trouble. You may want to contact Microsoft Xbox live support to have your system serviced. You can find the support information in the link below,
Xbox Support
Regards,
G33k
Visit the links below for other technical articles
Connect your Nintendo Wii to the internet
Connect your Xbox 370 to the internet
Connect your Nintendo DSi to the internet
Connect your PlayStation 3 to the internet
How to access Windows 7 God Mode
Tips to clean and speed up your computer
How to configure a wired/wireless home connection
How to access facebook when it is blocked at school
Extensive list of device driver links for common electronic devices
Keywords
xbox 360 disc read errors, xbox 360 disc read, 360 disc read errors, xbox disc read issues, xbox 360 disc read issue, xbox 360 scratched disc, xbox360 disc not playing, xbox360 cant play disc, xbox360 disc will not play
on May 14, 2011 | Microsoft Xbox 360 Console
My console keep saying open tray and won't read any disc
this is a very annoying problem when the disk drive is going bad (sometimes you can tap the top of console while its loading and it will read) you will need to send it off to get it fixed which is about the same cost as getting a refurbished console now or you can take console apart and change it yourself. takes about 30 min to do this. There are several different disk drive open them and you will see marking on disk tray Mitsubishi/samsung/benq are the ones I've fixed and repaired so far check out youtube under xbox360 disk drive replacement for visual guide if you don't know how and http://www.llamma.com/xbox360/Xbox_360_DVD_Drive_Comparison.htm to determine which drive you have and shop around for best price. good luck
Dec 22, 2010 | Microsoft Xbox 360 Console
My xbox360 says unrecognized disc
The laser could be dirty, or wearing out. Try to us a disc drive cleaner CD and see if that helps. If not, something in the drive (ie the laser) is going bad and will need a replacement. If you have warranty available contact Microsoft. If not, it's a rather simple process to change the drive and I'm sure someone local can get it done for very low cost.
Jan 10, 2010 | Microsoft Xbox 360 Console
I put a game in and it kicks it right back out
Hi
The problem you are facing is possibly due to a white lever near the dvd tray that is out of alignment, how do you align your console while playing Horizontal or vertical ?
try changing console position and check if it makes any difference, do not try experimenting much if your console is under MS support warranty, send it straight away for repairs they would replace the dvd drive for you
Nov 24, 2009 | Microsoft Xbox 360 Console
Games wont read
If you have the problem where the Xbox 360 will not read your discs then you need to stop the sensors overheating and to do this you can send it back to Microsoft or fix it yourself
Best XBOX 360 Disc Drive?
Hi, first let me say that as far as the DVD drives go I don't really think there is a significant difference in any of them. It basically boils down to who offered Microsoft a DVD drive cheaper. Next, I would strongly recommend that you get the same model/part number DVD drive.Reason is that you will have to do alot of work trying to get a different drive to work in your system. such as "flashing the drive" or having to change the sisterboards to make it work.
Aug 11, 2009 | Microsoft Xbox 360 Console
Blank DvD Disc Reading Problem
Goto HP's website to the support section download the drivers and replace your current ones. If it still does not the drive has failed and needs replacement.
Thanks Frank Z.
http://www.codebluehelp.co.cc
3868607368
Jun 29, 2009 | Computers & Internet
Xbox will not read any game or dvd
It sounds like your DVD drive has failed, this is fairly common. There is a good chance it is still under warranty from microsoft. Give them a call at:
800-4-My-Xbox
If it is not under warranty you can replace the dvd drive itself, google xbox 360 replacement parts. It's not too difficult if you are technically inclined.
Jun 25, 2009 | Microsoft Xbox 360 Console
Xbox360 game will not read
If your xbox is modded try a different brand of disc.
Obviously try and clean the disc itself.
Else your dvd drive is faulty and needs to be replaced
Mar 17, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
