Question about Sony Playstation 3 (PS3) Console
Wireless signal strength boost
Is there any way (or anything) that I can use to boost the wireless reception for my PS3 ? I cannot move the router [wirelessN] in my house because of the other computers and the signal strength to the PS3 hovers around 25% - not good enough. Doees anybody know of a way to boost the signal strength @ PS3 ? - a device, etc.. [ unfortunately running hard Ethernet is not an option at this point from the router]
  • 4 more comments
  • Quiggs Apr 28, 2008
    I just bought a 40GB PS3 becaue I can experience wireless online play . The only deal is I can only get a 50% signal strength and constantly have problems getting COD4 online. And when I do get online and finally start a game, I'm cannot play, I can only hear the game while watching my screen say I'm setting up...for the entire match!!! ARGGHHHHH
    Since the router is built-in is there anything that can be done to boost the strength?
  • hunda4 Jun 06, 2008
  • sammydave9 Jul 18, 2008
    I'm only getting a 25% signal on my ps3 but my pc gets 85% and I cant play cod4
  • Anonymous Nov 05, 2008
    Trouble is, I "borrow" wireless from my next door neighbour - how do I boost the 20% signal I get, which is fine for some functions but not full game online play?
  • Anonymous Dec 23, 2008
    same problem low signal no way to move router ne closer plss help
  • Hardcor_Punk Jan 10, 2009
    i have the same problem as basher99 i can connect wirelessly to the internet but have anywhere between a 17%-a 35% signal strength and i cannot move my router and i do not have the option to go wired at this point please help someone im tired of getting disconnected!!!!
What you need to do is turn a large pringles tube inside out after cutting it open so the metal bit is exposed then make it into a cone and wedge the thinnest end into a USB port.  This deffinately works :D
Posted on Sep 19, 2008
Take back the router and get wired connection using only a ethernet cable
Posted on Jun 29, 2008
  • 58 Answers
Depending on your router, you can grab high gain antennae for it and you should see a dramatic increase in range...
Posted on Mar 14, 2008
How can i boost and speed up my Wifi network reception ?
Firstly download WiFi Analyser from Google Play store and compare you WiFi with others in your area. This will enable you to change the channel. Change channel by logging into your router - 192.168.1.1.
Try moving your router to a more central place in your home and use the analyser to check if any improvement.
Next try a wireless extender. This will drop your speed a little but give a stronger signal in weak areas.
Also try power line adapters.
If you are using a few devices ensure that you are not mixing wireless g and n products at same time. Using a g product will mean that your whole wireless will be running at that speed even when your other device is n. If you need both connect another g router to one of the n router LAN ports with dhcp disabled. That way you can have the two devices connected at the correct speed.
Some routers will let you connect a bigger aerial which could boost you reception. Some devices have very poor wireless antennas - seems you what you pay for in this area.
Apr 16, 2014 | Android Apps
Are there firmware updates? My iPad is dropped from wireless intermittently.
im not really familiar with the ipad but my best guess is your wireless router signal strength is what is causing your ipad to drop. No firmware update is going to fix that. i would recommend downloading a wifi analizer from the app store to get a reading on your dbm (signal strength) from your router. the dbm scale will be 100 dbm(best) to -100dbm anything below like -50 dbm and you will start seeing disconnects.
I would either A. Invest in a wireless n standard router or buy a repeater to boost your signal.
Comment if you need additional assistance.
Aug 03, 2011 | 2wire (2701HG-B) Wireless Router
I continually loose connection to my wireless connection with my home router and also at hotels I stay at. it will just drop the connection for no apparent reason
Laptops have an internal wireless antenna that receives the signal from the wireless router/access point. The performance of these wireless cards varies widely from manufacturer to manufacturer and sometimes even from model to model in the same brand. Issues effecting reception are distance between laptop to router, obstructions (many commercial buildings use metal studs which can significantly reduce signal strength), electrical interferance and other things.
While there's not really any way to boost the reception of the wireless card in your laptop, you CAN purchase what are called 'hi-gain' wireless cards from various manufacturers such as Netgear, Linksys, and many others. These so called hi gain antennas can pick up a signal from as far away as 1/4 mile in some cases. If you can't figure out what's causing the problem with your laptops' wireless card, purchasing one of these cards might be a good solution for you.
Best of luck! Hope this helps!
Jun 21, 2011 | ASUS K52F-BBR5 Notebook
How do you fix the error code 80710723?
Remove the connections you have to your wireless network on your PS3, then set it up again. Your PS3 might also be too far away from your router. If you're getting this message frequently, I would call your ISP or the manufacturer of your router and try to boost your wireless signal strength.
Jan 22, 2011 | Sony Playstation 3 (PS3) Console
How to boost wireless signal on ps3
If you are talking the wireless for the controllers they use bluetooth and the signal strength is dependent on how much interference there is around you. If you are speaking of the wifi capability for the network connection you cannot increase the strength of the signal from the PS3 it needs to be done with the wireless access point.
Feb 11, 2010 | Sony Playstation 3 (PS3) Console
Signal strength bad between PS3 & D-LINK DIR-655 Wireless Router
Most likely it is the antenna for the router. Try changing the position or location of the router. The slightest twist or tilt of the router will affect the reception. A little bit of messing with it may improve your signal. Obviously the closer you can get it to your ps3 the better.
Sep 10, 2009 | D-Link Xtreme N DIR-655 Wireless Router
When I go into other rooms I can't connect to router
How is the signal strength? Check and make sure the antennas are not loose. Is your house the old style concrete? Sometimes thick block or concrete walls are tough for the wireless signal to get through. They do make larger antennas or signal boosters for wireless routers. You may need to install one of these to boost signal strength. Also is it wireless B,G,or N? Wireless B has a very weak signal while wireless N has a very strong signal. Sometimes the router settings can be changed to adjust the signal strength and may be set too low also.
Sep 05, 2009 | Linksys Wireless-G WRT54G Router
Signal dropping out when useing netgear adapter
You may find that either the signal strenf=ght is not there or there are other devices near by on the same channel as the router.
Use THIS app to test the signal strength and check the channels is use also
You may want to either move the router to a higher postion (on a shelf) or get an external antenna for it to boost range. Be aware that cordless phones are a source of interferance so thias may affect signal strength, reception etc. Put some distance between such devices and the router/widfi card etc.
Jul 06, 2008 | NetGear : WG111 54 Mbps Wireless USB 2.0...
Boosting Signal Strength
Greetings,
It is more likely the placement of the router an/or PS3. If possible do not place anything on top of them and make sure there is space around the units.
You can try using a repeater which will amplify your wi-fi signal. A repeater is a small box that will lock onto your wifi and extend the range of your current router. Here are some examples:
http://www.amazon.com/s?ie=UTF8&search-alias=electronics&field-keywords=wireless%20repeater&page=1
You can also try the cheap solutions found in these two videos for boosting antenna strenght:
http://www.youtube.com/watch?v=sUTT8wdN_VA&eurl=http://lifehacker.com/software/lifehacker-top-10/top-10-wi+fi-boosts-tweaks-and-apps-306436.php
http://www.youtube.com/watch?v=LY8Wi7XRXCA
If that helped please rate me well.
-WN
May 14, 2008 | Sony Playstation 3 (PS3) Console
No signal
If this model has a antenna, check its connecting with the router. Try resetting the router. Also some labtops have a worse signal reception strenght when they are not plugged in, so try plugging it in if you havent already.
Mar 25, 2007 | D-Link AirPlus DI-524 Wireless Router
Sony Playstation 3 (PS3) Console Logo
4,064 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
