Question about LG 24 in. LDS 5811 Built-in Dishwasher
Does not fill with water e1 code
Does not fill with water ie code
    Scholar:
  • 106 Answers
1E means - Water inlet problem >Condition : Not reached to the normal water level in spite of 10 minute water supply
Water supply problem. The inlet hose is kinked. The water pressure is to low (10psi) Inlet valve. The inlet water valve filter is clogged. The hall sensor. The impeller of Air guide is bound. Remedy : Check resistance of inlet valve ( 950-1300ohms) Clean valve. Check pressure. Replace the Air braker.
Posted on Mar 30, 2010
SOURCE:
Hi. I’ve got a HAAS deluxe HWA140SNN too loader washing machine. It’s coming up with a E1 code after about 3 mins during the water filling. What is that ? How can I fix it ?
This is a 'fill error timeout'. Can be caused by low water pressure from blocked filter cups, low mains pressure, faulty isolation valve, or blocked hoses. Can also be a faulty water inlet solenoid which is not opening far enough for a good flow of water. In normal circumstances you hear it RUSHING into the machine rather than TRICKLING.
Haas washing machine E1 code Google Search
Nov 18, 2017 | Washing Machines
Error E1 for washing machine
Lots of info on E1 for different makes.
  • How to repair a Samsung washing machine with error code E1 ... https://www.quora.com/How-do-I-repair-a-Samsung-washing-machine... How do I repair a Samsung washing machine with error ... If your Samsung Washing Machine is showing error code E1 then ... How do I clear bosch washing machine error ...
  • E1 error in washing machine? ' Yahoo Answers https://in.answers.yahoo.com/question/index?qid=20131129013237AA7oiKP
    • RESOLVED
    • 7 POSTS
    • 6 TOTAL ANSWERS
    2013-11-29 · E1 error in washing machine? ... Haier washing machine error code E1? LG Wave Series Washer LE error message? Washing machine error code? ...
  • My washing machine is displaying an error code. What does ... www.samsung.com/my/support/skp/faq/1033803 My washing machine is displaying an error ... E1. Water supply error. ... · Check that the level of the drain hose is not lower than the base of the washing machine.
  • Related searches for Error E1 for washing machine
  • Samsung Washing Machine 4E and E1 Fault - Help & Advice https://www.northlondonappliancerepairs.co.uk/error-codes/samsung...
    • 4.3/5
    • 46 RATINGS
    Samsung Washing Machine 4E and E1 Fault. Samsung washing machine Not filling in allocated time error code 4E and E1 Fault.
  • Help & Troubleshootings - Haier ZA Products Website www.haier.com/za/help_and_troubleshootings/faq/washing_machine Help & Troubleshootings. ... Too much water in the washing machine ... Error Code-control panel display "E1" Question : Error Code-control panel display "Lock"
  • Samsung washing machine error code 4E and E1 Fault Not ... www.youtube.com/watch?v=cFlnxeB0P0g
    • BY HOW-2-REPAIR.COM
    • 9 MIN
    • 19K VIEWS
    2015-11-24 · Video embedded · ... machine-error-code-4e-and-e1-fault-not-filling-in-allocated-time/ Samsung washing ... Samsung washing machine error code 4E and E1 ...
  • Samsung washing machine error code 4E, E1, Fault Not filling www.how-to-repair.com/help/samsung-washing-machine-error-code-4e... Samsung washing machine Not filling in allocated time error code 4E and E1 Fault This is essentially a fill timeout error which will normally mean that either the ...
  • Hoover error code E1 - White Goods Help www.whitegoodshelp.co.uk > ... > Washing Machine Error Codes Hoover error code E1. ... You need to watch the washing machine to see when it aborts to get an idea which of the three areas to look at.
  • Jul 01, 2016 | Washing Machines
    HOW DO I STARTS MY WASHING MACHINE AGAIN CAUSE IT ALWAYS `IE` ERROR EVEN I ALREADY CLEAN THE FILTER,CHECK HOSE,THIS ERROR HAPPENS WHEN SOMEONE USE IT MANUAL WHEN NO WATER IN SERVICE,I MEAN HE MANUALLY
    The IE or E1 error or fault code indicates that the washer is not filling with water. Check to be sure the water supply valves are open. Also, check to be sure the water supply hoses aren't kinked or clogged. Next, remove the hoses from the washing machine and run water into a bucket to test the pressure and flow of the water. If all of these check out and you have good water pressure and flow to the machine, you should replace the water inlet valve
    If you are trying to use the machine manually, there needs to be enough water in the machine to tell the level sensor when to switch off the water inlet solenoid valve. Failing this, the machine will only show IE (Inlet Error) and refuse to work.
    Feb 15, 2015 | LG WD-1070QDP 7 Kg Direct Drive Washer
    LD-2040WH
    The IE or 1E error or fault code indicates that the washer is not filling with water. Check to be sure the water supply valves are open. Also, check to be sure the water supply hoses aren't kinked or clogged. Next, remove the hoses from the washing machine and run water into a bucket to test the pressure and flow of the water. If all of these check out and you have good water pressure and flow to the machine, you should replace the water inlet valve.
    Aug 27, 2014 | LG Dishwashers
    HOW to fix E1 code for LG direct drive washing machine
    Aug 25, 2014 | LG Washing Machines
    What is E1 error code
    The E1 error code indicates a water inlet error. Do you still have your manual to test for this?
    Jun 20, 2014 | Kenwood KDW243A Builtin Dishwasher
    HOW TO CLEAR CODE E1 ON LG DISHWASHER ?
    The 1E error or fault code is to indicate that the washer is not filling with water. Check to be sure the water supply valves are open. Also, check to be sure the water supply hoses aren't kinked or clogged. Next, remove the hoses from the washing machine and run water into a bucket to test the pressure and flow of the water. If all of these check out and you have good water pressure and flow to the machine, you should replace the water inlet valve.
    Jun 13, 2014 | LG LDF7561ST FulIntegrated Dishwasher with...
    LG dishwasher error code E1
    E1 is a code that the dishwasher displays after detecting a leak. There is a sensor on the pan at the very bottom of the unit. Take the bottom front panel off, look under the unit at the hose coming off the pump and your fill line to be sure no water is dripping. Run the unit in a wash cycle while doing this if possible.
    Nov 21, 2017 | LG Dishwashers
    E1 error code on my kenwood dishwasher [kwd243a
    Hi
    The E1error code indicates a water inlet error.
    To access test mode: press and hold Normal+Eco, and press Power. Release buttons. Then press Start(display n:01).Press Start again (display shows water level frequency-not important). Press Start again-(display n:03-motor will be running). Press Start again (display n:04-drain pump will run). Press Start again (display n:05-inlet valve will come on and machine should fill with water). You have now tested major components are working-if you keep pressing start you will scroll thru and test other functions, like heater, dispensor etc, but not needed for your fault.
    If Machine didn't fill with water in test mode, you probably have a faulty inlet valve (test resistence should be approx 3.7-4 k ohm).
    If inlet valve has tested OK ie machine filled with water in test mode then:
    Disconnect from power.
    Remove side panels (need to remove top, and bottom front panel to then be able to remove sides)
    - Check no water in base of machine-water in base will indicate machine has leaked and activated the safety device which shuts off inlet valve.
    - If OK, you probably have a faulty flow meter(measures water intake). Located left hand side of machine, large plastic compartment, which has a sensor at the bottom with 3 wires (red,white,black) that go up to control board. Replace entire flow meter assy-relatively inexpensive part.
    - If you still have problem, then control board is faulty, it is much more likely to be flow meter .
    Thanks for contacting fixya.com
    Sep 10, 2009 | Dishwashers
    E1 Code - tried fixing it according to manual still won't work
    The error code E1 = Water supply error -Not enough water entering the W/M.
    Try check water supply line is on and not have any kinked.
    Mar 21, 2008 | Samsung WF337AA Front Load Washer
    LG 24 in. LDS 5811 Built-in Dishwasher Logo
    405 people viewed this question
    Top LG Dishwashers Experts
    Marvin
    Marvin
    Mike
    Are you a LG Dishwasher Expert? Answer questions, earn points and help others
