Intel Pentium IV Trouble (40gig)
When i start to open my PC Laptop, it strted to post on the monitor screen ' Operating System Not found' then the laptop sounds so noisy thats why we try to replace the hard disc but when we again start to switch on the monitor was totally black out and nothing was seen...what to do and how to fixed this problem? please help
  • deadpoet Jul 24, 2008
    when i turn on my laptop it say " operating system not found" but if i try it more like a hundred times ( more than an hour of trying switch on/off) windows starts up and i can use my laptop. Pls email: deadpoet77@lycos.com. thanks.
  • 520 Answers
Os not found usually means that your hd is faulty.
try remove hd and reseat it.
if no joy have os disk(windows) in cd drive start pc and boot from disk.
select install windows...system checks drive and informs of existing os..want to continue...install windows...next screen shows partitions.choose to delete partition then create new then format and install.
if when u try to boot from disk system say no hd found then hd is damaged.
Posted on Mar 14, 2008
When I power my desktop up it shows the Welcome screen and then seems to go into sort of a hibernation mode. My monitor goes black, except that I can still see the white arrow that moves with my mouse. I...
When you first power on the computer tap the key. If you get the boot menu then more then likely you have a video software driver issue when your computer tries to load the operating system. Only recourse is to fix the conflict or reload OS ( operating system).
Apr 24, 2011 | Dell Inspiron 560 Desktop Computer (Intel...
Can 1gb ram supports tally software with atom processor
System Requirements
  • Recommended Hardware Requirements for Tally 9
  • Pentium 4 and above or equivalent
  • 256 MB RAM
  • Minimum Disk Space: 40 MB
  • Operating System Software: Microsoft Windows 98/ME/NT/2000/XP
Hence, your system would definately support Tally.
Hope it helps! Good Luck!
CreativeTECH
Mar 19, 2011 | Samsung Netbook / Intel Atom Processor /...
I have dell gx270 tower pc with 2.6gh procesor(800mh).what higher processr of what specification can it support?
Hello
I did some research into your motherboard for that dell and found that it uses the Intel 865G motherboard. Which uses Intel Pentium IV Socket 478 proccessors.
Any Socket 478 Pentium IV processor will work in that board. the best processor I could find for that was the Pentium IV 3.4Ghz but it was $231..
However, I did find the Pentium IV 3.2Ghz for only $15.99. that seems to be the best deal to me. That would be a fair speed increase, an extra 0.6Ghz or 600Mhz.
Here is the link: http://www.geeks.com/details.asp?InvtId=P43200478&cm_mmc=GoogleProducts-_-CPUs/Processors-_-Socket478(Pentium4)-_-P43200478&utm_source=GoogleProducts&utm_medium=ShoppingSites&utm_campaign=P43200478
Also if you need to get a new heat sync you can search for "Pentium IV Heatsync" or "Socket 478 Heatsync" in google or a sight like newegg.com
Enjoy!
Jan 31, 2011 | Dell OptiPlex GX270 PC Desktop
Hi, i own samsung syncmaster 740n Monitor, from last 5 days, black horizontal lines are appearing on screen.today it is work.black shaded lines are becoming more worst .. what could be the cause, ...
We need to narrown down the causes first by trying this monitor with a good working PC to make sure it is not monitor problem, we do not want to open uip the monitor unless we have to.
Post back what you find, if it is monitor problem then please read below:
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Oct 08, 2010 | Samsung SyncMaster 740N 17" LCD Monitor
No input signal on monitor after changing resolution
While booting press F8 , Go to safe mode and change the screen resolution and reboot the system.
Hope this helps
Siju.D
Nov 12, 2009 | Compaq Evo D500 PC Desktop
40gig hard drive pentium 4 2.4 ghz processor.
http://www.newegg.com/Product/Product.aspx?Item=N82E16829126005
Not great quality, but cheap. Should work fine with your computer.
Jun 25, 2009 | HP Compaq EVO D51S Intel Desktop PC -...
Display problem in Fujitsu LifeBook C Series(c-6631
the internal bulbs of ur monitor screen have deteriorated...the manufacturers are real smart, these monitors dont last forever. So if repair estimate is too expensive then replace the whole unit.
Always purchase laptop or notebooks NEW or never more than 5 years old.
May 24, 2009 | Fujitsu LifeBook C6631 Notebook
Processor
Not showing on the screen in the sense, is the Operating System [assuming XP] system properties window not showing the processor details? If its the case, generally some processors will have some issues with the Operating system.You can fix it by downloading some "hot fixes" from Microsoft.
Try this: 1.Open the "run" dialog box [Windows key + R] 2.Type "dxdiag" [without quotes] 3.Press enter. 4.You will be able to see the processor configuration in that window.
If not succesfull, please post. I will suggest another method.
Oct 29, 2008 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
Does not read dvd
Is This The lightScribe ?
Heres Some Basic Information, that may help Resolve Your Problems:-
Minimum system requirements Operating system Microsoft Windows XP and 2000 SP4 or later (the latest service pack is recommended). Interface IDE interface. Processor/RAM 800 MHz Intel Pentium III processor or equivalent , 2.2 GHz Intel Pentium IV processor or equivalent recommended. (Actual drive performance depends on PC configuration). 128 MB of RAM (256 MB is recommended for video editing). Hard drive space required 1GB free for software installation. 10 GB free for DVD video disc creation. 18GB free for double-layer DVD editing. Video resolution 1024 x 768 video resolution with a minimum of 16 bit color required for video capture, authoring, and editing. ** Please do note Rate This post Until Your problem Has Been resolved **
Thanks mike.
Feb 26, 2008 | HP dvd740i DVD±RW Dual Layer Burner
Computers & Internet Logo
191 people viewed this question
Alun Cox
David Payne
David Payne
