Question about Seagate (ST3160827AS) 160 GB Hard Drive
Usb write protect
How do you write protect your usb and undo this?
  • 133 Answers
Its a process which involves the editing of your registry, note that this will only work in the computer it has been edited. The usb can still be written into in another computer,
- Start > Run > type ‘regedit’ (without the speachmarks) > Enter
- Single-click on ‘My Computer’ > File > Export > save it to the Desktop (Always best to have a backup!!)
- Go to the following:
My Computer\HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\StorageDe vicePolicies
- Double click on the string ‘WriteProtect’ and change the ‘Value Data’ box to ‘0’
- Then: File > Export > save somewhere useful as something like ‘StorageDevicePolicies001.reg’
- You also need to do this for the strings in any folders called ‘ControlSet***’ (* = any Digit, i.e. 001, 002) – for example: Everything is the same, just change ‘CurrentControlSet’ to ‘ControlSet***’
My Computer\HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Control\StorageDevicePolicies
- Save these to the same place as before as ‘StorageDevicePolicies00*’
The saves are in case it reverts at a later date, just double click (saying ‘yes’ to importing these to the registry) on all of the files and it will all work again!
Posted on Mar 14, 2008
Undoing Write Protection On A Micro SD Card
These cards have a switch on them to protect them just change the position and you should be able to format it.
Jan 15, 2013 | Samsung 8GB Sandisk TF Micro SD Card Black
How to undo write protection
click start click to open on my computer you should see your usb drive E: right click select properties there will be an array of options
select the sharing tab option then advanced sharing make sure you have a tick in the share this folder box
then click permissions make sure you have all 3 boxes ticked full control changes and read in windows 7
click start control panel user accounts click on the administrators account if you have made one or you will have to create one in windows XP
click start right click on my computer select open
Right click the icon of your usb drive (It should be E:/ or something)
Click Properties in the menu that comes up
Click the Sharing tab
Click permissions
And finally, click Allow next to Full Control.
hope this helps you
Mar 27, 2012 | Electronics - Others
A new usb flash memory "write protected" ? how to undo this ?
Look for a place that slides on the stick itself. That locks so you don't accidently delete files and it will show 'write protected'. Most brands use a slider position type lock so just examine the stick and look for a slider or button that will depress and that should unlock it for you.
Jun 12, 2011 | Computers & Internet
I put a bit of music on my 2gb sd card later when i wanted to put more on i got message that card was write protected how do i undo that so i can use my card again
USB drives can be write-protected by modifying the StoreageDevicePolicies Registry key and WriteProtect Registry value.
click Start>run>regedit to open Registry Editor. and press control+F to open the find dialogue box and type "usb device" or "driverdesc" to open usb mass storage device or type "usb mass storage device" in the search windows. And right click on it and delete. This will set the policy value to 0. then insert your usb device. It will work fine.
# Remember: do not delete any unknow files in the registry as this will make some programes not work as usual.
also
If you are running a Windows XP OS then you might be able to:
- click start right click on my computer select open
- Right click the icon of your Flash Drive (It should be F:/ or something)
- Click Properties in the menu that comes up
- Click the Sharing tab
- Click permissions
- And finally, click Allow next to Full Control.
hope this helps
don
Feb 12, 2011 | Computers & Internet
How do I undo a write protected DS sport memory stick?
Write protect the media with the creation softaware. for example, word documents are lockable from the word document as copyrites. The medium may allow write protect as an alternate arragement discussable. First, acquire a medium only compartible with your computer simly is write protected from evry computer but yours.
Jan 29, 2011 | Computers & Internet
My MicroSD card is write protected and i need to remove and add MP3s how do i undo write protection?
hello flip the switch for write protection picture here http://static.commentcamarche.net/en.kioskea.net/faq/images/0-hXBUyBSB-t555-1122-callout-s-.png
Nov 04, 2010 | PNY 2GB microSD Memory Card
Cannot undo write protect
If you are talking about the shock sensor warning it is a hard drive protection that retracts the heads when the laptop is bumped and that will reset.
Oct 25, 2008 | IBM ThinkPad X60 Tablet PC
SanDisk 2GB microSD error message - Disc is Write-Protected
Re-format it. Put the SanDisk 2GB microSD memory card into your LG enV2 and format it from there. If that does not work plug it into your laptop then right click the icon and format it to FAT and click on default settings.
Sep 21, 2008 | SanDisk 2GB microSD Memory Card
Cannot Sync music files
okay... :)
1. the PC needs a CD-ROM with the cell phone's drivers to help interface the sync process.
2. you could transfer the files via bluetooth if both cell phone and computer have bluetooth components built in them.
3. if the PC tells you the memory card is write protected, look for a tiny little lock/unlock switch in the edge of the card to undo the "protect".
Hope this helps...
- J.
Feb 18, 2008 | Motorola Mobility MOTOKRZR K1 Cellular...
Seagate (ST3160827AS) 160 GB Hard Drive Logo
55 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Computer Links
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
