Web Cameras
Problem for Web Cameras
Generic problem for all Web Cameras
Problems with pc cam gigaware 25-297
By tolena1 on Mar 14, 2008
i download the driver and the software for pc cam gigaware 25-297 and still dont see anything what should i do
Same Problem
May 06, 2009
-   i can hear the other person but they can't hear me whats wrong with it -   Guest
Dec 03, 2008
-   driver-   anstaciante
Sep 16, 2008
-   Camera works perfectly (well-- it's black & white but that might be the CAM) on Ubuntu 8.04 but when I tried to install the second one on my Windoze XP box it failed (installer is the problem -   memeemeee
Jul 27, 2008
-   i try installing the CD for my Gigaware webcam but it won't install all the way but the green light on my cam is on it's just when i go to use it on www.stickam.com it says that my camera is not found in my system but it is plugged into a USB port and has the green light on.
what should i do?
can someone walk me through the process because i really want this to work
-   ashleyrachel
Jul 16, 2008
-   Same problem, not event the link with the driver helped. Would download and install the driver manually, but I have no clue what driver to download. Pointing the hardware installer to the downloaded "driver" exe doesn't work (didn't expect it too).
It's times like these that I'm thankful that my main computer is a Mac!
-   Guest
Best Solution
posted on Sep 18, 2008
Very Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Here is a quick fix:
1. Download the driver file from http://forums.driverguide.com/showthread.php?t=36528
2. Extract this file to C:\WINDOWS\PixArt\PAC207
3. Update camera driver with oem57.inf
4. During install you might be prompted to specified path to PFC027.SYS. Point to C:\WINDOWS\PixArt\PAC207
It will work as expected.
Enjoy!
Solution #2
posted on Jun 27, 2008
Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
I had the same problem with the 25-298. However when I didnt install the drivers, Windows found the hardware and it worked without needing to install anything. Then I installed the drivers and I got a message box that said "fail". The camera would not work after that.
My Gentoo installation couldnt detect the camera either. Bummer because its a 2.0 MP and I had GREAT quality when it was working. The drivers are horrible.
Solution #3
posted on Mar 14, 2008
Somewhat Helpful)
2Gigs
Rank: Wiz
Rating: 81%, 94 votes
You must check first if you have successfully loaded the drivers. GO TO DEVICE MANAGER. You should be able to see your pc camera listed there. If it is listed and it has a YELLOW QUESTION MARK, that means that the drivers for the pc camera was not installed. Install the drivers manually.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #4
posted on Apr 29, 2008
Somewhat Helpful)
Chuluman
Rank: Apprentice
Rating: 71%, 2 votes
Sorry. I just experienced the same problems. Frustrating...My suggestion: Just return it to Radio Shake or wherever you bought it, and get yourself a better camera. A few more bucks will save you the waste of time and headaches.
Best of luck.
Was this helpful?
Yes
No
Solution #5
posted on Feb 03, 2009
Very Helpful)
Adimn
Rank: Apprentice
Rating: 100%, 1 votes
Im need setup
download
Was this helpful?
Yes
No
Solution #6
posted on Nov 06, 2009
Not Rated)
stanely1956
Rank: Apprentice
Rating: 0%, 0 votes
u can download here drivers
Was this helpful?
Yes
No
Solution #7
posted on Sep 14, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
HELP !
Solution #8
posted on Aug 29, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Windows XP service pack 1 does not support the camera.
Generic XP SPII (2) driver recognize camera, gives you basic use of the camera AND microphone. Skype works with the camera. I did replace a Logitec quick cam notebook, with this. No mfg driver needed with my HP XP Media edition & service pack 2.
Do not install the supplied driver or software.
Solution #9
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Return it to RadioSahack or wherever you ought it. It ain't worth it.
Spend a few more bucks and get a decent camera and easier installation!
Solution #10
posted on Apr 19, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
check out @ http://rsk.imageg.net/graphics/uc/rsk/Support/SoftwareDownload/2500297.exe
Popular Solutions for Web Cameras
Questions and Unsolved Problems for Web Cameras
Answer
web cam that works with vista 64 bit
Answer
We are looking for a basic web cam for outside use that we can record/monitor from a computer. Any... (More)
Answer
i have an intel play me2 Cam but when i try to install it through the CD issued by intel, it says... (More)
Answer
In MSN my Lifecam VX-1000 stay "freezing"
10 Other Users Have The Same Problem - Continued
Comment by Guest, posted on Jul 08, 2008
I lose my gigaware web cam driver #25-297, how i download from web ?
Comment by jollad, posted on Jun 13, 2008
I bought a 2-PC gigaware webcam 25-297 Radio Shark product but can't install it with the driver that came with it. I have tried getting solution online but no clue from it. The CD that came with it will just run for some times and stop.It gets to finish the installation but the icon does not appear and when the camera is plugged in it says the device is not installed. I have window xp.
Comment by Guest, posted on Jun 04, 2008
exactly the same problems, will return it tomorrow.
Comment by kidithara, posted on Apr 21, 2008
I bought a gigaware webcam (model 25-297) and i can't seem to install its driver into my computer (windows XP). Everytime i attempt to do that, the installshield will run for sometime and suddenly it just disappear with only the icon on the bar next to the start menu. When i go to the windows task manager, it appears to be there but there seems to be no activity done by the program. Any Help would be GREATLY appreciated, i have NO idea whats wrong or what i need to do to fix this problem. Thanks in advance.
Comment by telfrey, posted on Mar 26, 2008
after installing the driver cd that came with thegigaware 25-297 2-pack, window appeared with amessage that said, compatable sofware already installed.
i cannot, load sofware from cd, consequently i cannot use my webcam
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Web Cameras:
Top Web Camera Experts
Rank: Guru Guru
Solutions: 14851
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Web Camera Experts
Top Computer & Laptop Repair
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
