Question about Nitro BMW-486 Car Audio Amplifier
Was a green light during the day the next red and stays red
Nitro 486 amp was green for 2 weeks. now its on protect i put new wires in for every thing. i called a sound shop and he told me that he would test my amp or something like that. do you have any suggestions and what wires would he be talking about and what would he be using so that maybe i could just do it myself.
  • Anonymous Mar 19, 2008
    all wires are taped i still haven't had any luck.i hooked up another amp and it plays fine is it that the amp is fried. or do you know what kind of meter this sound shop is talking about
Kill Yourself :D
Posted on Sep 30, 2008
Look for wires that are touching each other like speaker wires or you may have a blown sub
Posted on Mar 14, 2008
My nitro bmw 486 cuts out when i turn the volume up alittle bit,subs start crackling and distorting turn volume back down sounds just fine amp doesn't go to protect mode still works 4 guage wire a
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty D.A thumbs up would be greatly appreciated if this answer is helpful to you. nitro-bmw-486-cuts-out-when-turn-volume-lv2kkrmxrai4iihdvw4m3np2-1-0.jpg
Jul 20, 2012 | Nitro BMW-486 Car Audio Amplifier
Its in protect mode and wont go back to normal
disconnect everything except the power, remote, and ground. turn off then on. if it goes into protect mode then there's a posibility that the amp if fried. check all the speaker inputs and outputs to make sure that there are no stray wires shorting out. if it stays on then you may have a short on a speaker wire or an auxilary input wire. plug each one in one at a time until it goes into protect mode, then that's the shorted wire or it could be a shorted speaker.
Aug 09, 2010 | Nitro BMW-486 Car Audio Amplifier
Hello, i have a nitro bmw 486 amp. i use it to power my 2 subwoofers in my trunk. its a very good amp and sure does its job, but randomly the light will turn red, which means protect, and my subs will shut...
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty D .A thumbs up would be greatly appreciated if this answer is helpful to you. nitro-lv2kkrmxrai4iihdvw4m3np2-1-0_0.jpg
Jul 31, 2010 | Nitro BMW-486 Car Audio Amplifier
Its not powering on
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty. D .A thumbs up would be greatly appreciated if this answer is helpful to you. its-not-powering-lv2kkrmxrai4iihdvw4m3np2-2-0.jpg http://www.nitrobmw.com/
Apr 07, 2010 | Nitro BMW-486 Car Audio Amplifier
Ok so my Nitro BMW - 481 2000w amp was working and then i came back the next day and the red protect light was on its been working for weeks but now it has the red light.
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty. D .A thumbs up would be greatly appreciated if this answer is helpful to you. ok-nitro-bmw-481-2000w-amp-working-lv2kkrmxrai4iihdvw4m3np2-2-0.jpg http://www.nitrobmw.com/
Mar 17, 2010 | Nitro BMW-481 Car Audio Amplifier
My nitro bmw-486 amp is in protect mode how can I
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty De .A thumbs up would be greatly appreciated if this answer is helpful to you. nitro-bmw-486-amp-in-protect-mode-lv2kkrmxrai4iihdvw4m3np2-1-0.jpg
Feb 24, 2010 | Nitro BMW-486 Car Audio Amplifier
My nitro bmw-486 amp plays but want put out loud sound
I have the same exact amp. And my friend has the smaller 1600 watt amp, and this happened to his. Basically, just start from scratch. Unhook every single wire, and rewire it. If that doesn't work, look at the side of it, and there are a few knobs that you can adjust using a philips head screwdriver. Try adjusting the bass boost knob.
Jan 13, 2010 | Nitro BMW-486 Car Audio Amplifier
Same problem i have a 486 bridge green light before now red.
IF THE RED PROTECTION LIGHT STAYS ON MAINLY MEANS THAT ITS BLOWN, I HAD THE SAME PROBLEM BUT MY PROTECT LICHT DIDNT COME ON, IF U HAVE A WARRNETY ON U CAN USE.
Jun 18, 2009 | Nitro BMW-486 Car Audio Amplifier
481 doesn't work
did that to mine. Bat went dead and went to jump the car. What happends is when you attach the jumper cables, it surges the power to the amp. This gets worse with caps. I would say you blew the relay in the amp and needs to be replaced. It is worth fixin but youll have to send it off or take it to a repair shop to have the new relay put in
Oct 05, 2008 | Nitro BMW-481 Car Audio Amplifier
Nitro 1000 w amp
unplug the speakers and the RCA leads from the amp, if the red protection light is still lit then its 1 of your linear amps blown or mosfet depending what your amp uses..if the red light does go off with the leads all disconnected, then connect 1 lead at a time and check the light,when you connect the bad lead or speaker then the light will come on and you know that 1 needs replacing..hope this helps
Jun 30, 2008 | Nitro BMW-481 Car Audio Amplifier
Nitro BMW-486 Car Audio Amplifier Logo
190 people viewed this question
Top Nitro Car Audio & Video Experts
ravie__s
Level 1 Expert
Mark Skinner
Are you a Nitro Car Audio and Video Expert? Answer questions, earn points and help others
